big tymer
Everything posted by big tymer
  1. 12ish when the car is off about 13-14 when car is going
  2. yea i like the look at the mo i have 18's that are 8" wide and have 215/35/18 on them they look like they dont have tyre on there at all but its all good
  3. big tymer
    door panels
    what about carpeting your doors ive done two lots of doors in carpet they look nice too just an idea
  4. yeah but rotary are all about being cool then performance anyways so ya might aswell supercharger them to be that much more cool
  5. yea degreaser from the warehouse $14.95 4l of the stuff
  6. just put abit of meths in there aswell and then just start it
  7. why do they have to be smooth just cut them as low as you can no one can see them when you drive past
  8. just wear a helmet next time then you wont get a scratch ion ya head
  9. sweet thanx
  10. does anyone know????
  11. why dont you make a box around the carb and run a bit of pipe to the front with a cheap $39.95 pod filter from repco
  12. ke70 5 speed giz an offer if ya keen ill go sort it out for pull it out and shit
  13. my mates got a 5 speed if ya looking for cheap
  14. can ya tell us about the conversion at the same time???? did it bolt straight in?
  15. on primiries only the two middle port are sucking in air and the secondiares are the two out side ports so you are doubling the fuel in fact more cos the jets on the secondiares are bigger you can get the same affected on a piston you just need to have a two barrel or more and get rid of the vacuum secondiares for a bigger affected
  16. big tymer
    Bosch GT40RT
    yea they are a lil better engine runs smoother revs a lil better yea they ok
  17. can i ask on where you are getting your zetec worked on????
  18. big tymer
    lowering blocks
    nah cheaper to make takes abit of time but thats the whole point of it not just to slam your ride down 2"
  19. i know that my 1600 zetec goes ok from standard but after i put filter 2.25 exhaust on without cat it just revs now its great but ive been told the heads on these zetecs are the downside give it a headjob and ill be racing v-tecs b4 ya know it hha that motor up there is crazy get a smaller carb and a better inlet manifold
  20. big tymer
    lowering blocks
    why dont you just make your own i mean it is only a block of metal
  21. big tymer
    Lowering my ute
    if its a two peice then that problem wont happen just reset them and get blocks
  22. maybe the car would have gone faster if they where all hooked up but you just thought it was fast as how it was
  23. big tymer
    12a dato coupe
    dont put your foot down as much?? who needs traction anyways????
  24. big tymer
    Diff Ratios
    yea just jack the back of your car up and count the amount of turns your driveshaft does to one full rotation of your wheel
  25. big tymer
    Diff Ratio
    with the lack of power from a escort wouldnt you want a high diff like you got so you can have some pick up???? altho i guess you dont wanna rev your engine to high for to long cant be to good for a piston engine i have a 4.3 at the mo but im looking for a 4.8
