Roman
Posts posted by Roman
  1. The sump on these are a lot more complicated, because the cut line is up around the centerline of the crank, rather than having the block extend down past everything.
    So you'd definitely be modding one, rather than remaking one.
    But another thing is, with the motor being so small you could possibly just have the whole thing sitting up above crossmember anyway and would be sweet.
    It's hilarious to see how short that motor looks when sitting on top of that crossmember, haha.
  2. Yeah, just the difference from iron block to alloy I guess!
    This engine would be way lighter and more compact if it was designed from the start to be 2.5 litre.
    But, part of the reason it's good for this application is because its bodged down to 2500cc from a bigger design.
    It's also amazing how much you can win or lose based on accessories as well.
    Like some of the engine brackets on factory engines are absolutely massive cast iron things!
    • Like 4
  3. Hahaha its all good fun aye!
    I think part of the issue was just the way the article presented it.
    By which I mean, when I posted the trackday video first somewhere, it gets a really positive reception.
    Then people ask what's in it, and cant believe it.
    But then if you tell it by the numbers first, no one wants to watch a trackday video that validates the fact that it did indeed go quite good.
    Then another issue was that the article sort of made it sound like it was making 150hp at the engine.
    Which on an American or UK dyno means about 30whp.
    • Like 4
  4. I've already got one ball busting project thats proving difficult, I didnt need two. haha!
    If I was doing a K swap or 2ZZ swap, this car probably wouldnt even be going yet.
    But I learned so much from it during that short time span, it was awesome.
    • Like 8
  5. 13 hours ago, anglia4 said:
    This thread still occupies so much space in my brain. I find myself constantly adding Echo's and Vitz'z to my trademe watchlist...
    One thing that has definitely changed, is vitz peoples perceptions of C56 boxes.
    It used to be that if I didnt go grab one out of the car from pickapart, it would stay in there and be crushed with the car.
    The most recent manual vitz RS to land at pickapart, was not even off the forks and someone was there to grab the box. haha.
    Although, not so many coming through these days, think I was right on the tail end of the bulk of NCP13s lifecycle through pickapart.
    • Like 4
  6. 12 hours ago, 440bbm said:
    So what actually happened to this, all i've seen was all the shenanigans here and then it went BOOM and has it just dissapeared or just got parked for now somewhere for more funds/rainy days/carina finished?
    I parted it out, and no one wanted the shell so it got towed away by the wrecker.
    Done and dusted!
    Carina will be cool though
    maybe
    • Like 6
    • Thanks 1
  7. More displacement will just turn your drivetrain into a noodle by loading it up with low rpm torque.
    Maybe a little bigger cam, bit more boost will acheive same thing easier?
    There's so many headaches associated with engine machining work, that can often go wrong even if you get the best people involved.
    I reckon there's bound to be a sweet spot for you with factoryish block and the right bolt on stuff.
    Do you have any guesstimates for drag day time / MPH / etc?
    I think I'll be somewhere in the 14s on first shakedown and with standard cams. (assuming I make it)
    • Like 4
  8. Matching the pedal and throttle body doesnt matter, as they both communicate to the ECU completely separately.
    So find a pedal that best fits rather than what matches the motor.
    Some good options for e-throttle pedals from commonish cars.
    Prius/Aqua/etc has a pedal that's easy to get. RX8 pedal is a nice unit if it fits.
    The prius/350z/etc sensor is like a TPS with a little lever arm on it, so you might be able to weld something up to just adapt this to your factory pedal.
    Amazon.com: Throttle Accelerator Pedal Position Sensor 18919-5Y700  Compatible with Nissan 350Z Infiniti G35 FX35 FX45 3.5L 2003-2006 :  Automotive
    • Thanks 1
  9. A lot of the expensive looking aftermarket options that do the same thing as you're suggesting (Jenvey, EFI hardware etc)
    Look to just be a Bosch ethrottle unit with the guts put into a CNC'd housing.
    I think the chopped up factory throttle body is a good plan, might need to retain something to support the far end of the throttle shaft though.
    This is only 2 wire which would suggest it's just a regular DC motor but not sure how it would work in reality.
    Says 24 volt so not sure if it would work okay on a 12 system, guess so?
    Might work too slowly though, dunno.
    https://www.aliexpress.com/item/1005006106982472.html
    EDIT:
    This one might be good, good price too.
    https://www.aliexpress.com/item/1005007988405812.html
    • Thanks 1
  10. The bulldozer throttle setup wasnt suitable, I also bought a cheap cruise control cable unit.
    However I found that it housed a stepper motor not a DC motor, so too much of a pain to get it working.
    Would have been a nice solution if it was a regular DC motor.
    • Thanks 1
  11. E-throttle is just an H bridge controlling a DC motor...
    So you can literally use any DC motor that is within its torque and rpm range with the available juice (~14v and 2 amps or something like that?)
    A lot of the ethrottle setups have a lot of internal gearing to step down the motor speed by roughly 10:1 - 20:1 kinda range.
    I'd definitely not reccomend removing any of the springs from the throttle bodies though, probably wont pass wof/cert/etc, and it's also very dangerous if your motor fails and there's nothing to bring them to home position.
    • Like 5
    • Thanks 1
