240KGT
Everything posted by 240KGT
  1. 240KGT
    Vibrating car
    easy way to check get a jack and a block of wood and SLOWLEY jack the motor up a WEE bit then start motor noise all but gone problem solved it will still make some noise while sitting on jack oh and by the way DONT sit in the car while car on jack will defently feck ya mounts
  2. 240KGT
    Vibrating car
    mmmmmmmmmmm the plot thickens ok what about engine mounts is the motor sitting on the sump
  3. 240KGT
    Vibrating car
    hope the new one was balanced. at what speed it start doing the shake could be many things as in gearbox mount could be fecked flywheel loose the list is endless start at the front of car and anything you had apart or replaced check out but its normaly the driveshaft that will do it just because its new it can still go outa balance real quick ie the balance weight can fall off
  4. put car into 4th gear and with foot on brake pedal slowley let out clutch and hey presto no running on
  5. 240KGT
    Escort probs
    NEWS FLASH !!!!!!!!!!!!! the fucking thing will now run on about 3 and then die I tell ya its gunna die soon by B F H shortly am going to buy fresh plugs and some av gas and give it a try
  6. 240KGT
    Escort probs
    mus be an escort disorder as my escort has the same problem has good spark and fuel but you think for one minute it will fire not a shit show and im getting mighty pissed about it
  7. click on this link (if i get it right) and have a good read it will help you out im sure http://www.powerpage.dk/just_karb/dellorto.htm Cheers Adrian
  8. yep gotta set on my mk 1 escort ask away what do you need to know can supply photos if ya need em
  9. black earth, red power on key, green postive coil, white light switch depending on brand of rev counter
  10. 240KGT
    dellorto help
    na sorry its not blue try bright yellow been round for a while will get it running right then the big rebuild
  11. 240KGT
    dellorto help
    Hi folks another newbie here needing help I have a mk1 escort 2 dr bubble flares 8inch mini lites 2000cc twin carbs and the twin carbs are not playing fair the gas pumps in them dont work and im thinking something is missing any one have a picture of the underside of a 45 side drft carb or a link to a site with pictures thanks in advance Adrian
