Everything posted by oldrx
Ok cheers. Do you think this iron will do the job?
I took another photo using my kids magnifying glass lol may be of some help not sure. Damn this drag and drop funtion on OS is awesome!
Yeah im not sure its been designed that awesome. Its a small company with no aftermarket support. It is connecting to the gauge side pretty certain. U2 has a symbol like a rugby ball with two parallel lines angled through it, then 7550-1, then i think maybe a #
Got it cleaned up a bit, so its labelled Q1 on the board but the part marking on the component is melted off. However Q2 below that is the same size im guessing is probably the same component - it has printed on it 2306A. Could be one of these? which according to that website is this from element14 - datasheet
Thanks man, I will clean and report back. I dont have any data on it but will have a hunt on the net and maybe try the manufacturer on the off chance. If I put a pic of a fried board on their facebook page it might elicit a helpful response!
Cheers, I'm guessing the hard bit would be identifying what the damaged component actually is
Below is the circuit board from my Podi oil pressure gauge. I managed to fry it as you can see and the manufacturer wont reply to my many requests for quote on a new board. I assume its a goner but not knowing anything about tiny black rectangles that somehow know things thought I would check if anyone can enlighten me? I think it was my fault trying to run it off a double relay that feeds the fuel pump also, too many on/off cycles in quick succession when i was trying to fill float bowl and turn off before it overfilled (too much fuel pump).
Found some atf and o rings were a size in my kit so it lives again
Will have a hunt in the shed for some ATF, dont have $18 this wk and am trying to tighten up on bullshit spending
Just replaced some seals in my floor jack need to re-fill with hyd oil, I get the feeling the 'jack oil' you can get from s.cheap etc for like $18/l is probably re-labelled something. Is there a cheap alternative?
Vibrant performance brand from Jegs.com
More of a negative pressure wave (from my limited understanding), being negative it travels towards the engine but draws exhaust gas out of the chamber aiding scavenging
The Honda K20/24 swap into MX5 guys are talking up the BMW E36/46 manual transmission, are they that good and why dont other swaps use this trans?
I use mouse milk, great stuff, waaaay thinner than CRC, smells like solvent
Where to buy ball joint boot retainer things? Got a new pitman boot (Mazda still supply!) Didnt come with the retainer things that hold it into its groove, can you buy these seperately? I did google but may not have the right term
Will report back, Mazda say they went NLA last year DOH, snaffle up good 12a shafts when you see them /future classic
Might look into hard chrome
Could do, but imagine the rotor journals (rotor bearing opposing surface) severly rusted
Repair sleeves for 12A crank shaft/eccentric shaft - possible to be a thing?
Yeah i gotcha thanks man, I will front mount it with rx3 X member i think this is going to be the easiest way. There is a kinda bulge in the casting where the twin dizzy stud would have prev been but means engine out to drill/tap and still probably inferior to front mount.
Plan B is a custom eng mount and front mount it, kinda like this or RX3 type that also bolts under sway bar but uses breast plate, below may be too rigid;
Will an eng mount to just one M12 stud pass cert? As per the drivers side on below pic, i will remake the bracket from some folded 10mm plate or some such as existing one is a welded POS, but will still rely on one stud.
Anodised - interesting, would last longer i guess, might be able to get a deal through work
Ok stupid question time, can I paint my radiator or get it done nice somewhere? Been looking at the below build thread and thinking how much nicer the black rad looks in an OS bay. Mins is a big (factory + 50%) aluminium unit. Cant imagine any insulation effect from the paint would affect it much. http://www.ausrotary.com/viewtopic.php?f=21&t=247235
