Muncie
Everything posted by Muncie
  1. Right that on the floor needs to go right where my lovely swoopy exhaust is..... might just experiment with new pipes at same time. CVT Time excitement! off the line punch and top end, up till now ive only been able to have one or the other. And the compromise of the exploding pocket bike wheels or a slipping clutch on take off for top end. Was on special finally from Motiveparts (nz company) so i decided to finally do it. The long suffering clutch was only ever rated to 8hp this one is 13hp the guy i bought from assures me it'll take my power easy because its light and gearing is pretty decent.
  2. It looks wrong but probably isn't looks like a normal sidedraft must be internally different for downdraft duties. Failing that i have a pair of 32mm Mikuni's...... nope must not fuck with it ffs im terrible.
  3. This will be happening BTW have found it to be lazy easy fit to the quad i was building so will just make it be and get it ridable asap Sprocket and disc have been fitted to axle just need to change sprocket to 428 pitch on engine and start moving mounts around to make chain line up. Currently needs to move 20mm to right and thats it. Unsure if carb is actually downdraft looks wrong to me so may need to jam a 90 degree silicone joiner in there.
  4. I got in to work yesterday morning and theres an envelope on my desk with the full wiring loom diagram and some hand drawn notes, The good bugger that gave me the motor found them when moving house and made a trip in to work make sure i had them. So i unboxed the loom and started plugging stuff together and quickly realized this is an entire bike loom, brake lights indicaters dashboard plugs the lot. Here i was thinking it was an extremely complicated stand alone loom. Its going to need some extras plugged in to make it run, ill grab an aliexpress digital bike dash so i can have some idea whats going on and go from there. Meanwhile theres Engine mounting to be done.
  5. Muncie
    Aubz dragped
    Would a 125 spool a turbo up a VZ21? Tiny unit but they normally need a 250cc + and plenty of revs to get them spinning. Failing boost a rapid fire whipped cream nitrous oxide system for max power minimum outlay. Nang till she goes bang
  6. Muncie
    Aubz dragped
    Jam a small blower on it a AMR300 would be about right. EFI could make it really easy or really hard depending how the small engine stuff works.
  7. Found this vid of it first time it worked long enough for kids to ride it. Might actually rebuild it as i still have the exact same scooter unmolested in roof stored away. It then evolved to this
  8. Sparked this up today after pissing around with chain alignment and tension it had this weird harmonic going on when you got to about 40 ks thats gone now. it could do with a roller on the chain that runs to the jackshaft but seeing as I'll be going CVT fuck it I'll just keep it on tight side. Anyway tune is good on 50% ethanol mix with taller gearing the SU is way happier plugs are nice and clean. Went for a 10k ride along a closed stretch of road and used lots of petrol this things effortless though just cruises along and doesn't fuck around for a second when you give it berries! Top speed? Dont know didn't get there just enjoying it not breaking shit and getting pelted by bees and sand flys. Hard to believe it started as this thing now. Very little remains maybe the throttle cable and some tube, and the battery box, the rest was chopped out and replaced with heavier tube at some point i didn't photograph.
  9. If you don't mind me asking whats a vespa worth these days? Your idea about throwing the bodywork over my scooter still is burned into my mind.
  10. Yeah they're what i tell people to buy. They dont need backing off and unless they have been used as a breaker bar seldom go out of adjustment. Been calibrating wrenches on and off for years and they certainly are my pick. Edit* i should of said in my hoard of tools i dont use enough.
  11. Yeah its evolved beyond what i ever thought id do with it and to be fair i don't have a lot of money in it but i hate to think how much time. It feels like it's got as much power as my old triumph Bonneville chopper i built in my 20's Haha. First time ive actually heard it from somewhere other than on it today since i did the port job on heads and switched to running a bit of ethanol, Its pretty barky as soon as it gets some load on it thats for sure!
  12. So rebuilt myself a 300nm torque wrench today essentially was put into work and found to be uneconomic to repair, the good thing is when you get enough broken ones you can raid parts to make a good one. Made it work than decided to try calibrate off my aviation spec deflection beam warren&brown Worked a bloody treat! Got it bang on. Excuse the shit on floor ive been active in shed recently.
  13. Father's day tinkering complete. Let the young fella have a go with the tall gears its really tame. I only let him roll downhill so he could used to it but no real wobbly moments slightly more than jogging pace.
  14. Ok could be changes happening here a lot of things line up nicely and mounts need only be moved around instead of fabricated. And the chain lines up which is always a prick to sort.
  15. Good shit man Cvt for the win bit more space you should have legs to keep the wheels going over any distance.
  16. Mighty car mods and haltec likely have a series or 2 coming up on modernizing their Nissan superturbo micra/mira? thing which will be worth a watch as a tech thing will be very cool. Of Interest to me as well as id like to do build myself a l67 holden v6 but keep the supercharger and add a turbo or turbos.
  17. Going to try the CDI setup off the Lifan yamaha clone i got this week which will definitely work just need to see how i can configure the pick up to work. Have heard this engine will happily zing to 6000 rpm for short bursts and 5000rpm continuously wont hurt it either. My smaller twin loves revs i do have to remind myself not to give it to many as it has no governor and a cast iron flywheel.
  18. Acquired a new 37 tooth sprocket today for the back as the 31 tooth was too tall. Bodged together all my scraps of chain adjusted up and went for the first proper ride. So so so much better! 60k at 2500rpm it takes off like an absolute rocket from there no slip ,some clutch slip to get going from stationary its doable though wont hurt anything. Moving the wheel back has added 25kg more over the front wheel too so it brakes like a weapon as well now. Would actually call it not sketchy anymore even crawling isn't wandery anymore. Will add a Cvt soon and new chain but its good now to do the milk (almond) and bread run as often as possible. No pics for a change as nothing broke nor did i fall off (or think i would)
  19. For sale now been daily driver for six months has been rock solid apart from door locks playing up . If you would like to kick tyres message me has wof and rego.
  20. I have half a mini chopper and a v-twin........ all i need is half a quad and i have a trike been a pretty logical easy build. Will make it run and properly assess the situation as this would bolt into my drift quad but not so keen on 5 gears and my kids hitting triple digit speeds.
  21. So this thing will barely move with the sprocket that was on wheel and my original has to many holes to redrill. Will order one and go from there job almost done oh and got valve stem replaced already so it back on the ground again.
  22. Cool so this is a clone of a Yamaha xv250 virago the Yamaha bike wasn't too shit for a 250 and sounded good so this could be useful. Hmm decisions decisions will have to curb my enthusiasm though and finish some other shit first, or hope something with wheels drops in my lap missing a motor.
  23. Some info its a Lifan 250cc The ignition setup would be perfect for the turbo v-twin i have so may try swapping some parts around. The 5 speed box has my mind racing. Type 4 Stroke Twin cylinders, V-Twin, four stroke, air-cooled Displacement (c.c.) 248cc Bore x Stroke (mm) 49.0 x 66.0 Max HP 16.25 HP @ 8,000 rpm Max Torque 13 ftlbs @ 6,000 rpm Compression 10.0:1 Ignition system: CDI (Capacitive Discharge Ignition) Idle 1,300 rpm Starter Kick and Electric Clutch Manual Wet Multiple Plate Transmission Left foot gear-change, five-gear constant meshing Lubrication Pressure splash inner-outer scavenger rotor
  24. Well this just got placed in my boot its brand spanking new all the parts are still in boxes for my favourite price of nothing. I have no idea what I'll do with it yet suggestions welcome.
  25. Looks far less weak in the back too with a meaty tyre.
