Everything posted by KKtrips
Yeah I had the Commy slam panel brackets powdercoated by them today. Never asked if they did blasting but I'm pretty sure they don't.
Any idea how that would translate into a cost for a motorbike frame? Specifically my C90? I've tried calling him and he is super evasive giving a price. He didn't even want to give me a ballpark to within.
OK so a bevvy of parts arrived from the states in the last couple of days. Heaps of electrical bits and a rear guard plus an aftermarket conversion kit for engine mount (so no longer need my home made one) Also my parts bike arrives from Dunedin on Sunday night, plan is to rip into full mock up on Monday and Tuesday. Maybe even try and kick it into life next week before full strip down and paint.
- 90 replies
Thousand Dollar Supercar's 1988 Jaguar XJ-S 3.6
KKtrips replied to Thousand Dollar Supercar's topic in Project Discussion
Ask yourself. What would Lemmy do? -
Also you can run the pipes under the subframe and mount the mufflers in the rear guards if you want ground clearance. -
Mate, a straight pipe and a couple of Cobys exiting through the sill and shit will be cash. -
- 90 replies
Tonight's job was making the engine mount, engineers, please bare with me cos this may be painful to look at, but my engineering skills ain't that flash.. First was put the engine where I wanted it to sit and measure the distance between centres from the original engine mount location to the new mount location. (which was 30mm BTW) Next cut some 50mm x 6mm strap to 50mm lengths giving me 50x50x6 plates. Drill 2 pilot holes 30mm apart along the centre line of the plate and drill them to 11mm (10mm bolt plus wiggle) Cut down the sides to a nice taper then repeat x 2 Next measure the gap from the engine to the plates with them bolted in, each side was different (8mm one side and 10mm the other) Also cut a spacer to go where the engine used to sit (90mm wide but I fucked up so have to add a wee washer on one side to pack it out) Fit the plates with spacers and tighten it all up, VOILA! a mount is born. And here are all the parts back out of the bike. I intend to radius the corners of the plates and weld the small spacers to the plates and then weld the plates to the frame. But I ran out of time tonight. It was incredibly strong as it was by just tightening up the bolts, but for longevity I reckon its probably best to weld the plates in place. I may linish down the smaller spacers yet, because it might be a mission to get the engine in and out with the snugness it possesses currently. Anyhow if you have any criticism then fire away. Although this seems a much easier method than the way other people have described to me how they did it. Also I won't be using threaded rod in the final version - I just used it for mock up purposes this time around.
- 90 replies
- 16
It looks exactly the same spec as this. (even down to the unusual clutch fork/lever arrangement - I've been told that normally they are horizontal pull - mine is vertical) https://assassindirtbikes.com.au/store/engines/lifan-125cc-r-race-big-bore-engine-motor-dirt-bike-assassin-dhz-thumpstar-atomik-1372.html Also, I now believe that this will bolt straight into your frame, it's only the C90 frames that need engine mount modification.
KKtrips replied to KKtrips's topic in Lower North Island Region
and trains -
Endorsed by admin. When I am in need of an area rep, I always reach for a Kickers. *ad jingle* Get yours now before they sell out, .99c * at all fine fuel establishments. *recommended retail price, your retail experience may differ -
Probably not a good enough rider for that.
Yes definitely. Not only would that be fucking cool, you are probably saving the life of a mechanic. Maybe even 2 mechanics. -
Those rear brakes are a shit cunt to replace. Rear disc replacement is major involving removing rusty seized together exhaust joints, busted knuckles, prayers to multiple deitys, suicide and a lot of swearing. IMHO you may as well drop.the whole subframe and give it a full rebuild. Do it once do it right. Perhaps even get a custom.bolt together exhaust made for it rather than stupid slip joints that seize or break. Also those discs look kind of OK and I would not hesitate in rolling with them until I was feeling particularly masochistic. If anything just replace the hand brake pads because they are not too bad to replace if your car has the access panels under the rear seat. (not all of them do, weirdly/Jaguarly) PS: Paul Walbran's is the best Jag Barry I know of up your way. edit - http://mgparts.co.nz/what-we-do-and-meet-the-team/ -
Alrighty then. I'll text ya on Saturday.
You working tomorrow? I might swing by and ding a ding dang my dang a long ling long.
Bought this tonight for the parts too. Brand new wheels and tyres, speedo, bars and bar mount, grips, lights, number plate frame and leg shield. Plus I'll have a spare frame and fork for if I want to take on another project in the future.
OK so got the engine sitting in tonight, all it took was drilling the 2 mounts in the motor to 10mm. (from 8mm) I should probably go 10.5mm cos the bolt is a snug fit the whole way through the mount. You can see the bottom mount hole and how far away the bolt in the engine sits. Will be piss easy to make some mounts for it. That's tomorrows job probably. A close up of the mount bolt to frame for reference. Engine sitting in the frame rather nicely. The carb needs to be turned 90 degrees otherwise it will be in the way of the front wheel. Chucked the leg shield on and It fits really nicely, will need a decent trim for the carb to poke through (need to figure out if I want it to come out right or left side) and also a hole or two for cables to snake through. I forgot to take a pic of all the wiring but it is all in the fuel tank area and will be easy to neatly tuck away and it's going to be a piece of piss to wire up.
Yeah there is plenty of standard cub full fendered but fuck all deluxe's, almost every picture of a customised deluxe has the tail docked.
Oooo, tell me what I need to do get in the queue for some of that very exact same treatment?
Man it is so hard to find sweet Deluxe Cub's that have been customised but maintained a full rear fender. Found a total of 2 in all my searching. So this is my new inspiration. not sold on the body colour leg shield or those rear springs but I do like it a lot. If anyone knows of any non-potato shots of this bike, preferably from different angles please attach them.
All good mate, don't stress, I ordered a brand new one from the states as he seller had a few other things I needed too. Plus this one has the mahoosive taillight bracket deleted.
Cool, sounds good. Cheers
How long does it take to arrive normally?
