Everything posted by yoeddynz
Sweeeet. It'll only be travelling over one property and hes one of a few who suggested a helicopter If you're brother has contacts and is keen to name drop any I should ring then please ask! No rush. Small matter of selling house truck, build mezzanine in shed, building new house first etc....
- 106 replies
- honda big red
- quad bike resto
- (and 2 more)
Or welding under a dash etc. When I'm welding something new, like different thicknesses or material or weld join type and everything is going well I write the settings etc down in a book I have near the welder. I'm still learning and it helps to gain an idea and memory for what works and what doesn't.
In the mean time when you get time you can just practice alt welding and be ready for the next project! Oh and get used to not using a foot pedal. Being able to alloy weld without having your foot on something opens up loads more jobs you can do and cuts down time too.
Yoeddynz's 1985 Hino N0915 housetruck build.
Hey @Roders here's the discussion thread for the housetruck. You asked ... " Is certification required when modifying a truck like this? Ltsa gave me an obscure answer to this question and vtnz said depending on the number of births, (not babies but beds) seat belts are required for the number of births. Surely there is more to this than that? " If you build onto the deck or what ever happens to be bolted to the chassis as a load, then no certification is needed. Its just a load. I was told by vtnz in Blenheim when we built a previous house truck that we could make the house out of balsa wood and cardboard or what ever...its just a load. Wouldn't be strong but... So long as the truck remains within the size constraints for heavy vehicles and any windows fitted are either toughened glass or have lexan (not perspex) covering the outside of them (shutters will do as well) then its all good. However- if you cut into the cab to create access into the house then things get more complicated. Firstly -You need a body cert for the modification to the cab. Then you'll need certified seatbelts and seat mountings in the back. You'll also need to cover the inside of any non- toughened glass window with lexan. My advice- dont go there unless you have to. Just leave the cab alone. You'll only need seatbelts for the amount of seats in the cab. Dont drive with people in the back. Obviously this is easy if its just two of you. If there's more then yeah... certified seat belts, and seat mountings, in the back will be needed. Its easy and I have done quite a few installs in vans, buses, trucks now. Just follow the rules. But it does get expensive! alex -
Just keep practicing. Make sure any and all oxide is off the areas you want to weld. Even alloy that's been cleaned off and then left to sit for a good time will re- oxide enough to need a clean again. Get a stainless wire brush and keep it for alloy only. When you've made a few tacks or welds and it's really hot give the area a good scrub with the brush. Really helps clean it up. If the wild is not critical and you're just practising and you get a little crap on the tungsten then just keep going. It burns off and will be fine. Seems to be only the case with alloy this as its not the same case with steel or stainless?Better than constantly stopping to swap it out. Oh and a really good helmet. Wow what a difference it made for me to see things more clearly. I spent the money and got one of these. If I look after it then itll last a very long time. Money well spent I thought. https://m.lincolnelectric.com/en-us/Equipment/welding-gear/Pages/product.aspx?product=K3034-3(LincolnElectric)
Yeah our neighbour around the corner has masses of fields (huge huge farm) and we could have the stuff sat ready to be lifted in an area only probably 1km or less from the drop off. No power lines of big trees to worry about. Couldnt be easier. Things like sheets of plywood and roofing iron would be the best thing to get lifted. Carrying plywood up a steep slope would get boring really quick me thinks.
- 106 replies
- honda big red
- quad bike resto
- (and 2 more)
I think the quad can only tow 250kg...on the flat. The track is pretty bloody steep. Lengths of the decking we have is about 5 or 6m. If done right with a helicopter or can be very cheap and easy. Another local over the big hill from us paid a pilot $500 cash for about 10min airtime pick up and drop off. Pilot was on his way home from another job. It saved him weeks of carting stuff. Everyone won. Plus helicopters!!!! I mean like.. Just wow.
- 106 replies
- honda big red
- quad bike resto
- (and 2 more)
yeah actually thats sort of the thing I was thinking. A simple dolly with a long tow bar. Hannah could walk behind and steer dolly. Then can be swapped for short bar and used as a normal small quad trailer. make it tipping for carting gravel etc. Hell- anything will be better then carrying stuff. weve recently built two more wood sheds. the top one was a day of 1000 meters of climbing overall carrying timber and iron up. Great for keeping shape but tiring! Have decided that shifting the materials for the cabin build will involve helicopter!!!
- 106 replies
- honda big red
- quad bike resto
- (and 2 more)
Quick update to say that this old beasty is still going strong and earning every cent of its $300-400 price Its never ran completely right fueling wise but everything seemed in order in the two times I stripped the carb. It would just simply lean out if I tried to give it too much throttle. The needle height was correct too. In the end I thought bugger it- I'll get a carb kit just in case I've missed something. $30 later and wow!!!! I wish I had fitted a kit ages ago. Sooooo much better. The only thing I can guess at was that a previous owner has fitted a kit with the wrong needle taper. Anyway.. now its a rocket ship. Apparently they are geared for 80kph? Well yeah it would easily pull up to that but damned if I'd want to be on it at that speed. However its way better at climbing up to the ridge. Damn its a handy thing. Loving it. Lawn mowing and tree planting on the ridge...easy. Next to do job is build a tiny trailer, about a meter wide. Sort of a trailing dolly type thing as I have a new plan on how to tow up all the decking and other timber for the cabin. Back flips here we come.....
- 106 replies
- 7
- honda big red
- quad bike resto
- (and 2 more)
Its pretty modified. I think they even ran a drive shaft through the V to get the engine as low as possible!?
Its gonna sound so sweet with those ITBs!!! Pic for inspiration. Mondeo touring car with Mazda V6 (albeit quite modified...)
Yoeddynzs 1965 Hillman imp 911 build. Flat six in....
yoeddynz replied to yoeddynz's topic in Projects and Build Ups
Wow! Its been a while since I've updated this thread. Work on this wee car pretty much ground to a halt after the last update. I got busy with other peoples cars for work and then took off to the UK for a holiday. 4 weeks of sunshine and loads of cycling. Nothing to do with cars at all. The one car that I spotted whilst there and liked was this absolute gem... Drool. Anyway. Got back to NZ and spent the next few weeks dealing to property jobs and more customer jobs. Finally last week I pulled the Imp out from its spot and finished off the panel work in the back. Now there's something we have to go back in time to jog memories. Normally in order to jump time I would just jump into my trusty police phone box as seen here in the Viva thread.... But I have had ongoing issues with that mode of transport. Things like oil leaks from aged seals and fading paint to name a few. So I sold it on at the end of summer to some fella called William who I met at the local market. Strange bloke. Not seen him since. With that machine gone I realised I had a desire to build another. Maybe a Delorian? Nup- prices had gone up beyond what I could afford at the time... so I based my new creation on one of Britains finest machines made. So now folks I shall introduce you to the Princlorian... With my new creation I was able to travel back in time to show you all a period in my Imp resto that I regret wasting time on. So in the beige wonder we shall travel through Hillman Imp time.... Whoops. That's too far. Hang on, try again... Oh dear. Must be the electrics. The fella at the motorist discount centre told me it was a 'new old stock' Lucas flux capacitor! Try again.... Ennnnggggrrrrrr!!!! I flicked the wrong rocker switch. Sorry. Hang on.. Righto this is annoying. But I think I've worked it out. Here we go... FINALLY!!!! Right. So way back when I first got the replacement shell I spent a long long time doing this... To this... I now wish I didn't. Instead I should have just chopped it out. Which is what I did in the end and had mentioned it in one of my last posts. Well with it all gone my next job was to rebuild it all. This is what I did last week. Imp back in its work spot with customers cars waiting... Working on building up ones shelf.... (terrible) To suit the fiberglass engine cover that came with the race car.. Fill in the blanks.. With that finished I rebuilt the rotten gutter above the bay.. Hannah has painted the lot in epoxy primer and I started on the front end which had been bent at some point when the shell was moved- probably a lifting strop or something I guess. I was originally thinking I'd have to cut it out and let in a straight front panel but actually after about an hour with lengths of wood, a jack, hammers of various sizes and many different shaped bits of steel Hannah and I managed to straighten it out fine. Very happy with result. Before... After... Now I need to remove the rot from the front of the bonnet. I carefully hammered out a small dent. Hannah laughed. It could have ended up like this scene... https://www.youtube.com/watch?v=1IL22sLF25s Then I can modify the front end to take the radiator. I must crack on because summer is coming quickly and there's so many other jobs we want to do here ! Planning on selling the housetruck this summer and building a new house trailer so that is one huge amount of time that I'll need to find. Please keep tempting me with racey little Imp photos and encouraging chit chat here... https://oldschool.co.nz/index.php?/topic/58205-discuss-here-about-yoeddynzs-little-imp-project/& Alex- 101 replies
- 28
I'm planning on going down there with a friend from Nelson who has an old Indian bike (I'm building a rack for it right now) I'm guessing there's lots of bike stuff too? But as such it will be up to him as to which day we head out- hopefully the Saturday to see displays and catch up with OS folk. However Mr Bling.... does Friday have a better selection or something?
Cool. I shall start dreaming of crazed old British taillights for some car I don't have but at a price I just can't refuse. Hopefully I'll find a stash of old English car magazines with lots of subtle black and white porn photos of chicks advertising ciggys or badly manufactured DIY rear screen dismisters and bolt on headrests.
Is there going to be a crew heading to the swap meet at McLeans? I'm hoping to make it down, drop off lathe, pick up other lathe and then go collect shit I don't need. It would be jolly nice to catch up with any chch peeps and have a cup of tea whilst discussing the finer points of some manky old obscure truck grill etc
Yeah I did that with some other dirty castings. Got boring real quick. But if its something that has to be welded then it just has to be done.
Yeah I have had a good look into them. Problem is the bolts holes and plug holes dont match at all. i originally thought I could cut one down to the flange, mill it flat. then repeat on the top from the other side. stick the two halves together and weld them. But plug holes would need moving too. Its a fair amount of work. Certainly nothing I'll be doing for a long time with all the other projects to do.....
Cool- you have clearance!!! I reckon silver top itbs would be a good match too. No injectors hole to plug and neat flanges to use. Given your impressive steel tig skills so far I reckon you'd be fine at having a go on Alloy. I jumped in at the deep end and my first proper go at alloy tig was my manifold. I just did a little practice first. I'd avoid trying to muck with the cam covers- I welded up a few holes on mine and they are pretty dirty casts- not so nice to weld really. Especially considering they are used. Mine were cleaned out but still had crap almost soaked into the alloy it seemed. In saying all this I still want to modify some covers for the next build- it has always bugged me that they dont match.
Could you do them like this but angled backwards? Although I think you have the same issue on clearance at the front end of the engine that I had with the Viva install. My bonnet was just a bit too close to get away with itbs sitting over top of the cam covers.
He is a Californian after all. Yeah so it was a chilled out day inhaing nature and talking about mad car projects and fluffy cats....
In my quest to work out what I could get away with I have weighed everything to do with the V6. With everything on a standard engine with flywheel, clutch, alternator, excluding the exhaust manifolds and inlet manifold but including the cut down inlet flanges with injectors attached it weighs in at 135kg. The manifold I made was pretty light, maybe 5kg. The single mazda TB is 415 grams. Steel fabricated exhaust manifolds wont weigh much.
He broke my handbrake cable.. but we did get lunch, dinner and joints supplied Plus it was a fun interesting day.
Oh I know- if it wasnt for the extra weight, which is fuck all really, I'd be slinging my spare KLZE into the wagon and not a Duratec. I just know that the four pot will never sound as lush as the V6 nor will it ever have the same mid range grunt. But time for change and I want to save my v6 for a future mid engine lmp style build (way way way in the future...) So I shall just sit back and live the V6 dream by watching you and that "a bit slack right now eh..." @Transom do your builds
You'll be soooooooooo happy when you first hear that V6 wailing past 6000. It will all be worth it- trust me Such sweet engines!
Yeah sweet- I'll have a think about what I might need. I do need an indicator LF lens because I foolishly dropped a lump of timber near my wagon the other day and took it out. hopefully getting one from @nzvohc though:-) Work on my wagon is on hold until the Imp is finished.
