Posts posted by 0R10N
I have some coin saved up for a BIG 'MURCAN TURCK but maybe I should just buy a 'tang instead.
Because theoretically, if I import, comply and then sell it for big bucks, I could still buy a BIG 'MURCAN TURCK.
<comicsans>Safe as houses!</comicsans>
Freshly imported from 'Murka, the untapped market for cheap good condition S1-3s as long as you don't mind left hook and two seater. Still wish I'd bought that GSL-SE I was pining a couple of years back.
http://www.trademe.co.nz/motors/used-cars/mazda/auction-1379264157.htm
- 6
Yeah, I wasn't going to look at the car again for another 9-12 months, but peer pressure (and a repair quote that came in well under what I initially thought) made me do it.
Engine builder recommended 1.1mm or thicker headgasket so will see what Toyota can supply.
The crank from the donor AE101 GZE was in better condition, so ended up using it, and the rods from that motor instead.
On 23/07/2017 at 16:04, Snoozin said:Set of 193b's sitting in my wardrobe doing nothing at all that would surely be lush.
Hmmmmm. Guessing these are N/A suited? Let me do some research and get back to you Richy.
@Firetruck I don't really want to go too extreme to be honest, keen on having a tidy looking car externally with a couple of small mods to give it more shove. I keep telling myself (maybe poorly judged) that if I wanted to build a foooooly siiiiick MR2 I should have started with a rusty high-km $3000 shell instead of a low-km tidy $12,000 one out of Japan, and then it would be ripe to chuck in a 7A-GTE and Link. As it stands, it still feels a bit sacrilegious going down the path I already have...
Because everyone likes laughing at my misfortune, let's have another look at those big-end bearings.
Yeah.
The crank was also scored seven ways from Sunday, and the machinists next door were reluctant to skim it, so now it's a big ole paperweight. These were the worst ones but pretty much every single journal was rooted.
We did work out the root cause of all this pain - the factory oil pump had eaten itself, apparently a common thing with the 1st gen motors. I never realized the 4A-GE also suffered from this weak point - it's a common thing to occur on the old Mazda B6Ts as well, although those tend to blow the relief valve and spring first.
Lots of deep scoring against the cover:
Take note of the area around the vivid mark:
In the meantime, things got busy... and my wallet got empty. We acquired a donor 4A-GZE bottom end (from an AE101 this time) and Karl attempted to make a good one out of two. The end result: my block, pistons and sump + donor crank and rods = this. He also sourced a brand new oil pump from Toyota and a couple of other bits and pieces. Head has been sent for a skim, as there was a 0.004" bow in the face (eek).
Toyota purists may note the AE101 4A-GZE rods are actually weaker than the preceding AW11/AE92 4A-GZE rods, but I was assured that for my application it wouldn't make a shred of difference. Different story if I was planning to go 7A and/or turbo I suppose.
The first photo below should answer the age-old question of whether 1st gen 4A-GZE (AW11) blocks were 7-rib or 3-rib.
Generic oil filter for the running in period.
Better get more than 100,000km out of this shiny new TGP pump!
Thanks to fellow oldschool member @Dell'orto I now have a SC12 from an AE101. They look very similar at first glance to the one that came off the AW11 but note the radius of each pulley face; AE101's is slightly smaller. If this translates into a slight boost increase, it won't be a bad thing I'm sure. When I next go back to the workshop I'll dig the verniers out and compare the inner diameter of each pulley, but I'm pretty confident they are different sizes, and the Toyota wizards on the internet also seem to indicate the same.
This clutch also arrived. Sadly, Toyota no longer stocks a genuine clutch kit for the AW11 SC
Next step is to speak to Mark at Toyota to see if I can find a suitable 1.1mm or thicker MLS head gasket before the engine can be fully reassembled. And do some more overtime in the mines to pay for all this faffing about.
Discuss the colossal fail here: //oldschool.co.nz/index.php?/topic/49412-80s-kid-part-ii-eds-aw11-sc-chit-chat/
Lancer Evos (I-III shape) are making their big comeback now. Just look at the numbers that are currently flooding Trademe.
I even saw a typical 'flatpeaker' and his boys driving around in one, except it was shiny and fully stock standard. Either they were on their way home having just picked it up from Buy Right Cars, or they'd finally come to the realisation that stock standard trumps shitty mods all day.
- 6
@xsspeed is dis us g?
You can brace yourself for all the people asking why the Fairlady has a RFB in it, and I can brace myself for all the people asking why the Skyline doesn't
Is it in Aussie? Talk to @Taistorm perhaps - think he is bringing over a wagon from WA.
Dereg papers and bill of lading will be useful, stuff that proves you are the owner of the car essentially.
If already damaged, the car will most likely be imported as such and flagged in the system and a certifier would inspect it before repairs can commence. I could give you the contact details of a friend in Hamilton who does border entry and compliance, he might be able to give you some advice.
A mate of mine just sold one recently after owning one for several years (Sean in Wellington - Al, I think you might know him). I originally picked it up in Auckland and stored it for a few weeks before he came to grab it.
They are quite economical, which is great for around town, but are a bit ungainly when cornering due to being taller than they are wide. Also the shittier the tyres, the more sledging that occurs. I remember experiencing a bad lockup coming down the Ngauranga gorge in the wet in his one.
It was auto as well which did take some of the fun factor out of driving it. But yeah, they have a responsive little 4 cylinder 1.3 turbo and a surprising amount of room inside, easy to park too which is good. They share a platform with a bunch of other Toyotas and Daihatsus so parts are cheap and plentiful and in the time he had it not much went wrong except for a bit of paint fade and an accessory belt needed to be replaced.
Get one!
...or if you can wait a few months while I try and source a windscreen for this blasted Alto you could eventually buy that instead. Lawl!
Yeah should be there. I'll pack me gumboots.
I bought some rare catalogues from Gavin/Myles recently. Had to fend off autobids from a well known foamer in the process.
Anyway, they invited me out to pick up the books and browse their collection of sweet 'tangs, will see if I can get some photos for the piners here.
Voted Stoddard. It might be busier but at least the cars will be somewhat in view and not tucked out of sight behind the building.
I believe BNT also has a scrap metal bin full of old brake rotors and discarded bellhousings that could be awarded to the pesky resident of Ellerslie for his efforts at chasing us away.
59 minutes ago, xsspeed said:
@0R10N hmm, I'll prob struggle this weekend then, doing waterview tunnel stz on sunday avo, I'm clear for next months C&C for sure though
Sounds good. I'll hopefully take the Skyline again, depends if it passes its WOF in between now and then.
Be prepared to get asked countless times "boe how much did ur twennydebt conversion cost?"
/nah it's not that sort of meet, lewl.
Oh it starts at 10 and goes until about midday, so maybe not
I'm going test driving of Fiestas and Focuses straight after C&C, how about a cruise/coffee in the afternoon instead?
Congrats BTW, must feel good man.
3 minutes ago, xsspeed said:
As per project thread it's road legal, have been going through my emails and text correspondence with compliance place, can't believe it took so long for what, after the panel work, was so little.
Anywho, made a cameo at auckland burgermeat on wednesday night, looking forward to a drive or few this weekend
Come to Caffeine and Classics on Sunday morning, I'm taking the Skyline.
43 minutes ago, Nominal said:
1600 for a 20+ year old Corona with 427,500km isn't all that cheap.
Offaz g?
/not my car so I don't set the price. Just demonstrating that for $1000-1500 there are options which aren't Mondeos.
...also, it's not $1600 anymore I've been advised.
11 hours ago, piazzanoob said:
so you should be selling all your other shit cars and just buy a
TOYOTA COROLLA
cheap
fuel efficient
basic
And low maintenance
Ant is selling that cheap as crusty crumbs Amon Corona (see Cars For Sale).
You should just buy that @MIRAGE-MAN
Skyline has been back on the road since January - but I don't take it out much.
Just about due for another WOF actually.
Yeah I'll take the Skyline over and have a nosey.
Probably won't be as jimmy jammed as the May event, that was more or less a flow on effect from holding the hotrod anniversary at the same place.
Malaysia again:
- 8
Ross McAlister is who I use but he currently has a gigantic backlog, so if you are in any great hurry you might want to consider the other Ross.
On 22/05/2017 at 10:01, HighLUX said:
1GGZE- what triggers the supercharger clutch to lock on. Theres a supercharger relay pin on the ecu. Is that triggering it via tps or similar or does it run off a switch on the accelerator pedal?
Pretty sure it works like a 4A-GZE one, the ECU triggers that relay based on intake manifold vacuum.
When vacuum drops below 8" the supercharger clutch is engaged. The clutch stays on until intake manifold vacuum has risen to over 10" for a period of 5 seconds. This time delay was added to avoid cycling of the clutch during shifts and momentary throttle transitions.
- 5
Ha I saw a bunch of those tangs heading south on Sunday morning. Figured they were on their way to Meremere or Hampton.
Speaking of rotary Luces...
https://page.auctions.yahoo.co.jp/jp/auction/s519208111
https://page.auctions.yahoo.co.jp/jp/auction/h264523413
Who's good at cutting windscreens out of cars at Pickys?
You could give my mate Craig a ring, VG. He's a compliance specialist.
Let me know, and I'll dig up the number and PM you.
Just like all of them he is notoriously bad at answering his phone though, lerl.
Rotary piner thread.
in General Car Chat
Craigslist is where all the old Japanese cars are, but it comes with all the usual caveats.
