Everything posted by shizzl
got my shocks yesterday.. made the coilovers tonight. was a bit of a bitch job though.. had to cut off the spear cover, then cut the top off the shaft,slide the adjuster tube over then weld the top of the shaft back on..will take some pics once i have painted them.. my bellhousing is on its way aswell. trademe gave me a score with a new clucth plate for $51...score
got my new seat today...the boss picked it up from chch... fits me mint as,cant move in it...and its 20X lighter than my old one.. but i will put more padding in it.. also got my wrx brake booster etc that i got for $1... took the master cyl off it and blow my fukn mind it bolted straight into the mounts etc on the stocky!!! finally something worked easy.... now i just need to make the rod from the pedal to the cylinder...
havent done bugger all since getting the engine in... just spending large on parts and selling all the bits i no longer need.. ordered a new HRP bellhousing for it $575 picked up a brand new 15" ultrashield seat so now i can get rid of the racetech.. got a p/s box coming trademe helped out finding 4 brand new shocks for $80 and 4 tyres for $40 picking up a set of spanky new white rims for $280 off a mate won a brake booster on trademe for $1....score.. still need: steering wheel timing gears and chain slip shaft for a driveshaft rear disc and caliper gauges brake lines wheel nuts belts shouldnt be too long before its up and running...just time and money...
haha....*slap to the side of the head* nah just remember seeing honda mufflers sideways
dont some crx's or mr2s have this style muff? i know i have seen them before...
peace bitch
in my stockcar im gonna be using a hilux surf p/s box. this will be mounted on a pedestal kind of thing,on the end where the pitman arm bolts on it has been converted to a shaft with a drop arm out the side... now, in a stocky you want slightly quicker steering..... i think most people go 2:1 steering by using timing gears and chain off some old school engine.. what i want to know or have been thinking of is there is an old m-bike frame sitting in my shed, i think its an old yammy as theres a 125 sitting there too ( for sale??? maybe)... the gears on it are a 51 tooth on the rear wheel and a 14 on the engine... if i could use this it would make it a 3.6:1 is this right???? i suck at maths.... would this make the steering basically 1/4 turn centre to lock on the wheel??? or somewhere near that anyway.. or would it just make the steering feel heavy? up for deals swapping the bike engine for timing gears etc...
got one for my escort but found the inlet/outlets were waaaay too small.. but if you could get the ports bigger or changed then itd work sweet
what colour is the oil on the dipstick and is there a creamy buildup under the oil cap?? creamy buildups are bad,never touch a chick with this..
got the engine in tonight... ;D ;D ;D ;D ;D ;D
picked up my new ride today between rain storms and hail and thunder n lightning... fukn weather.. was a bitch getting it on the trailer.. glad i put on backwards cos it only just fits... its real wide in the front end.. got it home and couldnt resist putting the new body on it..
the old car was taken away to its new home today...
haha... went to aucks on the weekend.. flew up and picked up a racetech seat for it got home and some shiney chrome springs were at the door waiting for me..
built by graeme read out of chch..pretty sure its a kuriger copy. doesnt currently look like that though but will do eventually..still has the bonnet there.. have a brand new nelson tigers team body to put on it...in white gel coat. need ALOT of parts to get it on track in 4 months.. so if anyone has any of the following cheap or free let me know: 3 speed HQ boxes hq clutch plate hq or 3 speed driveshaft yoke hilux diff flange locked hilux diff heads falcon calipers falcon hubs shocks steel coilover sleeves and top hats 5/8" rod ends/heim joints hilux surf p/s box 60mm gauges monster tach 16" thermo fan deepdish steering wheel quick release wheel hub paint 15" tyres falcon stud steel wheels (trojan trailer style) hilux stud pattern brake discs and any rear caliper for dff conversion 15-20L steel fuel tank steel battery box really small brake booster and master cyl anything helps...
www.freewebs.com/stockcar-31gm check it out...
the new chassis... this was taken when it was first built.. yet to pick it up.
have ditched the thought of building from scratch.. Have had a look at a space frame chassis tonight and made a deal for it so in 2 weeks my old flat chassis will make its way to nelson and the following day the new chassis will be picked up.. the best bit is the new chassis is only 3mins from home pics to come when i get it here.. already got a parts list going on: hilux/surf p/s box monster tach 60mm gauges switches speedway bellhousing hq driveshaft hq clutch plate corolla cable type shifter brake booster (real small diameter) falcon calipers 5x114 disc and any type of caliper 4 eye-eye shocks quick release hub steering wheel mirrors thermo fan alternator and brackets for falcon p/s hoses muffler seatbelts window net so if anyone has any of these bits let me know..i have until october to get it finished. the new chassis is set up with: front beam and links hilux diff and links firewall engine mounts for falcon 6 steering arms and draglinks bonnet radiator spare front beams and wheel gates
you can get flywheels to suit off the shelf.. ecotech would be the best option...
i sold my chassis now i will have cash to buy copius amounts of steel to build a new one..
thanks to the ultimate GC d.p.n.s i scored a engine and gearbox crossmember set.. and a radiator.... so waddled out to the shed this morning....engine and box now back in.. and the tunnel is undersealed... wont have any issues with the box getting too hot pics to come...
update: had this on trademe in jan..sold for $300.. but now they still have paid for it or picked it up.. so will be getting it back together.. bolted the box up to the motor today,starter on,still turns over on starter.. waiting for the crossmembers to be sourced,then ill slap it all back in.. put some gtx or other shite jappa seats in it.. find an old codger at a garage to do a wof then use it as a daily to work..
you drunk son? only pics i have are like 28882299mb..my computer poos itself trying to get them smaller. plus my skill level is lacking.
i would still find that funny..
