Everything posted by shizzl
fired the bitch up today fellas!!!!!!!!!! mass erections all round.. got all the wiring done apart from the alt, oil pressure light, fans and oil temp sender. need to figure out where ill put the sender. my alt and other bits arrive tomorrow including my shifter. my driveshaft is away getting machined. will get it in a drivable state this weekend. although ill still need the brakes done, need front pads and rear disc/caliper/brake lines.. if anyone can help out with parts this is what i need: front pads fdor xe/xf falcon any falcon rear disc and caliper (or any 5x114 with a deep hat) radiator fans (i have a vl commy rad,so i think skylines etc will work) plastic backed mirrors like what trucks etc use. for my spares bundle i need: hilux axles diff heads 3speed HQ boxes 253 v8 clutch plate 14"x3" air filters early bighorn driveshafts wheels- 15x7s or whatever tyres tyres tyres...
also isuzu mu calipers are usable...has the handbrake on the caliper..
heres the newest pics... didnt realise they were out of focus... next on the to do list: put the gearbox in when its ready rear brakes driveshaft radiator piping thermostat housing alternator p/steer pump bracket waterpump pulley wiring bolt it all together ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
got smashed on paint fumes this morning... shitty cellphone pic..
used an arc to weld the tunnel into the escort...worked better than the mig... just need skill haha
heres the dash I made..mounted the gauges...yet to put switches etc in... mounted the vl radiator note the funky looking wing the last pic is where it is now....getting ready for paint..
thats what id be trying....or, spray in some "start ya bastard"...
cool project.... dont go black.....do it a rx8 metacllic grey...like a gunmetal..
some old prick down here has about 10 of these as a fence on the main rd...
have you seen the swifts the aussies build as drag cars? LMFAO!!! pretty quick though,but aussies have no styling taste..
but gt starlets are puss...arent they 100kw stock?= slow..same as a n/a 4age (stock) fiat turbos are nuts, had a mate that was running 22psi in his for years,i think they set it on fire to kill it in the end.. brutal little lunch box..
does anyone know if the glass in an autometer tacho can be replaced?? mine is cracked so gutted...
some shit i will be struggling with cos i either cant do it myself due the fact i dont know how or my skills arent the best to put my life in my own hand,o r i dont have the funds to get it done yet... *lap belt mounts for the harness just the welding,as mine is not ticketed steez *dash mounts *clutch and brake lines cost of making new lines *mount fuel punp and lines *get someone to put my hq box together i have no clue *driveshaft and cover cost to buy slip shaft and make flanges *shifter mount *fit gauges to dash *wiring,switches etc *front brake pads,rear caliper mount *p/steer hoses cost *radiator,fan. need to get a suitably sized radiator $$$ *new air filter *oil in box.diff,engine service *mirrors *sign writing *body mounts *wheel gate pins *radiator filler/header tank not too sure where to go with this yet *foot guards *various padding *tune for avgas obviously cost and skill *mount tyres and tubes to rims *get wheel nuts for the falcon hubs *make a spare parts pile....
mahinapua south of hokitika...lake to drown in,trees to puke and piss on,grass to tent and skid on. cheers DOC.
wont be many on the coon
need to get a brake line flaring tool so i can make the rear line and clutch line.. my battery box is finished apart from welding it to the mount..i was gonna make it a bolt on box,but turns out the battery can go in with ease in its location.. just need to cut a hole for the cable to pass through.. still cant figure out this friggin radiator issue...i think ill need to get a shorter radiator.. i need 1 clip for the shifter cable to clip onto the bracket,i think i dropped it in the mud when i picked it up anyone got one? trueno/corolla shifter cable clip... this is a list of shit i need to do... *lap belt mounts for the harness *dash mounts *clutch and brake lines *mount fuel punp and lines *get someone to put my hq box together *driveshaft and cover *shifter mount *fit gauges to dash *wiring,switches etc *front brake pads,rear caliper mount *p/steer hoses *radiator,fan *new air filter *oil in box.diff,engine service *mirrors *sign writing *body mounts *wheel gate pins *radiator filler/header tank *foot guards *various padding *tune for avgas *mount tyres and tubes to rims *get wheel nuts for the falcon hubs *make a spare parts pile.... i think thats it.... 1st practice is in 5 weeks... not a chance in hell
also made up an alloy dash,i think its dope... cut a hole for the steering shaft to go through.. check out that sick steering wheel hunted
got my fuel tank mounted....just need to finish the top brace,then onto the battery box mounts...
this is an ignition module... its on the side of your dizzyhttp://www.trademe.co.nz/Trade-Me- ... 163637.htm
my daughter wants me get my arse into gear and finish it...
i would if i was local... have you checked your plugs?
yup...one of many things that can make it do that... my stocky did it for a bit till i figured out why...
all models kind of differ...im not too familiar with the ea.. but my xf and xe dizzyz have a mdole under a alloy plate.. with a few wires coming out of it... modules are known to crap out especially after heavy rain... water sits under my module,and messes with the earthing etc.. also check your leads they may be cracked
is the dizzy the type with a module?if so give it a clean with crc and dry it... if not...then disregard
you wont loose bugger all power driving a blower.. blowers= constant boost,bridgey idle set to 1500rpm... burnouts on tap.. and itll be tuff
