Everything posted by Bearded Baldy
Drivers A pillar is no good. Fixable though. Found a hole under the wiper panel too, will see how bad that really is when i pull the dash out. Not looking forward to it tbh.
Went out this morning to pull the front bumper off and check out how things look. Got carried away but at least i know most of the front end is in good shape now.
Today went pretty smoothly, managed to solo tow the old girl off the lawn and onto the driveway and waterblast 2 years worth of lichen off. Found lots of cancer had spread but not as bad as it could be. 15 yard test is still a pass. Also found lost of lifting bog from its life before me, will make for interesting times ahead. Had to use the quad with a bare tire on the front to push it into shed as the brakes were binding on, got wife to steer it and it went slowly rolling into the jack, axlestands and compressor. She hops out 'i tried using the brake but it didn't work, its not my fault!!' Calmed her down with 'if i told you it had no brakes would you have hopped in it?' Prolly no dinner for me tonight lol.
- 40 replies
- 15
One of the multitude of reasons this car never gets any closer to be finished is my never ending flow of side projects and half arsed ideas filling up the carshed and not leaving enough room for the car! Rainy boring day so perfect for a shed tidying session. Got sidetracked making one of my kids a wand first up (see never ending projects comment above), but got a solid effort in this afternoon so far. Have been putting up with this behemoth being in the way everwhere for years now, never wanted the box anyway so today it got cut up for the burn pile. So much more space efficient now. Lots of things along those lines and now i can see a car sized open floored area again! Will cut open another burning drum tomorrow and get rid of all the scrap timber that has accumulated in the back shed. Then continue the relocation from hoardingsshed 1 to hoardings shed 2..... of 4. Then to tow/push/shunt the car out of its lawn divots!
Damn good deals those, just shits me as i was about to list my little arc welder with tig kit for $550. Might just hoard it in back shed instead, out of sight out of mind etc etc.
Wiper switch turned up today. All 5 points select solidly, they are pretty bulletproof so no further testing will be done until i fit it and it doesn't work. And that could be years away.
- 40 replies
Aaaaaaannnnddd car is still in the weather outside. But i just found and paid for something i have been looking for since 2005ish..... AN INTERMITTENT WIPER SWITCH!! This may not seem like a big deal but only having a 2 speed wiper switch in rainy reporoa is a problem. And yes while i could have wired in an aftermarket timer that wouldn't have felt right. So long as david from gumtree doesn't let me down.....
- 40 replies
Tldr. They are arse covering and i assume vtnz so won't look any further if you had asked them too. Not a fan of testing stations....
Sometimes it can also be they are not sure if the play is minor in the rack bush (less dangerhazard) or in the rack end/inner tie rod end (more likely to fail sooner. I have come across a few xtrails where this is the case. Easiest way solo to check is to slip the rack boot along the tie rod and off the rack, then have a look at the joint. Slide boot back over with a new tie and job done. Easiest way with help is to turn the wheels to extend the side of the rack with play, and pull down on the rack inside the boot while someone else checks to see if the play is still there. If it is, inner rack end. If play is gone, rack inner bush.
Took bike for a shakedown run up the road, surged and popped a bit. Shone a light inside the tank.... well that is coming off again. Removed and drained tank and carby. I really really really need to build a shelter for the bikes. Under the trees isn't waterproof enough apparently.
Tracked down a second hand hub/knuckle and i hope it turns up early in the week. Will put new bearings in it and throw it all back together for the trip. Everything else is in good shape.
Haven't taken the quad out for a for long long time and have pretty much just used it to move the trailer around. Decided i am going to take it away for my upcoming bday so gave it a once over. Lh front wheel has been on the piss for ages, i assumed wonky balljoint and put it on the oneday list..... Balljoint was fine, a combination of flogged out lower hub and a driveflage/wheel bearing combo that don't actually contact each other was the real problem.
Unintentional semi threadjack. My goal is to reach 400cfm at 28 inch test. Most of what i plan on using it for will be under 250cfm so it should would out ok. I have a couple of alloy heads for my falcon of different styles i want to play with, and i have access to a few ca18 and mx5 heads. Once it is up and running i want to write a logbook of stock head flow levels of pretty much any head i can get my hands on. I will also send a calibration plate to various places to get their readings with. Without knowing if there are discrepancies (there always are, like dynos), it is impossible to know how any headwork would compare to someone elses.
The speed i progress a project it is about time to procrastinate for a few years. I prefer working with steel opposed to timber so might take a prolonged breather before i build the box haha.
@Roman i bought the plans for the PTS bench. Then looked up the price of importing all the gear, exchange rate is murder. Current stockpile list is 3x ali ex motor controllers 6x vac motors 2 access ports Few little bits and pieces. And today finally got around to finishing the pressure/vacuum pickups. Prototype on left to see if i could do it. Thread too shallow and i snapped a drill bit in the end....amateur
Any progress? Making a steady collection of parts here for my project bench.
Shit yeah thats not too bad at all.
Before you buy a new rarespares bonnet, have a gander at alfa motorsport in oz. https://www.motorsportfibreglass.com.au/products/c45/Ford-Falcon-XY-XW
Stupid question. If it works on the bench but not the car, have you tried testing it with the revs up at 2.5k ish. Could be something stupid like the pulley size is too big, so at idle speeds it spins too slow.
Missed a spot.
I was thinking of using rule of 'eye appeal is half the battle'. Unfortunately since i plan on stripping and repainting the underside i can't hide it with shit.
Report him anyway. Being burned is no excuse to be over zealous. How many other cars has he condemned that are more than likely ok?
Report with pics to nzta. Don't need people like that doing shit like that.
