rxtoy
Everything posted by rxtoy
  1. Merry Xmas Corona!!! had most parts in stock, there was nothing listed for the ball joint, i grabbed an ST184 one but it won't work. also still in need of a rear strut but i've got the bent one out now so i'm going to take it for a drive and compare it to a pair of ST204 ones that are for sale on gumtree. also got the rear wheel bearing out, just need to wait until monday to use the press at work. CV's were a bit of a prick, but mainly because i haven't done any inners for ages so pissed around a bit and did it the long way. getting the passenger side one out of the gearbox was driving me mental until i googled it and someone mentioned using a slide hammer, which reminded me that the g/f's dad had one in the shed. bent strut housing the joys of spending half the day under a car which is covered in CV grease and engine oil leaks thinking along the lines of these for wheels, i think they'll suit and they're only $300 brand new. add $400 odd for tires and the whole car is still going to come in at around $2K which i'm pretty happy with while i was under there i found the rear engine mount was fucked so i'll pick one of those up early next week and she should be ready to go by wednesday the way things are going. fingers crossed!!! cheers Matt
  2. So I just bought a new daily, it was ultra cheap and it's got rego (no wof required in WA so it's legal) plus the coldest air con I've ever come across but it's taken a bit of a hammering driveline and suspension wise. Jacked up all 4 corners to check things out and came up with 3 fucked cv joints 1 rear wheel bearing 1 front lower ball joint proper scary that I drove on it fucked 1 bent rear strut A couple of oil leaks Some panel damage Jacking points are all rough as fuck Wheels are all pretty rough So I'm going parts shopping in the morning but considering these are import only in Aussie I may have issues. I'm thinking about just grabbing a 3sge 5 speed ST184 and swapping brakes, hubs, driveline over. Anyone know how compatible they are? Pics
  3. Drop spindles aren't meant to fit this model, there are minor differences between these and the next ones. Apparently. Could be worth a try but both Belltech and Chassistech are listed for 84-95 models (which is when they switched to Tacoma but spindles should fit up to 04 hilux) Looks awesome already though, I'd be stoked to be dailying that. Looking for something similar at the moment. Cheers Matt
  4. Dude, this is fucking epic. Was not expecting such a sweet build when I clicked your thread. I kept on showing/annoying the gf things. Apparently she doesn't care about parallel 4 links with watts links. Weird. Love your work Matt
  5. Finally got the sump sorted, scored a standard 22R hilux one for free, then realised that no way was it going to work. Spent a few hours on the interwebs trying to find pics and definite answers, best I could get was '20/21/22R sump bolt patterns should all be the same' and a crappy pic of a RA60 Celica sump that looked like the bulge was at the front. I spent a week trying to find someone that would sell me a sump without a motor, eventually found a guy over east who was happy to take one off and send it, although he ended up taking over a month to get organised. So it arrives, and it looks perfect! Pulled old sump off and side by side compared them and decided that it would be perfect. Fitted new sump, with new cork gasket, and lowered the engine back onto its mounts. Ahhhhhh!!!!! It touchs the front crossmember!!! Only just though, and a minor hammer adjustment gives me enough clearance. Before: After: Can get it out of the garage now with only minor scraping, before it needed bricks or it got stuck. Now just need to sort an exhaust and she's good for summer cruising. Pulled her out of the garage to give it a clean and got a couple more pics in better light. Cheers Matt
  6. I saw a KA24 D21 at Tauranga pick a part a few years back so there's definitely some in the country. Cool wagon. Cheers Matt.
  7. so while i'm super happy with the 14/s and low profile tyres its created a few extra problems. the guys i bought the car off never planned for it to go low, let alone this low, so when they needed to notch the sump to clear the drag link on the steering they put a massive box on the front to gain oil capacity back. this is now touching the ground, on a flat surface. hmmmmm might need to do something about that so i'm pretty sure that its a hilux sump they modified, just trying to find info on whether the other 20/21/22R sumps will be better suited to this setup, then i can buy another sump and actually be able to get the car out of the driveway again. the exhaust is also a problem, i've got no idea where the extractors run from factory but after a good look underneath the only spot i can see for the exhaust to cross to the outside of the chassis is right behind the steering before the chassis kicks down. this will involve a bit of work because my extractors are still 2 bits of pipe at this point (4-2-1), and its not exactly the biggest gap to go through once things start moving around with the car running. so the previous system just went under the chassis which is way to low for the way its setup now. i've cut off the low hanging bits so i can drive it (once sump is sorted) but its pretty much tractor like so i'll need to get onto an exhaust system pretty quick. it needs to go through this cutout in the rear, which is what it did from factory. and out in the sun, its hard to get good pics in the driveway, need to hurry up and find a sump so i can drive the bitch somewhere!!! cheers Matt
  8. finally managed to sort out the fucked wheel nuts, been distracted with doing a clutch on the gf's daily (AE92 corolla with a blacktop 20V), fuck i hate working on fwd's. also chipping away at a few things on the GT4 getting it ready to sell. anyway, managed to get a couple of the wheel nuts stuck on, tried hammering on smaller sockets which is when i fucked up my thumb. so i went with drilling down the centre of the studs with a pilot drill, then going up to a 12.5mm drill. well, the pilot drill went sweet, but the bigger drill crept off to the side. fuck. so i thought about it for a couple of days, then i made up a steel spacer which just fit inside the wheel nut holes, and drilled out the centre to 12.5 so it'd keep it in the middle. then just drilled really lightly until it pulled the drill bit back to centre, then eventually through the fucked wheel nuts, and hooray, the wheel is off!!! happiest i've ever been to have a pair of fucked nuts in my hand!!! more tomorrow cheers Matt
  9. no progress, just got a few decent shots of it today while we had the gf's RA28 out to try and sort out a noisy belt. loving the wheels now they're on!!! yeah, i'm an ass man with another one of the toys, 1989 ST185 JDM GT4 cheers Matt
  10. i'd love to park it up next to a long nose one, just so i could see the actual difference. can't be much in it. don't know of any other 40 series on the road in WA though. a mates brother has got a project MS45, maybe if that ever sees the road we can compare. cheers Matt
  11. Weekend progress was hampered by splitting my thumb open with a hammer. Ouch. Better side shot 18RG picked up Still haven't got fucked wheelnuts off. Might have to pull hub off and drill studs. Cheers Matt
  12. oh hell yes! so much better driving fun without that sitting in the corner of my eye frowning back at me
  13. discussion thread: //oldschool.co.nz/index.php?/topic/44401-rxtoys-1965-toyota-crown-rs41-deluxe/
  14. sooooooo………………… opinions, jealousy, advice, all welcome cheers Matt
  15. so my tires arrived on thursday and i went and got them fitted today, 165/50R14's, they look tiny!!! pretty much the exact look i wanted, just going to have to put sorting out my exhaust a lot higher on the list because its pretty much on the ground now. tires on wheels and fitted, worst pics ever, i know. need some sunlight which is going to have to wait until tomorrow. oh, i also bought an 18RG. it was meant to have twin carbs, but the carbs ended up being owned by the brother of the engine owner, and he ended up deciding he didn't want to sell. its got brand new extractors though which is a big plus, and i'm doing some investigation into aftermarket quads to suit the 18rg, and a computer/fuel system to run it. pics of motor can wait until tomorrow too, its a fresh rebuild but was built years back and has been sitting around since then.
  16. so i randomly came across a set of MS51 Crown coupe wheels, apparently they're the same as MS75 ones, but either way they're pretty hard to come by. i found them at a mag shop that was closing down, he had no idea what they were, scored them for $50 polished all the rust off and decided to try something different colour wise went to Canada somewhere around here for 6 months so everything went on hold and the Crown went into storage, i ended up with these wheels with a shit set of tires on my MS55, which ended up selling while i was overseas. sold them without the wheels, but they came back with a few scratches which is annoying. i bought some tires for them, but because i went for low profile skinny 14's i had to wait for them to be brought into the state, so i did a quick fuckaround job to fit a mates set of 16x8 watanabes, had to throw some bolt on 15mm spacers on the front to get them over the upper ball joint, then cut all the studs to suit the spacers, plus they're nissan thread which left me a bit lost for wheel nuts late saturday while i was finishing up, with the car meet i wanted to get it to on sunday morning. ended up just using the skinny nuts that came with the adapters. mistake, two of the fucking things are jammed on, and rounded off. pics of it on wats, at car meet i took it along to. it was Custom Cars n Coffee, a monthly meet in Perth. there were about 1000 cars there this month. very cool meet, nothing like it in NZ. every sort/style of car, from gemini's to corona's to lambo's, corvettes, aussie and yank muscle, civic's, vw's, everything!!! there was even another crown.
  17. eventually i got sick of the bonnet scoop, so i got a panel/paint guy i know to sort it out. it was meant to be ready for a combined photoshoot me and the gf were getting for our cars, long story short it ended up with a matt black bonnet for a couple of months and the guy who did it charged me a decent amount over what he quoted. have to admit he did a great job though. i actually liked it with the matt black bonnet, was definitely not the end result i was looking for though so much cleaner without the crappy bonnet scoop!!! gf's RA28 in the background, those who toyota together???
  18. so i picked this thing up about a year and a half ago, i had noticed it at Toyotas in the park (local Perth car show) in 2011 and got to know the owner, when he decided to sell he sent me a message and as i had just sold my hilux in NZ i had the spare cash and i snapped it up. i already had a MS55 that i was chipping away at getting ready for rego but with crowns for me, the earlier the better, and this is a pre facelift deluxe, pretty much my perfect crown. although i'd kill for a wagon or a ute to park next to it. pre facelift in the 2nd gen crowns means you get the round taillights but the engine bay/wheelbase is shorter, they extended it to fit a 6 in in 1966. which sort of leaves engine bay room a little bit tight. when i first saw this thing it had a supercharged 18RG in it, but the previous owners cooked it and swapped in a 22R for reliability, along with a 350 holley to keep things a little cool under the hood. it was sitting pretty high in front, and there were a few rushed bits, and the exhaust had been run under the chassis, instead of through cutouts like it had from standard, because they wanted to run 2.5" and it wouldn't fit. it was on generic 5 spoke 17x8's with high ish profile tires it also had a hole in the bonnet, with a crappy old falcon replica scoop over it which made me very sad. still it was a great price and its not the sort of car you come across every day. or at all. this is it alongside my MS55 at TITP a couple of months before i bought it so the first thing i did after i bought it was to chop the front springs, not to low because the plan was to drop it on the 15x7's with 205/45/15's i had on the MS55. offset on those things says no however, they're 0 all round and the crown is happy to swallow 8" wheels, but only if they're fwd offset. so it sat on the 17's for quite a bit longer than planned. after the front springs got the makita treatment then i ended up tidying a few things in the engine bay to get her a bit more reliable, and just driving it whenever i got the chance. cheers Matt
  19. I've always wanted a matching pair/different body type of vehicles. So mega awesome!!! Need garage door open taillight pic. Cheers Matt
  20. Not when you've already shortened/made custom upper and lower control arms and tie rods, plus if they get to short you lose all suspension travel and room for airbags. Narrowing chassis rails is another option but would be a major in a unibody car and you'd run into all sorts of bump steer issues Cheers Matt
  21. I know what you mean, I've got the same setup in my Stout. Good setup for diff articulation. With having only front and back control are you still running supply and bleed valves to each airbag? 8 valves rather than 4? Look forward to pics, I love a nice airbag setup. People don't realise how much custom work is involved. Cheers Matt
  22. Too hard basket then. Hmmmmm going to be fun finding a buyer with my offsets. Some awesome fab there, loving the control arms. Watts link setup in the rear or triangulated 4 link?
  23. I like this a lot!!! What stud pattern/offset you running? Pretty sure my Boyd Coddingtons Magneato's will be up for sale soon, 20x8 +32 & 20x10 0 in 5x114.3 Could be easier than rehooping yours. Also who's doing the fab work? Cheers Matt
  24. I like the 2 tone, big fan of this car!!!
  25. Love your work!!! I've been through a TA23 and a RA28 myself over the years. Actually fitted a set of flat lights to the 23 so there are some in the country. Hole spacing is different from memory, but not to much. I remember having to slot holes, and obviously the centre garnishes mounting holes are heaps different. Cheers Matt
