Yowzer
Everything posted by Yowzer
  1. It's not that they can't handle the power, it's that they can't handle a dc voltage. Plug an old speaker straight up to a 12V battery and see how long it lasts. Now picture how long it lasts at 30V. It will, in most cases, be the installers fault as a correctly set up gain, input voltage and crossover will prevent the problem. But wtf is the point in running a 100W speaker on a 50W amp? Wasted potential right there. The damage occurs when carnies try to get 100W from their 50W amp by cranking the gain to beyond what the amp can provide. Yeh, right..... tui ad. Steve Ouch, Yowzer, I think you just got burned Shit yeah, I guess I just fluked a $8k+ install On a side note, we are actually a mile off topic here. BRB while I read the original question...
  2. Keen as if cash allows
  3. Make sure your amps are well under rated for your speakers Haha yeah, wouldn't wanna be operating them efficiently or anything aye! Sheepers boe, what ya want for it?
  4. List of things to do, in no particular order. [*:20lgpb93]half done - Quieten down the exhaust [*:20lgpb93]Wheel alignment [*:20lgpb93]Install power steering box [*:20lgpb93]Improve front carpet. [*:20lgpb93]Reupholster the rear seats [*:20lgpb93]Panel work on all the minor dents / scrapes / rust patches [*:20lgpb93]Replace missing side trim [*:20lgpb93]Improve fuel system installation [*:20lgpb93]Improve audio installation [*:20lgpb93]Buff out all the scratches on the bootlid [*:20lgpb93]Install a 4 speed transmission [*:20lgpb93]Dynamat the interior [*:20lgpb93]Respray [*:20lgpb93]Replace shitty bushers with something better [*:20lgpb93]Repair/replace/relocate battery mount [*:20lgpb93]Make radiator shroud [*:20lgpb93]Done - Repair dodgy battery earth terminal [*:20lgpb93]Done - Install relay for highbeams (Installed HID High/lows) [*:20lgpb93]Done - Repair/replace buggered fender mirror [*:20lgpb93]Improve security on engine wiring [*:20lgpb93]Upgrade central locking [*:20lgpb93]Install alarm Hmm.. gonna be busy over winter. Better get another car running in the meantime.
  5. Hey Steve, when was the last time you ever posted anything actually helpful in a tech thread? Almost every one of your posts is shooting down other peoples ideas or suggestions, and making out that you are some fucking super guru of absolutely everything despite never contributing anything remotely useful, or even on topic for that matter. Running a speaker over its power rating heats the coil up nowhere near as much as putting a constant DC voltage into it, which is exactly what clipping is. Running a higher rated speaker on a lower rated amp means the amp cannot supply enough power to take full advantage of the speakers potenntial, so ya turn the volume up and woops, DC volts into the coil. Bang. Chuck a higher rated amp on and ya can run the speaker happily at full potential with no worry about clipping destroying it. Also, if you're such an idiot that you're gonna run a speaker way over it's capacity, then you deserve to destroy it. No idea how you could stand listening to it though as if the speaker is running over its physical power capacity it will be maxing out the cone throw and distorting like a motherfucker. Especially if you're not running any sort of crossover. I know this shit inside and out. A home amp system works a bit different from a car system. The input signal on a home amp is constant, and the output volume is controlled on the amp itself. On a car, the volume is controlled from the headunit so the input signal is variable. When the volume is turned up too high / gain set incorrectly the amp tries to recreate the waveform yet doesn't have enough output power to complete it, hence the clipping.
  6. 100% wrong.I've read it here before too....... forum BS. Probably started and contiuned by some salesman of speakers to keep the sales going. The speakers should always be rated higher than the amp. Otherwise the voice coils burn up at party time when it gets left at full volume. BTW you don't measure speakers with an ohm meter because the 4, 2 or 8 ohm is impedence which varies with frequency. The resistance is always less than the impedence. Steve. You're an idiot.
  7. The main destroyer of speakers is 'clipping' (when the amp can't supply enough power to complete the waveform, and ends up cutting the tops off), so it's actually better having an amp more powerful than the speakers. Also if ya have the crossovers set up right ya can generally pump more power into the speakers without a problem anyway. On an unrelated side note; I ran a 25W speaker on my 1000W RMS amp. It set on fire
  8. An amp (that isn't complete dirt crap) will give better audio quality than running on the headunits internal amp. Especially at the lower frequencies. Yeap ya can run both front and rear off the single rca output, but you won't be able to adjust the balance between front and rear from the headunit. Not that thats a real problem as the amp has individual gain adjustments anyway.
  9. I have heaps of spare cars. Road legal is a different story. I'll hopefully have something (avenger) wof'd by then though
  10. I'v heard a story where some guys temporarily fixed their fuel tank with some chewing gum after a rock punctured it. Could always try that with a cardboard plate ductaped over top.
  11. My rangi accelerator cable mount (made from an old boot lid) ECU So yeah, had an oil problem, the pump was leaking but that is now fixed. Car is complete. I epoxied the thermostat housing back together so it's all good as.
  12. My leaking oil pump begs to differ. Bearings are fine. Issue solved The oil feed pipe was leaking straight back into the sump. Didn't actually need to swap the pump, but figured that I might as well anyway since I was already there. Cheers guys!
  13. Didn't this motor have fine oil pressure untill you changed the oil and filter? Off comes the filter first (or perhaps I am missing something) I had also changed the pump. Oil and filter are the same as what was already in the engine. No idea what size the factory filter is. Just got the same that was already on it. I changed it to a spare ryco one I had lying around with the same results. It is still pumping the oil, it's just not pumping it as well as it should be. I have now modified the 5m pump to fit so will stick that back in if I can get the sump off.
  14. Gonna take it off right now. Just made a new pump out of the 4m and 5m one I had lying around. The 4m pickup wouldnt fit on the 5m pump due to the longer pump shaft, but the 4m shaft fit in the 5m pump housing. THe 5m pump gears are a good 1/3rd bigger than the 4m ones, so it probably has a bit more oil flow to it. This pump should be fucking sweet if the current one's the problem. I didn't take photos
  15. Never blew a head gasket. The head cracked due to the water galleries being blocked up and causing it to overheat. Not sure on how you could blame the oil pressure problem on me considering I've had the car running for a grand total of 2 days, 1 of which only drove to exhaust shop and back.
  16. 10-5 brought his gauge over, and it is reading a definite zilch. Off comes the sump.
  17. Gauge has the wrong thread so did not fit, but a spare sender I stuck on gives the same results... Just when I thought everything was sorted
  18. Last one was also a repco one. Ended up with a screwdriver in it Will try it though.
  19. I think it wants 10-40 but I went with 20-50. Has a repco jobbie filter. Maybe I'll chuck some flush through it and another new filter and see what happens. I don't know how the old owner treated the engine but it ran mint up till today. Seems a bit odd that it was fine yesterday (although that could just mean the oil was only a bit higher than the pressure sender... )
  20. Yeah its new filter and fresh oil.
  21. Yep will do once it cools down a bit and hopefully stops raining. No oil leaks that I know of and is still full
  22. Yeah did think that. Somewhere about the 200k mark. Thicker oil maybe? Not that keen on a cheap fix though / engine overhaul in a can
  23. So I was goin for a drive today, and the oil light started coming on at low rpm. This is kinda strange as it was completely fine yesterday. The engine is a 5mge with a 4m oil pressure sender, pickup and sump. Oil is brand new 20W50. As I said, it was mint yesterday and not so mint today. Not keen on running a bearing just after I get the car going again.. Throw me some ideas on what could be causing this. The pickup didn't look like it was worn out or anything Cheers
  24. Has anyone got a spare thermostat housing for a 5mge? I will pay good money / beer for one. Need it asap
  25. Have a gas mig, but it ain't working as good as it should. Regulator seems to be rooted. S'pose a mig set up for gasless is better than a gas mig with no gas. I'll see if I can get anything good from it, if not I'll PM ya. I only need it for a 5cm blat, if that.
