Everything posted by Muncie
Kimjon's 50cc (then later ... 150cc and 400cc...then 1000cc) of awesomeness!
Muncie replied to Kimjon's topic in Two Wheels
Chopper will look sweet with that body on it..... -
Earth other side of pipe.
No fume oven cleaner works well doesn't fuck paint removes brake dust piece of piss. Dont use on bare alloy though it dulls it.
@vk327 would you say this is an accurate accurate pinout for a vy? Multi meter says otherwise, best voltage i got from 2nd pin from left was 10.7 volts.
If you can find your self an air dryer second hand i highly recommend your gear will live a far easier life, you wont get buckets of water in your airlines "my 2c" i dont have one on mine yet but i really miss having good clean dry air.
Just fitted a second hand ecu which ive managed to clone from original one so all securty is intact. Flashing a tune into these is actually a piece of cake and theres plenty to try online. Once ive got the electric issues nailed down ive got a hot tune I'll try. I've split out my ECU shenanigans into a separate thread as its a project in its own right.
@tortronIm going to put my multi meter on the DFI power i wonder if ive got a voltage drop causing it to brownout and partially shut down causing weak spark as it stinks of fuel when it runs shit.
Thats on the 100% untouched map that was in car too.
So out of interest while it was running shit this morning i floored it to see what would happen it maybe got to 1900-2200rpm and popped and banged out intake. Something really bloody weird must be going on with timing, its like a 2 step only out the intake.
Hasnt missed a beat or broken anything since i fitted the CVT smoothed the engine out nicely and has the top end of a GN250 with a tailwind. I sold my turbo motor (got Ls1 money for it) so no need for a box now. Quad getting v twin bike motor i scored. Currently happy nothing to do on it...... it just works now.
@vk327What would you like for it? Currently running a VR set i bought 1$ off trademe in despair and it fired straight up after nothing else worked....... does get ridiculously hot though be good to see if that's not normal.
Yeah worth a try they appear read well but something weird could be going on at startup giving weird signals to ecu.
Your input is bloody helpful for me trying to get my head around this shit. Im bloody determined to nail this gremlin so i can move onto fabbing some nice pipes and jam a turbo on and tune it myself.
My rough cold start symptoms persist still.... improved with new ecu but still there im not getting fault codes yet so something on the engines playing up. Time to collect more data annoyingly the problem only exists from stone cold (morning) and 2-3 minutes,setting up for a data logging at 5am is a pain in but. Ive got a brand new DFI that the car wouldn't run on i will throw back in as it fully seems ignition related. Of note too the car runs hardly any different with the cam sync sensor disconnected revs a bit sluggish but not terrible.
"HOT Tune" yeah nah car didn't like it tried to run but kept stalling. Got a check sum error after loading it so stuck original tune in fired straight up and ran fine. Will find something else a bit more mild perhaps.
Sweet Downloaded XDF File now i can see whats goin and turn stuff on and off. Compared the tune I downloaded from net against stock from the ECU I installed only minor changes so will zap it in tonight can always go back to stock if its balls.
Can cars catch computer viruses..... oh well guess ill find out just downloaded a file called "hot VY tune" has 98 octane map and raised line pressures in trans.
Fuck yes i did! If only it wasn't so expensive and burn 3x as fast.
Cold start still shit as expected. However drives way better rev counter needle no longer flicking so must have been an issue with the CAN output to dash. Hoping i can now flash a stock tune into it and that will sort the cold start. Did some data logging lastnight nothing untoward going on (no weird spikes or flat lines)except the ecu isn't commanding the IAC to do anything at idle hence very low idle.
So after saving some data from the original ECU i fit the replacement Ecu hooked in with OSE Flash tool and loaded the Bin file. Successfully too after a second attempt i got a scary pop-up message first go that wasn't mentioned in the step-by-step from pcmhacking.net leaving the the ecu with no vin number so no start. Seems a bit more peppy and idle is better when warm than before. My bet when its stone cold I'll have the fucked idle still because ive cloned the ecu. But now i can safely jam a new map in it and i know this ecu Hasn't had the ignition system shit itself while plugged into it. Getting there.
Read the bin saved 2 copys but for whatever reason i cant figure out how to open it in tunerpro to unset it from the parameter tree. Failed somewhere.... ecu is still happy though connecting fine etc so original back in. Data errors i was getting are gone after changing a few settings so thats a start. Watched few videos and got different results gah! Frustrating.
Got new ecu in opened everything on laptop then this happened, could of been worse 5-10 minutes later i would of possibly bricked the new ecu.
Yeah cars still matching numbers and got off original owner hasn't been apart so hopefully i can discount wiring as the issue. Might see if i can plug into my dads vy as thats 100% happy just to see if i get data errors have had the lead a little while now. Finally got my brain on task and understanding what im trying to do stoked new hobby! Down the rabbit hole i go.
Got Tunerpro up and running today monitored the live data quite a few Data errors so held off Running OSE flash tool to pull the Bin file, could be the ecu is fucked and is my entire problem. Will swap new ECU in this week Pull the bin with OSE Flash and deactivate VATS to get it running then just monitor the error count before playing around any further. Correct me if i'm wrong but if i'm getting data errors I could have wiring issues or my laptop is another potential issue and I do not want to brick an ECU. I got scammed out of 100$ bucks on facebook market place trying to find an ECU so this has been an expensive exercise.
