peteretep
Everything posted by peteretep
  1. peteretep
    1600 and 5spd
    aww i wanna put the pinto box on but i already have a skimmed flywheel and i dont really wanna get another one skimmed
  2. peteretep
    1600 and 5spd
    most mk1 escorts came with 1 piece driveshafts i think, my car is 1 piece
  3. peteretep
    1600 and 5spd
    hey, if i was just gonna use a pinto 4speed gearbox on my 1600 xflow could i just change over the clutch plate because my flywheel has already had some weight loss so i want to keep it
  4. peteretep
    1600 and 5spd
    so do you reckon you could just change over the clutch plate?? btw the standard escort(type 2) one is 7/8 x 20 and the type E and type 9 one is 1 inchx23
  5. lol i wonder where it would actually be used
  6. peteretep
    1600 and 5spd
    http://www.mcs.vuw.ac.nz/~kris/escort/gearbox.shtml whats needed to put a 4speed from a pinto onto a 1600 too??
  7. damn 7psi is alot isnt it? i suppose your cars a drag car though, in the burton catalogue it says that I should need no more than 4psi. I was looking at maybe getting a facet silver top pump which is 4.0-4.5psi
  8. actually dvlrcr it would be the opposite of what you said. Normally it would changeat 2.5 but with overdrive it would hold in gear longer so it would change at 4
  9. are your sure its not a 1600 one? could just be a standard 1600sport carb
  10. peteretep
    uuuuummmmm
    lol and it only took 8 replies to figure that out
  11. fuel pump? well i just got a done up 1600, do you think a standard fuel pump will pump enough or do you reckon i should get an uprated one. The guy who i bought it off was running an uprated one so the hole where the standard pump goes has a plate covering it
  12. yea i need to replace those too but hopefully it will last until i get an electronic ignition
  13. well i found my vacuum advance almost isnt working at all so that explains alot
  14. peteretep
    fuel pumps
    what fuel pumps do you guys use?? standard or performance, also does anyone use a fuel regulator? im thinking of using an uprated pump on my 1600 xflow
  15. i think it would be very hard to properly flare a 4dr, the back door is so close to the rear arch that it would hard to put gaurds on, even those bolt on ones would be very hard
  16. yea i think its nothing allowed on the front, 35% driver and front passenger windows and rear window, and you can pretty much blank out everything else
  17. i used davies and naylor on church street, 150 for the car and they cut the backs ones by 10mm and rolled the front gaurds
  18. peteretep
    Welder
    if you mig it you'll just need to hold it somewhere where it wont be able to warp
  19. peteretep
    Welder
    whats wrong with using an angle grinder it would do the trick wouldnt it, then tig weld it or something
  20. peteretep
    2.8v6 105e
    oh yeah but finding that engine would be slightly(understatement) hard...
  21. peteretep
    2.8v6 105e
    yea i dont think there was any 2.6's but a 2.3v6 from a cortina wouldnt be too hard to find but all 70-80 ford v6's arent very tuneable and performance parts are hard to find unless you find a cosworth 2.8 v6 but very doubtful in nz. also, v6's are pretty heavy
  22. nah i dont have a 2l carb and ive had a little play around with the carb but that seems to be working fine, of course my car still doesnt like idling when its cold but otherwise seems ok
  23. i have a standard 1300 engine but when the engine is cold and you put on the gas it has a distinctive clicking sound and it almost stalls the engine(very rarely it does), my boss told me that it may be a broken distributor or sometihng like that. sometimes all you just have to tap the gas and it does it but other times you just have to accelerate really slowly to avoid it. also when i put the pedal to the metal all the car does it sound drowned before slowly accelerating again, im not sure what this is...this occurs even when the engine is warm. thanks
  24. that looks like a nice amount of stretch combined with deep dishness...as well as being an insanely nice car. theres more at http://www.volny.cz/capri/Main/uk.htm
  25. peteretep
    Twin pipes
    did u guys see that 5 door rav4 for sale on trademe a while ago where the owner said it beat some targa cars around manfield or something like that with heaps of trd rubbish on it, pretty random car to turn intoa race car...
