Posts posted by Otodat
Air temp sensor will go in where the vacumn for the idle control is currently, just ne to take the hole from 12mm up to 14mm, it's just above the throttle so should be a good spot
Wideband sensor will swap straight over where the current O2 sensors are, the leads to the wideband controller are 1.2m so might even chuck it behind the dash
Started marking out an adapter to put the throttle position sensor on, need to get some 6mm aluminum plate to make it up
Not quite sure on where to set the sensor, I guess there should be a spot with min resistance or max resistance maybe will need to figure that one out.
Photos of the distributor @fletch
Has a mechanical advance at the top under the rotor which is a bit oddslotted disc under that , eight holes on the inside, a heap on the outside, more than I wanted to countsensor has rsb-06 on it which looks to be easy enough to get a replacementodd rotor on top that covers the advance
What do you think, would it be ok to use this setup and maybe just replace the sensor?
https://www.trademe.co.nz/3598534483
$700 bolero, hope someone here gets it!
Love that Sentra @GaR, just watched the hill climb vid, so good!
Then started a side quest for some reason,
so that’s probably going to chew up most of my time for the next few months, Shit Nissans is a mental disorder I think.
- 6
1999-2011 U300 looks like it may widen at the front, can’t find a picture of one irl to check but,
Do later model chassis rails narrow at the front still? Can't imagine it would be overly hard to swap the chassis.
I saw this and it looks so good
https://www.trademe.co.nz/3527757289
How about some wats @yoeddynz?
Yikes, clicking on those links isn't convincing, japcrapcar club one advertising event for 2013? and states for unmodified vehicles?
Is there an implication here that vehicles over a certain age are not going to be allowed for normal use?
Is there actually an answer on if ga15 bolts straight in? Casual question, can't be bothered searching myself
7 hours ago, yoeddynz said:
I've run the wheels past whmbo and it's a no. Not the style she's after. Spokes are too fat apparently.
https://www.trademe.co.nz/3517488102
Trademe has been recommending these to me for a few weeks also
https://www.facebook.com/marketplace/item/287187790158692/?ref=facebook_story_share
Some 15 inch borbet wheels for sale locally, would suit a k11 imo
Nah I paid $338 for a new one like a chump
Will get there eventually
Slotted disc with optical sensors I think, will get a pic at some point
Been parts hoarding for this, got the work rims as part of deal on the 1200, been just running down the haltech website cause I'm lazy and don't really know what I need.
Got a wb2 wide band controller thing which should do two oxygen sensors
And a Bosch type dual channel ignitor, I guess you can use one channel to run the coil, haven't looked too hard at it, but it had to come in from overseas so went for it now. Will most likely bring the car home in a month or so and start to faf about with it.
You still at it @KustomKreeps?
Looks so freaking cool, will follow with interest.
Otodats 87 Nissan president discussion
in Project Discussion
It's a 54mm disc @fletch
