Everything posted by KKtrips
The complicated version could be the master cylinder is too small and the tiny amount that each piston moves when you multiply by 8 front pistons as opposed to the factory single sliding callipers (or is it twin on a Mk2??) would increase your pedal travel - a bigger piston would increase the required braking effort but increase the volume shifted and reduce the pedal travel. Could be as simple as air in the system or badly adjusted rear brakes or sticking caliper seals - causing the piston to return too far and having to be pumped out again. I would try clamping off each brake hose successively and see if you can trace which wheel it is or at least whether it is front or rear. Then come back to me..
Mine does the same thing - and its a very similar one - kinda weird - I think maybe cos they are an inductive type tach rather than a plain feed like normal that they need something special done.. if you find a cure - fill me in please and v.v.
If I was to cut and weld anything - I would weld a longer section into the threaded rack end as opposed to a cast tie rod end.. But thats just me..
IMHO - if you have a hi volume oil pump you should not be getting 100psi - if you are, you have WAY too much volume or blocked oil galleries, anything over 80 will start to overpressurize the bearings and cause the surface to erode away.. I am NOT an engine builder but this is a general rule I have always worked to.. My general rule is oil pressure should be 60psi when hot and never more than 80psi when cold. PS - there is no such thing as a high pressure oil pump - it is the size of the oil galleries that determine your oil pressure. It is a high volume oil pump you talking about.. ie - LOTS of pressure becasue of the flow restriction and the volume trying to get up there.. Think something like - Hi Volume = trying to squeeze a whole salami up the eye of your pee-pee nuff said
get some 87-89 323/laser or 87-97 323/laser wagon rims - chuck on some pick a part 155-13 or 165-70-13 tyres with an hours work you can fit them no problems. It cost me about $68 for 4 rims and 4 x half worn tyres. I had the tyres removed, I sanded and painted all the rims for about $25, then had them fitted and balanced for $32 - all up cost for a bangin set of rims and worn tyres $125!! Priceless!!
A bloody beautiful set of gold centre simmons would look just peachy!!
hjaving trouble finding info but would like to know more. It did have a v6 capri engine in it. HE4619 was the plates if you could dig up more? It was a couple haircuts ago but I think the guys name was Gavin (He might have been a ginga?? and he worked at U-Save spares on Tacy St in Kilbirnie, It does seem to ring true it had a fairly rad V6 in it, (memory made me think it was a docile V8 cos it wasnt wildly fast) it was kinda metallic blue and the guy use to do some pretty scary things in it.. The other thing I sort of remember was it had about a zillion gauges in the centre console - and it was really gnarly on pedalspace - the clutch and brake pedals were nearly on top of each other. Other than that I am a little stuck - ol Unka Jakey Pants might remember the car also - I guess he was into weird little Fords at the time the car was zinging around Wellington - he might have still had his Heavy Metal hairdo then too.. The guy who would know a lot more would be Ian (AKA Kaos) who works out at either NZ Car parts or Partsworld in Porirua.. he used to work at U-Save when that beast was around - But I dont think Kaos is on this website..
I think I remember that car in Wellington a few years back - it was a blue colour and from memory it had either a gnarly v6 or a docile v8 in it.. Do you know any history?
The best way to teach Kelford a lesson - Go Rota Bro!! try and get him to sell you a cam grind for that puppy.. it'll take AGES to get it
I can promise you can go as wide as what I got - you cannot go any wider without cutting or serious body mods - mine involved using a log splitter on the front guards to pull them outwards a little - just a gentle persuasion. The rears are a bit more involved but just a cutoff wheel on a grinder - cut a notch about every 2 inches around the inside lip of your wheelarch then hammer them flat.. does a sweet job!! (also tyres no wider than 165/70/13 else you have tyre rubbage dramas)
Much better looking now!! It looks like a 4WD in the before photos
I have remove countless of these on japa lasers/323's - You need a sharp centre punch. Punch a starting divot into it - then using the punch as a drift, tap it firmly counterclockwise it will undo slowly - getting faster as it loosens. Then do the other one.. Locksmith should have a good idea how to do it if you dont. To put it back on you will need to buy replacement torque to yield bolts.. just tighten it to a nice snug tightness - then back it off a quarter turn sharply and the bolt head will snap off as it is meant to - or you can just leave the head on there for next time you loose your keys, if you undo it carefully the head won't snap off.
Want a whole new suspension set up then lol? have it free if your prepared to get the bastard out yerself before i scrap metal it.. . When are you scrapping it? I normally don't turn down spares.. got plenty of em at the mo. But more is always good.. If you were closer than the Mighty Wai I could be very keen to strip it. But its a long way for stuff I most probably already have a lot of... Any pics of your Morange all slammed yet? PS - I have found you can safely slam them to 2 "man" fingers width distance between the top of the front wheels and the wheelarch - so for those that need metric measurements, that is about 3 "woman" fingers..
because of a stupid bet..
When ya ride em low, and take it off road, sometimes shit happens and shit happened - like ya say though - someone sneezed on it and she moved sweet..
Nope - thats a lie.. made up by a real assssshole!
Corolla - ah that was Patrick Pull a Phat Trick's car - he sold it since - its got a 4age with twin sidies on it.. and its matt black not green.. Its sweet ride with the mods, it rides very well and can corner like a freakin go kart.. Just its got a small leak in the left hand side so I have to pump up the suspension once every couple months to stop it hitting the bump stops.
foreshore!! more pics will go up after the next cruise (new years)
what are keybangers? and we are not a group - we are a gang.. a real bunch of badasses.. hahaha
sobering up is for drivers and the weak.
Chair Bowl - You bringing out your "bangin" mercedes sometime soon??
yep he came from Palmy - some old chap (nice chap though) owned it and I managed to latch onto it by a pure fluke while surfing trademe drunk on friday looking for people to annoy with dumb questions.. bought it hungover the next day
Drove back 600 odd clicks to Wellys with no clutch - oh I love the sound of gears gnashing!! Fixed it when I got home and its been sitting outside my house in disgust ever since - maybe except one drunken cruise to palmy and the odd thrash to work when the wife takes the car to work. Never to mind - massive BDA Car Gang cruise at New Years over the hill somewhere!! woohoo!! That reminds me - I better check the oil and inflate the spare sometime in the next 6 weeks
pretty much the extent of my cruising for the weekend at the beach hop - the clutch shit itself within 50metres of driving away on the first morning after arriving
