Everything posted by kpr
Its just a G4 ecu. The gear cut control looks pretty basic Pretty sure its a mechanical issue. as never once got it to change at high rpm. but yeh that would be a good setup to have, to take bit of human error out. Have some new parts on order to throw at it, hopefully will make it better
Possible has had some previous damage. and has been your misfire issue all along. if that hole was burning a bit of oil. which looks like it has been, would be more prone to knock. Which will have been what ended it for good, you'll probably find the ringlands just floating around in there when pull the pistons. you can get all fancy and egt every cylinder. but making sure isn't set on the edge of knock when tuned is the main thing. checking the plugs after few pulls is good idea also. Not saying it was a tuning issue. but also make sure you tuner is using knock detection and not just using ign map numbers that worked on another engine the same.
I tested it with a crappy supercheap compression tester awhile back before put the trd head gasket on it. 130 , 130, 100, 130. can only assume its worse now. with factory cams, no body home on 3 at idle. with the bigger cams idles like junk anyway so easy to ignore. end game is to build the long rod engine properly. with the head off the 150kw engine along with vvti. around atlantic 4age numbers but with a massive power band and reliable is the goal. looks doable at this stage turd will be coming out soon, and in the meantime will be putting 150kw engine back in. probably put a vvti setup on it also Too many bits of pistons and rings coming out the exhaust, might break my camera
Yeah found the same thing. looks like couple of them maybe the same was w/g box. but not much coming up for them either dog box way out of my budget. Think i'll throw some new oem parts at it if cant find anything else. I probably didn't put a new spigot bearing in the end of crank, when put the junk engine in. so probably a suspect worth looking at that could be causing some drag if its toast. It used to work fine with 9k limiter and bigger 212mm clutch. so thought another 1000rpm wouldn't be too much to ask.
^ clutch was adjusted like that, to the point thought may have not quite been releasing. so gave it a little more, no dice It has the small 200mm friction plate. but will see if anything "light weight" is available without going too silly. Maybe will throw some fresh syncro rings and sleeves in it
my poor old t50 doesn't want to shift gears at 10k rpm. around 8k seems ok. just that bit more is a no go. All the gears seem about the same So yeah probably not a very common thing. But trying to figure out if its a limitation of the box, its just old junk i can fix. or if can modify it to work better. have heard of people filing the teeth down on the synco's or the likes Or same deal with J160 boxes. anyone used them at 10,000+ rpms? could be an option to swap to. Have tried the usual stuff btw, adjusting clutch etc.
"forged" likely the same process as toyota has been using since forever, they just started making them lighter in the late 90's. not like the 80's-90's stuff that you can run a zillion hp on factory bottom end
can you get in there to measure the valve lift at tdc with dial gauge or even by eye? should give you a pretty good idea if cam timing is right.
How much are you guys paying for a 90deg 3" from autobend? or any 90deg for that matter. I can sort roman out with some stainless, is about double the price of that sta stuff for bend. but sta stuff also sounds like it should go straight in the bin haha
I have no idea what happened to that engine. seems ive owned 3 20v's in my life, for shame. although only ones made it out alive
Can someone tell me if this a normal amount of smoke for a 4age? seems about right to me? 10200rpm on stock 2nd hand oil pump and 300,000k pistons/rings and crank. seems like the winning combo Yeah it really needs to come out. but want to put some run time on the vvti setup. Had a little play with some shorter intake runners. looses the peak off the top as expected, if just jam them on. same deal as with fixed timing. but after tuning the vvti, was able to pretty much match the peak of the longer runners and gain power after peak. Holding on real well right out to 10k with the little 193b cams. Looking good for the end game setup red is normal intake runner length dark brown is 40mm shorter - ignore bump at end of run dyno tends to have a frizz up there at that road speed. Both with vvti dialed in.
- 216 replies
- 34
wait till it snaps in half haha. As you said some kinda brace from bottom of engine will be good idea. Probably back to where the new pipes join on if possible
Done. Now a @Roman problem haha I'll quietly leave the room now. can sense the growing anger, due to the lack of graphs
Yeah back when you could buy a kp starlet with 4age and t50 for 1500 bucks haha
So, I'm onto version 2 of the vvti setup. main difference is the solenoid setup. the original setup I had the solenoid remote mounted. as was easier to do it that way and to confirm would all work. but ocd couldn't handle all the lines. more chances of leaks and stuff breaking. It had 4 lines. Pressure feed from engine, drain back to sump and 2 for advance/retard New setup eliminates the advance/retard lines. So just the 1 pressure line (feed from engine) and drain line to sump. yeah im still using the dipstick tube for the drain, ha. Solenoid now mounts in the block right by pulley and bolts to the other part. so all the advance retard ports and wizardry happens inside the ali blocks. Doesn't look too out of place. have done a small amount of run time with it. All looking good so far. Also moved the cam sensor. before it was hidden in the spark plug valley. but getting the clearance right was a pain, since the covers can move around side to side on the studs Now its on the top at back of cover. I had a little accident with the bran new genuine timing belt, so had to get this blue thing to get me going again.
- 216 replies
- 32
going by the pic of your exhaust, you should be able to still fit a reso after that abortion of pipes ^
yep runners made and welded. that was the easy bit, about 3 hours work. there is over a day just in the collector. just gotta weld runners to flange and stick the collector on and hope they fit haha
It depends what you are calling the "exhaust" There is plenty to be gained getting the sizing right after the merge. Lots of people hit me with "such and such motorbike or race car doesn't run an exhaust that big" In a motorbikes case, just happens the length of bike is about the right place to end exhaust. same deal with race car. either the car ends or not a full length system. Banging a 3" pipe on right where all 4 pipes join together will probably loose power yes. but going big at the right place onward, is the way to go. I'll place money that most of the gains roman will see, is in the midrange along with a bit of peak power
Yeah, flows more. but kinda means your exhaust is too small if makes more power. After the end of that pipe, idea is to simulate no exhaust. biggest straight through glass pack can fit straight after it. the rest of exhaust just needs to make it quieter, while adding little exhaust pressure as possible So yeah echo with 3" exhaust
Will work as is, but will be extremely loud haha. lt will also work pretty much the same, with the correct exhaust/ mufflers after it
Can't argue with that In other news, can we fire up that go fund me page again, roman gonna need a longer car kinda silly seeing it all out in a straight line like that. the length is roughly same as what i run on 4age still waiting on the straight pipe to show up. gone about far as can go now. collector and cone section 100% done I'll leave the last bit off. as really winging it for fitment now.
If could harness @Roman intake mods. In a perfect world the same 18psi would be about 316hp or 27hp more. not really apples to apples / dyno to dyno. but maybe a better comparison than most, considering both have a cork in the exhuast
Classic courier gag. only deliver half the stuff. But got collector tacked together Idea behind the fancy collector is try cut down some of the big open area over a standard merge collector. Its still there but over a shorter distance. Also transitions nicely back into diverging cone
looks pretty decent, looking at that dyno graph. looks like its making full boost by 4500 going by torque curve. 200hp by 5000rpm.
