Posts posted by vk327
3/8 unf for the manifold studs, i think the fuel pump is 1/4bspt might be npt cant remember which thread tape will make up the gap its only low pressure
is the map sensor in a position where moisture can condense in the vac line and sit in the sensor? best practice to mount with the line facing down so water wont sit in the sensor , it sounds like you got a faulty sensor tho, being link you can run damn near any map sensor with the known calibration, MSEL stock a good 3 bar bosch one iv used a few of https://www.msel.co.nz/epages/motorsportelectronics.sf/en_NZ/?ObjectPath=/Shops/motorsportelectronics/Products/SENBOSMAP3
Fyi those bosch 3 chanel ignitiors need a decent sized heat sink, i cooked one testing ignition on a small piece of ali, also be wary series 1 3.8 square coils are prone to failure.
That efi throttle body setup off the falcon looks like it should work pretty good on the carby manifold.
on another note i take it the trigger wheel showed up
Switched to ground is pwr mode un grounded is eco mode. From memory your ecu has a performance tune loaded with a modifed trans tune
be better to weld or tap in injector bosses above the ports and not have fuel dropout issues that throttlebody injection has, efi hardware in ausie do a bunch of different style bosses and also individual injector rail fittings (PS the crank trigger will be on its way as soon as the courier actually picks it up)
Just now, tortron said:
Would a commodore coil pack work, I have one you can have for free. Take the crank angle sensor too
Commodore ones would work but a pain to wire up as they are designed to fit down on the dfi module base with tabs sticking up on the base for the connections, the au coil has a nice 4pin plug and about $90 new for a bosch one
Au 1 falcoon coilpack is the go for a wasted spark setup, along with a bosch triple channel ignitior from a volvo makes an easy setup, nounted my coils on heavy ali angle with the igniter bolted to the bottom using the ali to heat sink, also used a ba falcon VR sensor for the crank pickup, sensor type will depend what ecu you use tho, also check out thesonic injection throttlebody injection stuff for the 9 port 202
@chris r i have a spare 36-1 trigger wheel for 202 balancer i used with my link atom on the vk build @flyingbrick done the cad file and got it cut for me, if you go that route with efi, flick me a message if you wanna know more about the efi stuff on the 202
Some custom purple pearl mix its got a red and blue pearl in it, gonna be a pain in the butt when i needa touch up the paint
The guy we brought it off was an apprentice at a panel shop, was his 1st car, (he didnt wanna sell it but had it sitting for 5 years after being told he couldnt drive for medical reasons)wrote it off twice and fixed it both times, 2nd time he bare metaled the car inside and out and spent 11k on the paint according to the receipts we got with it,
Discuss here
Go ahead ask build questions or comment here
Build thread
Bout time I put up a post for the on going evolution of this build, a few years ago discussed with the mrs what car she wanted to build and she wanted an hq, we put it on the 5 year plan... 3 months later im working out on site at one of contacts powerstations and got talking cars, got wind of an un finished project a mate of the site fitter had sitting in a shed, que a few calls and some $$ changing hands it came home with us, its been evolving ever since, initially we spent 8 weeks and plenty of $$ getting it back to roadworthy with the 202 and 3 on the tree, since then its had my 327 chev and a fully built th700 fitted, then i picked up a vz ss ls1 cheap so makes sense to ls swap it since i run CWS specialising in wiring them, so out came the 327 and in went the ls1 mid lockdown 4 weeks later iv just fired it up, will endeavour to post up more pics of the project build but heres a few of various stages from when we 1st brought it in pieces to how it is now with the LS1
- 20
Post drag day have been daily driving to work, broken another 2 t5 gearboxes one blew a 3rd syncro the other sounded like an angry chipmunk so now running on a Frankenstein box made from 3 parts boxes, iv decided to splash out and get a jzx110 r154, waiting for my billet adaptor to gm bellhousing to arrive from the states and will be getting it fitted up and the clutch modified again, bonus is shifter in the right spot and cube speed short shifter off the shelf but need to make a new longer halfshaft, cue the i need a lathe for ....things talk with the Mrs (too late its already ordered) (also the you need another gearbox why?) haha
if you havent got a carb yet check out palmside.co.nz, they sell the 32/36 weber new for a reasonable price new, also if you have the ability to weld a water heating tube to the bottom of the manifold for anti icing, done that to the redline manifold i had on my hq 202 made a huge difference to not having cold fuel pool in the manifold, was running a new 32/36dgv from weber specs, that and the vk electronic dizzy worked well on the old 202
vk thru vt 86 thru 2000 commodores all have center cv joints v6 and v8 are all the same cv joint, 21r series u joints at the ends
$500 for an alternator is dare, 300-350ish retail(depending on model) thru my panpacific account for a new mitsi alternator
The same size or even a 3 kw single phase motor is no good on a screw type hoist, ask me iv tried it even with gearing down the drive pulleys it stalled the 3kw 4 pole motor could only lift a mazda6 on the hoist about 600mm off the ground, single phase just dont have the same torque a 3 phase motor has, @Kimjon im gonna guess that motor you have is star wound only for 400v (looks real similar to the one i had), if it could be hooked up for delta windings it could run on a single phase in three phase out 230v vsd but would lose torque due to the lower line voltage. Flick me a message if you have questions about motors and power calcs (im an industrial sparky by day)
yeah the axle tube flange ends are the same on both sailsbury and borg warner diffs, just the thickness of the backing plate that affects the bearing/seal depth, from memory the axle flange offset is the same
can be done. need to change to the disc rear end axle bearing and seals they have a different seal width to accommodate the difference in backing plate thickness, bearings and seal kits from vk v8 sailsbury commodore should work
Just now, spiderwebfx said:
TBH most of Jaycar's products are China spec items that have been branded. I've compared a few things from them and Aliexpress/Wish and they're identical but cost about 10x as much.
If you want Deutsch connectors, Repco can do the Narva ones, and can also get Hella ones. They're great but expensive.Jaycars auto electrical stuff can take a flying leap into the bin, genuine deutsch connectors are actually quite reasonably priced (given i do have wholesale prices from non retail suppliers) , just dont buy them from retail outlets like repco , for anyone interested I can price them up along with the budget home level proper 4 indent crimp tools
Brake cylinder resleeving stainless
in Tech Talk
had a couple hillman hunter rear drum cylinders stainless sleeved and rebuilt with new seals and i think pistons at apex in hamilton, was about $75 each side from memory
