bubblegoose
Everything posted by bubblegoose
Cheap auto painter in Auckland / north shore.
bubblegoose replied to Truenotch's topic in Upper North Island Region
would not want, that would only just about cover materials -
iirc from the small print rust kill does not kill rust but prevents it from forming on clean steel (like most paint) where as por and hammerite can be applied to rusty metal
phosphoric acid wash (metal ready/deoxidine etc) then por15 or hammerite then millions of cavity wax
sweet, im attacking voldos fairlady over xmas so ill take some pictures and blurb about application of said primer
for restoration epoxy is defiantly the way to go, mostly when bare metalworking its perfect for slapping on right after blasting or stripping then you can asses rust and dents without fear of the metal deteriorating while you work on the car. For panel work a 2k hi build or filler primer is a must as it has many multiple times the build as an epoxy and sands alot easier which is nice buying a wet on wet capable etch primer that costs not much more than either single product is clearly the way to go if its available at the time to clarify what a wet on wet primer is for for those who are not so sure, its a thin primer sprayed out of a regular paint gun before you lay down your colour, reason for using it can be to cover up any wayward sanding marks you may have missed (dry guide helps with this), to prime areas that have been rubbed though to bare metal or bog, if you are doing a colour change and have several patched of 2k primer over repairs but dont want to 2k prime the whole car, as a ground coat for colours with poor coverage and a few other reasons but those are the mains ^dry guide, is a colored dust usually black that can be rubbed over bog and primer to check for shape, hi/lo spots and when working down the sanding grades it will show up coarse lines that need attention imo there are too many products on the market, should just make a self priming black paint and leave it at that
thats a silly quote, but i suppose it its auks prices, shouldn't be more than 300 down here -
you can get away with it on alot of colours but ive never seen a pearl spot painted that looks better than a spraycan job you blend out the clear and buff the overlap, looks good for a good few years, longer if done right -
is that a straight white or a pearl? touch up guys fail at pearls -
set the idle to about 1000 then using the little adjusters on the linkages between each carb balance 1-2 then 3-4 then 2-3 pays to have your own rig as balancing is part of general servicing
left an earth cable off?
ill just throw this up here this was a weekend rush job on cherrios 740 and after slapping on the second coat of black base coat i noticed that we had rushed too much and 320 sanding marks were visible over the whole car so i let it sit for 15mins and slapped coat of spies wet on wet mixed 50:50 with black base (as seen in the picture) then 2 more coats of black and it fully covered the whole woopsie. its a fantastic product
we use PPG but the wet on wet etch shit we swapped to standox as it seems to self level better reason behind sticking with the 1k system for this is all 2k products have a much higher build/fill and always require sanding unless doing a full wet on wet coat ( ie ppg dp40/ 4000) with the standox 1k we can spot prime a rub though, let it flash then paint over it with no visible edges or peel as it drys to thin to make a difference its also super handy to throw down as a first coat before slapping heaps of 2k primer over a rough old panel
unfortunately spece you are incorrect, 1k etch is used as a wet on wet primer (2 in 1 product) in alot of shops including the one im at and is covered under the manufacturers lifetime guarentee most can even be tinted to be used as a ground coat for weak covering metallics, its not as old school as you think
read up on balancing bike carbs, its real easy to to do and you don't need a fancy set of gauges you can use a length of clear pipe to make a cheap manometer. make sure you get your fuel pressure to 3psi and have the carbs balanced before you do any jetting changes
a bike mechanic is your best bet, thats the only reason i like them. just dont go to an old guy they dont like it
worth mentioning that epoxy primer is hard as nails and is far from a pleasant event in the sanding process if you want a quick tidy up then look into u-pol dolphin glaze for your stone chips and then a 2k filler primer over that (mipa is cheap and nice to use) upol also claims there bog will stick to paint as well as bare steel, not that we ever bog over paint *ahem*
PPS. if its white then MIPA 2K all the way its almost monkey proof paint and delightfully cheap, i did my delta in the garage and it came out like glass (lots of runs because i was too impatient between coats)
ps, pay for a shipping crate and ill post my self up to paint your car/can lend you my gun if you pays poostage
metalux WHAT i used 5 litres covering an scargo never again will i use lux basecoat which was about 6 coats, 3 times more than it would have been in PPG cobra. 2k lux is alright though as for laying clear on 'super thick' don't, lay it on wet and leave it as that, super thick will dry super peely as for the gun not having much effect on paint i also call lies on this, i did my first paint chobs with a machine works gun then switched to a gti pro and was dropped with the difference it made, then i used to a sata and was super impressed all over again slow and fast hardener has almost no effect on the peel but slower hardener will give a better gloss as the hardener doesnt take efect for hours after the paint has been applyed reducer speed will have a small effect on peel but not much, id go medium for a garage job on a full repaint so you have plenty of time to get round the car the biggest thing to effect the finish is how heavy you lay your paint on, gun set up and time between coats peel takes longer to polish out than runs but often looks better after
clear coat kit will cost you $300 but will do 2 cars and you will need 2L base coat for repaint on a ke and add some more if you want to do door shuts so say $600 but with left over clear for your next project 2k would cost you $300ish for midrange paint so slightly cheaper but its not as sun proof, depends how much you love your car
be warned, warm is good for painting but can also increase your change of runs as the paint thins when it heats up, so be sure to practice in the same conditions you will be painting and id advise getting shit set up/masked the night before and getting and early start when its cooler for painting and gets hot later one for budget bake cycle cool shed=more time to get around the car hot shed=dry spray around the start/finish points
no need to prime its already go magic pixie dust in the paint, the reason it says 'do not thin' is because the hammered finish paint is actually 2 types of paint in one tin and thinning can mess with the way it separates and 'hammers up' either buy it in a spray can (looks sweet) or put it on with a medium soft small roller and do so quickly so your not rolling over paint that's started to tack off and your results should be satisfactory, i fond best results to be had when a second and third coats are done the following day
depends on the temperature, im assuming this is a garage job so ill say 15 degrees, id say leave it 15-30 minutes between coats just give the primed panels a bit of time in the sun before working on them to bake out the moisture and you should be good to go
just seen that people have started to put usefull measurements on sprocket auctions, so now you can crack out the verniers and go nuts on trademe
the 'restrictor' in the intake is actually a diffuser and requires many more tweaks to get gains from its removal anyway, back to the chains. you want to order the oe honda front sprocket and a decent length chain then find a rear 428 sprocket with the same pcd and bore size as the v50, its the same as car wheels there located on the hub not the bolts which its why its better to go to a shop (for the rear sprocket atleast) where you can get a better match then a guessing game on the internet you also get what you pay for with chains, cheap ones will stretch much faster than a good one (but you dont need a fancy gold racing chain like gail)
