Everything posted by 120why
Discussion for the 78'
Picked this machine up recently. Its stock standard, original 94 thousand km's... Even better, rego on hold! Discussion:
- 5 replies
- 15
It's possible? Maybe someone swapped the yoke from L series to A series? I ended up getting my other shaft shortened and balanced as that one was slightly too short and way out of balance!
Diff installed and running well! Ended up getting a driveshaft shortened, re balanced and a new joint fitted under level 3! The 4.11 ratio provides a fair bit more torque than the 3.9 and is paired well with the 5 speed box! Anyway, I was asked a while ago to share some photos of inside the car as I'm pretty useless at this... Interior is 95% mint, a tear in the hood lining and a tear in the already repaired drivers seat. Plans to get this tidied up soon! Went for a little drive to the beach!
Managed to get the rest of the panels bolted on, sanded and ready for highfill primer! Finished masking up and blew over it today. Will get onto sanding tomorrow and give it another blow over. Aiming to have it at the paint shop next week!
Busy week, prepped, set up booth and sprayed the door shuts, under bonnet, under boot and sprayed some other bits for the other car. Looking to finish off the fine filling this week and have some high full on nearing the end of the week https://oldschool.co.nz/index.php?/topic/60176-120whys-other-y
- 26 replies
More updates... Laid some paint this afternoon ready to go back in the car. Also, forgot I never posted the guard resurrection. In December last year I spent some time repairing rust, filling and sanding. Got some paint matched, its not perfect but pretty close considering the lime/yellow/milky colour. The paint tin is back at the shop and they are having another go at it. So back to the diff, aiming to have the exhaust sorted on Saturday and the diff in on Sunday. Might go for a hoon up the road on Sunday night
Bit of a cheeky update from end of last year... Engine in, running and driving! just no brakes, but who needs them. We've been filling, sanding and filling some more. Aiming to get highfill primer on before we come out of lock down then some more sanding... https://oldschool.co.nz/index.php?/topic/60176-120whys-other-y
Shit that h150 took some hard work! h165 is from a 1200 ute, same width as the 120y h150 diff. Maybe I should get some of that oil... might be worthwhile in this new diff. Video below of how bad they get lol
Few small updates from today - Bracket made for 120y hand brake cable to mount, bit on the ugly sign but she'll do! Diff wire wheeled, rust treated and prepsol'd ready to prime tomorrow. Aiming to have the diff in on Sunday after I do a some exhaust mod's...
Shite man looking good! nice getting that stuff sorted Had a geez at your h165 conversion photos, I'm doing one at the moment for my 120y. Do you remember re welding/adapting for the shock mount on the diff? Ive had to take the h150 mounts and weld them onto the h165 to fit
Good to see your still mucking round with Nissans Bit of a shame with all the shops shut right now... Surely its essential to have a glorious mode of transport?
Working on installing an H165 in the Y. Getting a bit over replacing the H150 heads, the A14 seems to destroy them... Cut H150 perches off, realigned and welded onto the h165 housing. Found a driveshaft in the shed, 1275mm long. Aligned this up and seems to fit well with the larger diff. Not sure what this is off? Something A series. Would like to acquire another one if anyone has one. Working on a bracket for the handbrake now, will be using the h150 120y cable. Need to offset the mount by 100mm to fit the h165 diff Aiming to wire wheel the diff and get it painted this weekend and installed next week! Thanks corona Come have a yarn while your stuck at home!
- 34 replies
Ill get some on here! Its very original and tidy
Chairs fellas, I haven't checked this in a while! have since left the Wairarapa!
Long time no update. Car ran super well over summer, minus a little incident where I struck some slippery stuff (oil?) on the way up the bombay hill heading to Auckland for a classic meet. Long story short, front of the car hit the barrier, was lucky it missed the wheel and didn't swing the back end into it! 100km on full lock doesn't feel too good. About a week later we were heading to Leadfoot fest so had to quickly turn a repair around and get it presentable again... Slide hammer and a few dollys helped with that.
- 34 replies
- 18
Ryan im Cole, Darrell is my father who was with us. Did you meet him?
Yeah man please do! Seen your wagon around a fair bit, very clean! You passed us in a grey Countrylane Kitchens trailer and blue ranger on the route to Hahei. Towed the datto there and sleeping in the trailer will be parked in the classic area tomorrow about 8am
Im here now and parked my 120y in the classic area. Staying at Hahei camp ground
Cut off the h150 brackets to mount onto the h165. Will need to make sure I weld these on perfect! aiming for a non cert swap as the diffs are practically identical Yarns heeeeerre
Been a while since an update, A14 has been running well. Finally got the jetting better, smoother to drive and more fuel efficient! Up'd the main jets and changed the emulsion tubes to improve the change between idle and main jet. Its still a little bit lean, but have spent far too much lately on trial and error with finding the jets. In November, my diff became seriously whiney. Ended up buying a 2nd hand head to put in, this seems to be working okay for now. Sourced a Datsun H165 ute diff 4.11 ratio, this needs some mods to fit but will be far stronger than the h150 thats in the car at the mo. Will be working on this throughout the year when I visit home during breaks from uni Took the car to Caffeine and Classics at Hampton Downs after xmas, also came to the Oldschool Drags at Meremere!
Just me, got the old man to grind the welds back. Then I went at them again making them presentable and re welding where needed Cheers guys. Hours upon hours and around 1m^2 of sheet metal :D
So thats it for now, Ive caught you all up with what I've been up to lol Feel free to drop some comments here https://oldschool.co.nz/index.php?/topic/60176-120whys-other-y/
