Everything posted by Alistair
Error 404 traction not found
Ughhh im super on the fence. No wipers in the rain is not fun
Good to go for this!
BRAPYEAH BRING TO BURGERS PLS
Do you mean gauge or sender? There is no sender in the tank, needs to be cut into it and fitted. The fuel gauge is stock KE20.
How would I find out what Ohms range my fuel gauge has? Setup a potentiometer with volts gauge, set it to an arbitrary figure like 90 Ohms full, then connect to 12v with the potentiometer on the gauge and see where the needle reads at? Need to fit a sender to my fuel cell but they seem to have different Ohm amounts. If the stock ke20 gauge is different to what is available in the senders am I stuck with having to buy an aftermarket fuel gauge with the matching ohms?
Also been a while whats the go with stickers?
Gedderdivit. No work trips planned for the month so I'm good!
This on for 23rd this month? Been a while since my attendance but keen for burgers and boes!
Haha yeah might have to wait for the mrs to recover from me buying the car before I start doing that!
Tubbed & 9" m8?
Just has a W55 in there at the moment.
Also, wow @ Toyota Tax on W series gearboxes now. If anyone comes across a decent priced W57 I'd be interested.
Yeah, could be worse wheels, least they're Works and not Rotas/TBC/Linglongs
Need to double check but I think they're 315mm.
Miso solly. Was always going to be pushing it but work and gearbox being gay really put the nail in the coffin for that. Ah well plenty more events to come!
Something 15x8 rear, 15x7 frontwould be ideal Neil but yeah at the moment issue would be finding something to clear the FD's bulbous calipers. Can't go too overboard at the moment with changing things as the mrs will have a hernia but it's on the cards.
Basically all I have done so far is change out the diff fluid for some new LSX90, put some Redline HD Shockproof oil in the box as it was a bit noisy (this helped heaps) and oil change. I need to get a fuel sender for the Jaz cell as I currently have no idea how much I have in there and need to mount the wiper motor on the passenger side (normally up under the pedal box) so I can drive and see when raining! I have raised the front coilovers slightly as the roadtrip back from Whakatane was harsh as balls on the front as it kept bottoming out. Need to check level and see if the back needs to come up to suit. Wheels are quite big, main issue with changing wheels are the FD3s front brakes as the calipers are huge on them. Other than that, enjoy, do drags, track and cruise the hell out of it!
Here goes! Ever since I sold the RT40 I have had a yearning for another high powered old Toyota. Two years of grinding away at renovating a shitty house and I finally have the time & money to enjoy an OS car again. Priorities changed somewhat however and the idea of starting a project like that from the beginning after this house renovation scared me and my bank balance. So after some arm twisting and dinner cooking for the mrs it was decided to go and search for something "finished". This little car was mentioned to me by some Oldschoolers and I had followed the build thread of it over on Toyspeed since it's inception. I guess I'll start with some specifications from the previous owner (because I'm lazy) and pictures from today after I had given it a wash, machine polish & wax to a level I was happy with! Discussion Fred Engine: Model: 7A-GTE Block Internal Spec: Factory crank shaft, Forged ross racing pistons and top seal rings, H-beam rods, ARP bolts throughout, toga race bearings and oil pump Cylinder Head Spec: Rebuilt Factory 4a-ge 20v blacktop vvti head with Supertech Valve springs and TRD steel headgasket and ARP headstuds Intake system: Factory 4a-ge 20v Blacktop ITB’s and MRP 2-peice plenum with 3” intake Turbo system: New Holset turbo supplied by steve murch, x2 Tial 38mm MVS wastegates, MAXfab custom thickwall stainless steel manifold, HKS ssqv bov, Fuel System: 60L Jazz fuel cell, carter lift pump, surgetank, bosch 044 fuel pump, full braided Teflon lines through to 800cc SARD injectors, turbosmart FPR-800 regulator Ignition System: x4 1nz individual coils mounted to a CNC’d made-to-suit aluminium adaptor plate Exhaust System: MAXfab Full 3” stainless steel exhaust system, x2 inline mufflers through to custom dump tip Cooling: 3 Core custom aluminium realdeal radiator with electric fan, setrab oil cooler and 500x250x56 tube & fin intercooler with 3” inlet/outlet Engine Management: Link G3 ECU (upgraded to g4 Firmware) with 4-bar MAP sensor and electronic boost solenoid Engine Bay: de-loomed engine bay, custom aluminium oil catch can, custom aluminium overflow bottle Other: gilmer drive pulley kit, remote oil filter kit Driveline: Gearbox: W55 supra 5 speed gearbox Flywheel/Clutch: Quartermaster twin plate clutch with billet flywheel to suit with ARP flywheel bolts, willwood reverse cylinder mount pedal box with remote reserviors Differential: 4.1 ratio LSD shortened hilux rear end Other: custom 1 piece driveshaft with custom driveshaft hoop Suspension: Shocks: Front – shortened shocks and modified OEM struts fitted with coilover sleeve kits and custom CNC’d camber tops Rear – adjustable shocks and reset and stiffened leaf springs with custom made anti-tramp bar setup with chromoly rods and QA1 rod ends Others: Cusco TE27 front strut brace, custom made swaybar to suit engine position and nolathane bushes allround Brakes: Front: 4-pot FD3s s6 RX7 front callipers and sloted rotors with steel braided brake lines Rear: s13 single pot claipers and rear sloted rotors Wheels and Tyres: Wheels: 17x7” (F) and 17x8” ® genuine work meister s1’s Tyres: Pirenza 205/40/R17 all round Exterior: Panel & Paint: Prep and paint done by Jason price, finished in a custom holden green Other: New indicators, park lights and headlights, all new window and door rubbers/channel, straightened and rechromed front and rear bumpers, doors and boot fitted with solex locks Interior: Seats: x2 Racetech 1000 bucket seats and factory rear seat Steering Wheel & Gear Knob: woodgrain steering wheel and stainless/bronze gearknob Gauges/Meters: Autometer cobalt digital boost gauge and autometer cobalt oil temp water temp and oil pressure gauge Audio: Pioneer Bluetooth headunit mounted in glovebox and alpine typr-R 6x9s in rear parcel tray Performance: Dyno Power: 320kw @ the rear wheels on 23psi with previous masterpower turbo setup, have since gone to a smaller holset unit for more response, currently making 280kw on 20 psi and full boost at around 4000rpm
sheepers 1977 (i think, could be 76) Toyota Celica TA23
Alistair replied to sheepers's topic in Project Discussion
Should've let bunghand fels do it up ever so gently for you -
You're fucking beasting through things as always Sheepdawg. Keep it up! -
Alistair replied to QCADTA's topic in Project Discussion
1gzfe now pls -
any recommendations on a mobile media blaster in chch
Alistair replied to d.p.n.s's topic in South Island Region
https://opencorporates.com/companies/nz/2203470 Ill try find his mobile but he does a lot of car stuff. Can't seem to find his deets online -
What are you wanting Sodablasted? Sodablasting is a dying art now and can cause more trouble than it's worth if you don't have a good operator and a lot of it stuff can be fine sandblasted with similar results. Can recommend a heap of blasters in Christchurch, some mobile too but not all sodablast.
