DB8-TypeR
Everything posted by DB8-TypeR
  1. So a Dax update, have been slowly accumulating parts and then stripped it right down, got some more cracks in the frame welded up and began the painting process. Conveniently I was working night shift (no one else in the workshop) and we have a large oven that is meant for baking varnish onto electric motors Left it to sit for a while then started making it look like a bike again Still a long way to go, lots of little jobs like tidying up the original badges
  2. Thanks to @Raizer I got some Honda Gyro front shocks (already shorter than spacy by 10mm) then shortened the shock a further 20mm. At this stage I havnt cut the spring, its just got more preload to make it stiffer. The rear still isnt lowered (apart from when I sit on it), but need to sort out a kick stand instead of center stand as it drags a bit much even at this height. Once Ive sorted that then should be able to get it a bit lower Pic from previous page for reference Other than that, still just using it daily to get to work and its going sweet. Knocking sound from previous post was loose bolts holding center of the rear wheels to the rim
  3. Am still working on lowering it (too many projects), wont be that low so I can retain some ridability but will see what I can do. It developed a knocking sound from possibly the gear train today so hopefully nothing serious
  4. Still using the Spacy as a daily (still not registered.....) and have got the Chaly running pretty good, 38 idle Jet, 82main and the needle one clip up from the bottom. Apart from being a bit obnoxiously loud its pretty good. And into the Dax, got a new seat and exhaust from webike, discarded the muffler that came with that and attached a Supertrapp Replica from aliexpress. Also have a 120/90-10 tyre on the back to check it was all going to fit. Chain will be a tight fit but hopefully ok
  5. Finally got the Chaly running with new exhaust/carb/head Had got sidetracked when I only noticed one of the intake manifold threads was stripped after I swapped the head. So then ordered some threaded inserts off aliexpress that were M6 inner thread and M9 outer. Then once i had everything attached it just wouldnt start, no compression..... checked all the headgasket and things Id done and couldnt fault it but when kicking it over it would just chuff air and fuel back out the carb. Did some thinking and decided to check valve clearences (which id set before I put the head on) and dontcha know it, the intake valve was tight as. Loosened it up a bit and first kick it started. So now its running and have ridden it around the driveway, need to order some jets of ali to get it right, idle jet seems a bit big and a unknown size, main jet is a 75 at the moment which shouldnt be far off. Have been using the spacy as my daily for the last 7 weeks or so (probably should register it...) and apart from blocking the carb a couple times it been good. Quite fun to ride and offers a bit more wind protection on the cold mornings than the DJ1 ever did. Hopefully be able to commit some finances to getting the Dax finished by the end of the year
  6. Cool, at least they still look good. Im looking for tyres for mine and options for 215/45 are fairly average/expensive
  7. What size tyres do you have on this? The factory, hard to find 215/45R16?
  8. DB8-TypeR
    Break the bank and order a twincam head! Cant wait to see this complete
  9. Finished assembly and took it for its maiden voyage around the block. Acceleration is pretty average but once it gets into top gear it goes pretty good. Need to adjust idle as once warm it wants to stall
  10. Yea, the Dash is pretty much what made me want this. And it even all works!
  11. So my engine turned up from Japan last week, assembled it all on Sunday and last night acheived its first start
  12. Been meaning to do the waikaremoana trip at some stage by car so perfect excuse. May not be a winter trip though, will see how weather/life goes and if nobody has done a recce will do so and report back. Id imagine there will be next to nothing re:gas after murupara and before gisborne? Will see how the mrs is closer to the time before I can commit to the ride, may have Dax done by then also depending how carried away I get with the spacy
  13. Im keen to do a rece of the murupara to gizzy bit. But wont be for a couple months probably so may not be of use. Doubt I will have a suitable bike for the trip by then however
  14. Its the stock height pretty much (its on the stand so sitting slightly higher) but I do have a plan to lower it once Ive got it running.
  15. I hadnt even thought of that. Not really in the habit of naming vehicles. But how can i not
  16. Fitted the wheels to spacy to see how it looked. Not bad I reckon
  17. LED lamps will likely blow as most scooters run the headlights off the ac circuit
  18. Yea tend to be just a few common sizes generally stamped inside the drum
  19. Most common fault ive found with electric start is brushes on the starter or a poked start relay. Brakes, might just need adjusting, might need new pads. For $30 id just replace the pads as if its been sitting forma while the brake material could have fallen off the shoe
  20. Good to see it saved!
  21. Havnt really achived much with any project, waiting for Spacy engine to arrive but have beadblasted rims, painted and fitted new tyres (thanks to mr Mopednz Callum) Chaly is waiting for parts to arrive, Dax is waiting for funds for parts, DJ1 is being used daily but will possibly be sold once spacy is reliable
  22. Ive got nothing to add cept dont be whatever colour the tribesmen dont like (probably white im guessing) around Kaiangaroa/Murupara
  23. Ive got 7/6k in mine on fortune auto. They are alright but not enough droop so dont soak up constant undulations well. Its ok when its just me but always concious of how uncomfortable it is for the wife. Trying to make mine closer to stock as they are so much fun to drive like that
  24. Wish mine was that tidy. How are the ohlins? Im sick of having coilovers ruin fun roads so swapping back to bilstein/spoon spring combo shortly
  25. So things are getting a little out of hand
