Posts posted by mk2marty
On 16/12/2020 at 23:01, MRT1TRD said:
This belonged to the old bloke next door to us at work, his kids are dumping all his old engineering gear. Hopefully we're getting down on the big 3 phase "Herbert" lathe, the electric panel folder that's taller than I am and whatever else they're getting rid of. I bought an ancient Tanner drill press and a bench grinder, both of which we now have to move to Wellington with us lolol
7 hours ago, cletus said:
technically it would need cert, as it is a structural mod due to the guards not being welded on any more , even if the guards are not very structural
Depends how legal you want to be I guess. If you need a cert for other mods it would be easy to get that certed at the same time
Cheers for the speedy reply! The car is standard otherwise, so maybe this will be the tipping point for more mods...
Or maybe I'll ask the body shop to just weld the guards on. It would probably take a fairly observant WOF inspector to notice the difference, but why risk it tbh.
Front guards on a Mk2 Escort are spot welded on from the factory. If I were to bolt them on using rivnuts and M6 bolts every 60mm or so (for ease of panel gap adjustment/removal for future repairs etc) would this get into certification territory?
My thinking was that people have run fibreglass guards on Escorts for decades, and given that they predate any kind of frontal impact legislation it might be allowable - the bolts are spaced at roughly the same intervals as the spot welds were, so whatever body stresses the guards carry should be unaltered. However, the bloke painting the car reckons otherwise, and tbh looking at the VIRM it may be classed as a modification to the vehicle structure.
Who is right?
@brocky41 will PM you with a list of random trim bits I need for mine
Yeah can't do tonight, but keen for next month!
One year on from when I bought it, and it's looking a bit more respectable.
I bought a grille, front bumper, front air deflector, chrome moulding and column switchgear from the wrecked sedan in Lower Hutt, which has prettied up the front of the car immeasurably. Also, in a feat of impulse buying, I bought some headlight covers from a NOS Honda accessories bloke in Indonesia, who very kindly sent them over just before lockdown. They couldn't go on the car just yet though, because while the grille and surrounds were a lot better than the ones on the car, the surround was missing the left hand corner piece. There was a guy in the States who was selling a couple of corner pieces, and after lucking out of people in this country who might have the right part, I sent him some internet money for the piece of moulding in question.
Three and a half months later, it managed to fight its way through the COVID ravaged postal system and finally took its place on the front of another Accord, half a world away from the car it came off. It was definitely worth the wait though!
In other news, I fitted some headlight relays because the high beam switch had enough and self destructed one night. Fun fact: the switch is before the fuse in the headlight circuit, so when resistance through the switch gets warm enough to soften the solder on the terminals, there's nothing to stop the wire from falling out and then trying to weld itself to anything that has a body contact nearby. Unfortunately, without drastically altering the wiring loom there's no easy way to remedy this. The best course of action was to fit the replacement high beam switch and run it through a pair of relays to remove the current load.Other than that, there isn't a lot to report. Tune in next time for the valve stem seal replacement and 1980s stereo install, hopefully
Yeah, I still own this. One day I'll fix all the photos in this thread, but for now here's a slice of the 1980s on my front lawn.
Nothing else has happened really, apart from that the WOF man decided he didn't like the Recaros, so I'll have to swap the original front seats into it, and it needs a driveshaft hanger support and rear gearbox seal replacing. Maybe once the Escort is out of the garage I'll give it a bit of a freshen up, it probably deserves it by now.
- 7
Just arrived, carpark is full though!
On 16/02/2020 at 08:25, ESKIN8R said:
Was wondering how this little beast was getting on, keep up the good work!
Cheers mate! Maybe it's the Northland climate that helps with the project car enthusiasm
Surprisingly I still own this. I figured i'd better update the build thread now, it has more metal in it now than it did 2.5 years ago. With a year of a long distance relationship, moving house, changing jobs, other cars and a fairly sizeable task ahead to fix all the rot, progress kind of came to a halt not long after the last update. In the last year or so though I have been chipping away at it, so far I have cut and welded the l/h inner guard, heater bubble, l/h floor pan, inner and outer sill section, rebuilt the bottom of the l/h A pillar, l/r wheel arch inner and outer, outer sill section, and probably some other small bits I can't remember. I also cut the front valance off, and I am very thankful for the abundance of pressed panels available new for old Fords in that I got a new valance, front guards, and a myriad of repair sections to stitch in, without these I probably wouldn't have taken this on tbh.
Here it is on its way to its new garage:Some repairs to the firewall where every Escort rots - under the heater bubble. I've made an indent in the new heater bubble so water can actually drain away, rather than collecting in the bottom of the bowl and rotting through the seam that joins it.
It mightn't look tidy, but it's solid and there's good penetration through to the other side, so I'm reasonably happy. The l/h side floor section was probably the most daunting repair in terms of size, I ended up cutting the floorpan back almost to the seat mount before I found decent metal, but after I zapped in the floor section the outer sill and pillar fitted up pretty nicely.
This was the most recent repair - the rear wheel arch - which someone in the past has had a go at, not rust proofed behind the repair, and it's rusted again. There was a patch welded into the outer arch, which someone had beaten in with a ballpein hammer and shaped with bog, and a large patch on the inner which had gone rotten. It all had to go, I ended up cutting away the inner half and remaking it, and welding in a pressed section into the outer.
All that's left now is the l/h C pillar and vent, probably the r/h C pillar too, the bottom of the r/h A pillar, a random little hole in the rear apron, make some new front guard supports and attach the front. I have a full set of factory bronze tinted glass and chrome trim mouldings for the windows, which will probably end up on the car too.
And this is pretty much how it sits today!
- 21
Some good things have happened to the Accord since the last installment! I gave it some CV boots, thankfully the inner and outer are the same size, because both boots on the L/H axle were split. Fun fact - pre-facelift Accords have CVs at both ends, but later ones like this one have tripod joints on the inner. Confused the hell out of the bloke at BNT, anyway.
It passed another WOF last week without any hiccups, and we've taken it for decent number of road trips around the upper North Island. I even slept in it after Crate Day, which honestly turned out to be more cramped and uncomfortable than I thought it would be.
Still working on tidying up the front end, there's a sedan at a wrecker down country who might be able to supply the grille bits. The passenger side carpet is pretty rotten and it got consistently damp in the rain, which was a pretty good indicator that there were holes somewhere that there shouldn't be holes. I broke the unwritten rule of old car ownership, that being "don't pick at that bathroom sealant, you won't like what's underneath it" and lo and behold after chiselling away the layers of Selley's Bathroom Adhesive in the windscreen plenum chamber there was a decent hole.After taking out the wiper motor I found another hole, so out came the cutoff disc and the welder. Just to be safe I pulled the dash out so nothing caught fire, to be honest this is probably the first time this car has seen the hot end of a MIG torch in its life.
I made up a couple of patches, binned them after I found more scabby bits near where I was welding to, and then made up some bigger patches. Glued them in with the metal gluestick, and hit it all with some epoxy. Might spray some underseal in there yet, or I might just spray it all with fish oil and put up with the smell for a couple of weeks.Otherwise it's been plain sailing, the front seats need some more foam because as far as I can see they don't actually have springs in them, just a layer of heavy foam which has disintegrated over the past 39 years. Local content laws dictated that as much trim as possible had to be made here, which is why we didn't get the neat colour coded interior fabrics that everywhere else in the world got, we got beige or beige.
I pulled out the amplifier that was tek-screwed through the floorpan underneath the passengers seat and the lil' Johnny spec head unit that was flopping around the dash and wired in with three core house cable, and wired in a period '80s Clarion spindle mount unit - less doof, but more class! It needs a set of TS-Xs for the parcel shelf next time i'm near Buyee.com.Here's some pictures of it enjoying the scenery
- 19
3 hours ago, niswhale said:
The dude at Greenfingers was a GC. No receipt needed and nothing said about transporting the bottle, It just costs $20 more than Bunnings.
Worth it not to have the hassle of dealing with Bunnings tards tbh.
2 hours ago, ajg193 said:Did you show her the pamphlet and point out that it does not say you need a ute or anything and that a car is fine?
Interesting! I'll see if i can track down that pamphlet online
Bunnings Whangarei are utterly useless. The Karen at the counter wouldn't even get past the fact I didn't have an "open car", at first I thought she was asking if i had a convertible. She insisted I needed a ute to carry it in.
Might go back on the weekend and tell them I walked to the store, it's either that or hire a trailer, pointlessly. Apparently Blackwoods and Greenfingers are Coregas suppliers up here too?
5 hours ago, S124AB said:
This makes me very moist
/pft: failed at stalker snap of @Tumeke in the wild
- 7
Could be keen
Cheers guys! The car came with a Gregory's manual but thanks for the offer, @tortron
I'll keep you in mind, @- i5oogt -, if plastic welding the corner of the grille on the car doesn't work then it'd be good to replace it with something decent.
Old Lathes and machining shite
in General Car Chat
Cheers! Not sure how you guys are going to make any more space in the office, but I'm looking forward to it
