Everything posted by kws
With 190,000km on the clock, and little to no service history, I wanted to replace the PCV Valve as preventative maintenance, as this is the cause of a few issues others have had. The main issues people seem to have with them as they age is that they can get stuck, causing oil consumption, or more commonly, a rough idle. As far as I am aware, my car uses no oil, doesn't smoke and my idle is about as smooth as you expect for a boxer with uprated engine mounts, but it was cheap enough to buy a new one with my last shipment from Japan. The little guy lives here, tucked down behind the inlet manifold There is a bracket with a hose on it just above it that blocks access. Remove the 10mm and move that out of the way Much easier to see now, and slightly easier to access. I had heard the hose can get a bit hard and brittle as it ages, so I grabbed a new one of those too. It has no clamps on either end, and is just a press fit. On the manifold end, remove the little beauty cover, and then it's the hose without the clamp Pull the hose off the inlet manifold and then the valve. It'll be on there tight. Worst case, cut it off, since we're replacing it anyway. You'll need a deep socket, 19mm IIRC, a wobbly joint and an extension. Even then access is super tight Once removed, it was obvious the old one hadn't been touched in a while, so it was probably original. When shaken the original one did click, but it was sticky compared to the replacement which rattled freely (there is a little valve inside it that moves freely when shaken, hence the rattling). I probably could've cleaned the original one, and it would've gone again, but for the cost, it was easier to replace it I screwed the new one in with some sealant on the threads and tightened until snug The new hose slipped on nicely Plug the new hose into the manifold, refit the hose and bracket moved earlier, refit the beauty cover, and that's a job done. No real obvious changes, maybe the idle is a little smoother, but I'm happy knowing it's been done. Parts Used 11810AA131 - PCV Valve 99081AA321 - Hose Please note these parts are specific to my car and may vary. Please check before ordering.
Surely logging or watching live data on the PFC during the times where its faulting should show up if a sensor was reading wrong. Thats how I found on my old Link G1 when my MAP sensor was full of oil, the MAP reading went on the piss when the car stumbled, same when the IAT sensor wires were shorting on a different car.
Certain BMW E46 fuel filters have a reg built into them and return from the filter https://skunkworks.co.nz/products/e46-m54-fuel-filter
More track day prep here. One of the common issues with the Toybaru Twins is that the oil temps are pretty high, so in an attempt to control it, I installed an oil-coolant heat exchanger. I'm not really breaking any ground here, since this exact cooler was factory fitted to the second gen BRZ/86, and others have fitted it to their first gens, but since no first gen got any sort of oil cooler from the factory I figured this was a good compromise for what I'm doing. Yes, ideally you would fit a proper oil-air cooler in the front with a thermostat, but 90% of my use is on the road, where it wouldn't be needed, and one major benefit of the heat exchanger for me is that because it sheds oil heat into the coolant, it can also suck that heat from the coolant, which is much quicker than oil to heat up, to bring the oil up to temp quicker when it's cold. Example of Greddy oil cooler (blue radiator) Cusco even released their own version of the heat exchanger for the first gen, which was a little more in-depth and required tapping into the actual radiator hoses. The basic theory is that the heat exchanger sits under the oil filter, and has coolant circulating through the inside of a copper core as the oil goes around the outside of the core. It's quite a nice looking unit. Genuine Subaru, of course. This is where it goes, under the oil filter. And this loop under the throttle body is where others have tapped into the cooling system, and where I will too I purchase a meter of 5/16" / 8mm coolant hose and used some spring clamps to fit it to the exchanger. Half a meter on each side is more than enough and will need trimming to fit nicely. I removed the filter, which was way too tight, and then had to go out and buy a deep 24mm socket in order to remove the old threaded stub, as this needs to be replaced with a longer one Slightly longer The exchanger comes with a new O-ring already, it just needs a smear of lube before fitting Clean up the housing, since you won't be able to access it again. Make sure the small indent on the right is clear of debris too, as the locating tang on the exchanger needs to fit in there Thread the hoses through under the AC compressor first, and then offer up the exchanger. Once it's sitting nicely, slide the centre stub through and tighten to spec (45NM) Oil up the seal on the new genuine filter and fit that too, Hand tight, no uggas or duggas. And now you can see what It's going to look like Now it's time to connect up the coolant side of it I removed the loop that is there from factory. Nothing came out of the top pipe, but a small amount come out of the lower one and proceeded to go everywhere, so I quickly measured, cut and clamped the hose on The top hose was measured, cut and fit too. I don't know if it matters which way the coolant circulates through the cooler, in my research from others doing this the consensus was that as long as it was flowing through, that's what mattered. Ignore the tape, its holding a piece of thick rubber in place to stop the hoses rubbing. Will be replaced with some split conduit later. I took the opportunity to change the oil too. According to the sticker, it was changed just before I got the car with Valvoline 5W30 (which is fine oil). Oil pressure was good, but I was surprised at how dark the oil was in just two thousand km or so. After much research, going over all the relative viscosities of oils at certain temperatures, I settled on Castrol Edge 5W30 as my oil of choice. It's thicker than the stock 0W20, but Subaru did recommend 5W30 for extreme use cases (like track days), and I don't want a thin oil breaking down on the track and costing me an engine. Once everything is buttoned up again, the fresh oil is in the sump and the coolant has been topped up, start the car and at idle with the heater turned to hot, slowly open the bleeder on the heater hoses near the firewall until coolant comes out of it. This should be enough to bleed the air out, but keep an eye on coolant temps for a couple of drives just in case. So far the results are promising. Previously, I was regularly seeing oil temps 10+ degrees C above coolant temp when at operating temperature, which would often mean oil temps 100+C. Now I'm seeing oil temps much closer to coolant temp, within a couple of degrees The oil temps also drop back quicker than they did before after a hard run, and the time for the oil to come up to temp on a near zero C cold winters morning is significantly quicker, maybe even halving the time. As a bonus, it appears I have picked up a couple of PSI oil pressure at operating temp, too. I was sitting around 10-12PSI at idle previously, now it's 14-16PSI. Over all, considering it cost about a quarter of a decent oil cooler kit, and unlike those it also helps bring the oil to temp, at the moment at least, I am happy with the setup. The big test will be at the end of the month when I take the car on the track. Hopefully it can keep the temps under control. I really gotta clean that... Parts Used Subaru 21311AA220 - Cooler Assy Oil Subaru 21317AA070 - Connector Oil Cooler Subaru 15208AA130 - Oil Filter Subaru 803916010 - Sump Washer 1 Meter 5/16" or 8MM Coolant Hose Please note these parts are specific to my car and may vary. Please check before ordering.
- 94 replies
As part of my prep for the track day later this month, I wanted to replace the engine mounts. How to do it wasn't exactly clear though. There is a bit of information out there for replacing the engine mounts, but mostly LHD and most of them say to remove the headers to do so. Being the stubborn guy I am, and not wanting to remove the headers, I thought there must've been a better way. In my last RHDJapan order, I got a pair of uprated STI engine mounts. These have a stiffer compound rubber without being super harsh like the Cusco and similar with their polyurethane mounts. With the car in the air I slid under, removed the two under trays and had a look at what I was playing with. The mounts were surprisingly accessible. That bolt and nut are easy to access with a rattle gun and extension, but there is also one bolt above the steering rack which is a little harder For that one I found it was best to start the bolt with an offset ring spanner as it is recessed, and then once loose, undo it with a ratcheting spanner Both sides worked with the same treatment To lift the engine, which has to be done otherwise the mount stud will not clear the crossmember, I used a floor jack on the sump. I'm not that happy doing this, but many people have done it before, and I used a rubber block to spread the load. I got away with doing this with no visible deformation of the pan. The hardest bit was just working around a big jack right where you need to be. I started with the RH engine mount as I figured this would be the hardest to remove due to the steering column/rack, and I was right. I completely unbolted the RH mount and loosened the centre stud on the LH mount so that I could use that mount to pivot the engine over (instead of just lifting it straight up and having nothing keeping it in place). Once the mount was free, I could move it around, but couldn't seem to get it out. The trick was to remove the heat shield plate on the top of it (not captive like the STI mount, it just sits there) and unbolt the steering rack (mark or make note of the bolt positions before undoing them as there is some wiggle room). Without the plate on the top I had more room to move and rotate it, and lowering the rack gave me just enough room to squeeze the mount out towards the rear of the car and remove it. It'll take a fair bit of rotating and wiggling to get it out, but it's doable. Refitting the new mount wasn't too bad either. Because the heat shield on the top of the STI mount is captive and can't be removed, I did get it stuck just as it went over the steering rack, but a little gentle pop with a pry bar got it free and into place. To bolt it in I lowered the engine slightly, so that the centre stud lined up, but I still had free movement to screw in the two bolts. Once the two bolts were done up hand tight, I lowered the engine down onto the mount, leaving the centre stud nut loose, and moved to the other side. Comparatively, the other side was easy since there was more space to work (no exhaust or steering column) Once the mounts are in place and the engine lowered down onto them, torque them to spec (45NM centre stud, 35NM for the two bolts, one of which has to be done to gutentight since a torque wrench won't fit - in hindsight with the rack loose you might be able to fit a torque wrench on an extension in there). The steering rack needs to be refitted and bolts torqued to 120NM. In conclusion, yes, at least on a RHD car, you can replace the engine mounts without touching the headers. How are the STI mounts? Good. The driveline feels tighter, more like it's part of the car. There is a small amount of extra vibration now, mostly at idle, but it's barely noticeable (and nothing like the vibration the Alto had after the rear mount inserts went in). I probably wouldn't bother replacing stock low KM mounts with them, but my 190,000km mounts were worth replacing. Parts Used ST41022AS000 - STI Engine Mount RH ST41022AS010 - STI Engine Mount LH Please note these parts are specific to my car and may vary. Please check before ordering.
If the transmission in your Toybaru Twin has ever been out of the car, there is a chance the reverse lockout plate on the shifter is no longer correctly adjusted and maybe impacting shifting. In my case I knew the previous owner had the transmission out for some work, and knowing it was quite hard to shift 1st and 2nd gears, I suspected my reverse lockout plate wasn't correctly adjusted. This is a reasonably easy task to do, albeit with the complication of having to remove the center console to access the shifter assembly. To start with I removed the shifter surround by gently reaching down into the shift boot, grabbing the inside of the plastic surround and pulling upwards on the front of it. The back slots in with a tab, so you need to start with the front. Once it lifts up, unplug the connector for the traction buttons, remove the shift knob, and the whole surround comes off. Next the little pocket in front of the shifter, with the start button, needs to be removed (or at least free'd and moved to the side). The manual says to just grab it from inside the pocket around the start button and pull, but I couldn't get that to work, so I removed the little side trim below the knee pad on the side (pulls free) and using a screwdriver gently pressed it against the back of the pocket and pushed towards the rear of the car until it popped. Both methods are offical ways to do it, according to the service manual This is a good time to unclip the handbrake boot by pulling it upwards and then sliding it off the handle. There are six screws holding the center console in, two under the pocket I just removed at the front, two behind the shifter and the final two are under the rubber mat in the "cupholder" storage tray area. With the screws removed, the console can be lifted, plugs disconnected (don't forget the one for the power socket) and the console removed. I slid it back into the back seat for enough room. Now its time to work on the shifter. Remove the big foam insulator on top, this has two white plastic screws on studs that need to be unscrewed and then remove the four bolts holding the metal boot retaining plate down. This will free the rubber boot and let you acess the reverse lockout plate I found mine was out of adjustment and too tight to the lever when in the 1st and 2nd positions. When going from 3rd to 2nd for instance, you had to push the shifter against the lockout plate, which made it harder to shift into gear and felt pretty yuck. The spec is a 1mm gap, when the shifter is in 2nd gear, and lightly held to the left (since my shifter has a little play in gear). I loosened off the four bolts securing the plate, just enough that the plate could be tapped into place but had enough resistance it didn't move freely and then slipped 1mm of feeler gauges in the gap, making sure the blades were parallel with the face of the shift lever "detent" (as the vertical stopper is actually curved) I then nipped up the bolts and checked the shift action. Mine was better, but if you find the gap too big, the manual says you can reduce the shim size by 0.2mm and try again until it's right. Also check it still blocks reverse unless the collar is lifted, and that you can actually get into reverse too. I used some lithium grease on the two faces and then reassembled everything. I'll tell you what, other than the Motul fluid in the transmission, this was one of the biggest improvements to shifting I have made. I didn't think it would do much, but it's significantly easier to shift into 1st and 2nd gears, and by some placebo, the rest of the gears feel smoother too. From factory this should, in theory, be correctly adjusted already, but obviously whoever reinstalled the transmission in my car just kinda set it by eye. Whilst my overalls were still clean I had a couple of other things to do in the interior. I have no idea what was going on, but the gauge cluster lens was junk. I'm not sure if someone had tried to clean it with something it didn't like, or if they had a sticker or something dumb on it at one point, but this is what I started with I polished it with PlastX and it got slightly better, but it was still hazy, particularly around the tacho It seemed the only way to actually cure it was to replace the lens completely. I did this on the Alto, and it was well worth the $30 or so from Japan. So I ordered a new lens from a GT86 (since the BRZ one appeared to be NLA) and set to work replacing it. The radio surround has to be removed, which just pulls off, and then the top visor needs to be removed. This is held with a single screw in front of the cluster, facing upwards, and then with a bunch of clips which require you to pull it up and toward you to remove. The cluster surround then pulls forward. This is attached to the column shroud, so I opted to just pull it forward instead of removing it. This left me with full access to the cluster lens. You don't need to remove the cluster. I just used a small flat blade to pop the clips around the perimeter of the cluster to remove the lens I took a lot of care not to touch anything inside the cluster, or to touch anything but the edges of the lens just so I didn't have rogue fingerprints everywhere. After reassembling, the results were dramatic Its crystal clear now. I think for the money, its one of the easiest ways to uplift the interior of an older car. You spend so much time looking through this lens, it might as well be spotless and not scratched or marked. Finally, the cabin filter was replaced. Fairly easy, just open the glove box and squeeze the sides in so the stoppers on each side pop out and let it drop down further The filter is behind the white cover. Gently press in the clips on each side and remove it Take note of the orientation and remove the filter. Mine was full of junk. Likely not changed since before it left Japan And slip the replacement filter in, oriented correctly (UP is up) Reinstall the cover, hook the glove box back in and job done. Enjoy the nice clean air coming through the vents. Parts Used Toyota SU00302619 - Cluster Lens Roadpartner 1PS961J6X - Cabin Filter Please note these parts are specific to my car and may vary. Please check before ordering.
Problem with poly and similar hardness is allegedly because the bushes need to twist when the axle moves, if they are too stiff the cast alloy arm can actually break, and like the OE bushes, it's also long since NLA. It'd be easy if the inside of the hole where the bushes go was perfectly round, but it at least has the two flats inside it and i suspect it tapers in at the middle too, although I havent removed my bushes yet to check. I won't be modifying the arm to fit anything different.
Bringing this back from the dead as casting my own bushes might be the only way to get bushes for my rear axle reaction arm since they are long NLA. Has anyone had a go in the last 5 or so years? I would want to cast them in a similar hardness to rubber, since it does need to flex and not be so rigid it breaks the arm (apparently a risk). The stock bushes are a weirdo shape, typically. The attached photo is what I need to replicate, and I could probably cast it in place in the arm if I needed, using some 3d printed moulds.
In typical fashion, my plan didn't work out, so now I'm onto Version Two of my oil pressure monitoring solution. I left off the last instalment with the pressure side of the gauge working, but I had not received the oil galley plug adaptor yet, so had not installed the temperature sensor. The adaptor arrived, so after work one night I quickly set about replacing it. I used a decent, firm fitting, 8mm hex socket on a ratchet to crack the plug. It has thread sealer on it and was in quite firmly. I originally fit the adaptor and then the sensor into it, but I would recommend fitting the sensor to the adaptor first and then screw the adaptor into the engine as it's easier to get it nice and tight and sealing well as one unit. I also noticed during one of my many times removing the sensor and adaptor that after the first install of the sensor into the adaptor, there were a couple of brass shavings that came out with the sensor, which is easier to clean out with the adaptor out of the engine. Anywho, the adaptor With the temp sensor screwed into it I crimped the terminals on the wires, and connected it up to the gauge (ignore the ugly tape, that is long gone) So, what was the issue? Well, temperature differential was my issue. I can monitor the oil temp with ODB2 in Torque, so it was quite easy to compare the gauge to what the engine was seeing Early on, when its cold, its fairly close But as the temps rose, the difference got greater. In the end I was seeing 10-15c lower on the gauge than in Torque I had heard that the galley on top can cause a difference, so swapped the sensors; oil pressure in the galley port, and oil temp in the front of the engine. It got worse Now not only was it slow to respond, it was miles out compared to ODB2. I suspect this is because the sensor was in the end of the long adaptor and no longer seeing oil flow, only pressure, so it was more measuring the ambient temp of the housing than anything. That was the final straw, a gauge that gives meaningless figures is useless. Oh, and it's bloody bright at night, even dimmed. With that failure under my belt, I looked around at my options. Annoyingly it seems pretty hard to find decent gauges, for a reasonable price, that have a PSI scale over 130PSI (my cold pressure). Normally I'm a diehard analogue needle gauge kinda guy, but I noticed with that one how hard it was to read at a glance and the accuracy was "maybe this much" at that low end of the scale, so I decided to try a digital gauge this time. I also scrapped the dual gauge idea and and settled on just a pressure gauge as thats more important since Torque can give me temperature for now (and I have an alternate solution in the works for temperature). I removed the galley plug adaptor and refit the standard plug, and swapped the pressure sender to the new one. It's a fair bit bigger than the previous gauge sender. Using the old gauge wires to draw the new ones through, I wired up the sender (albeit backwards in this photo, I forgot G is gauge, not Ground) Thankfully, it clears the stock airbox with plenty of room to spare And the new gauge. White during the day Dimmed and red during the night. It blends in very well with the stock gauges. Its a heck of a lot easier on the eyes than the last one too. It seems a little slower than the previous gauge to respond to changes, but it's a fraction of a second difference, really. You can see in the photos above that even at a glance it's super obvious and easy to see what the pressure is. Over all, I'm happier with it, and hopefully it'll give me some peace of mind when I take it on the track next month.
I used the term "veteran" as that's what NZTA calls "classic" cars over 40 years old, so when they check the NZTA site they don't get confused
Vehicle 1 - being a "veteran vehicle" in NZTAs books, will be reduced rego costs and is not subject to continuous licensing so you have two years of not being registered before it lapses. It cannot be driven on the road without rego either way. This site will give you the rego cost https://rightcar.govt.nz/rego/ Vehicle 2 - Buy 3-12 months rego, for the cost of the rego and away you go. Costs are in the above link. All the information is on the NZTA website.
We used to have this at a dealer I worked at, and it was amazing for cleaning wheels with baked in brake dust. Brutal and nasty stuff though, but my wheels went from a weird browny tinge that didnt wash off, to bright silver. Reading what it actually is, i'm surprised we were allowed to use it with zero PPE. https://www.pacer.co.nz/product-group/1806-mag-wheel-cleaner/category/285-wheel-cleaners
One thing I have been chasing since getting this car is backlash and thumping from the rear diff when coming on and off throttle or changing gear; I finally sorted it. Cleaning the throttle body and changing the gearbox oil had helped a lot in driving smoothly, but there was still what I would consider too much thumping and backlash in the driveline when coming on and off the throttle. Driving slowly in start stop traffic was pretty terrible. To try and combat this, I ordered two sets of inserts from Whiteline; A gearbox mount insert and a rear diff mount insert kit. I started with the gearbox mount insert. I was going to order an STI mount to replace the stock one, but decided on the Whiteline insert mostly based on cost. There isn't much to it, it's literally a moulded piece of polyurethane that gets installed in the mount, to take up the voids in it. The instructions call for completely removing the cross member and mount, but the internet said I could install it much easier with just some careful jiggery-pokery, and the internet is never wrong. This guy here is what we are working with. The insert goes into the gap shown by the arrow, which allows the insert to take some of the weight/force, instead of just the two blocks of rubber either side of it. I found since my mount has about 190,000km on it, it had compressed enough that I needed to jack the transmission up, this was done with a bottle jack and a couple of blocks. I did have to remove the rear black undertray to access the bottom of the transmission. This is the only bolt you need to undo to fit the insert. It goes through the bottom of the mount, to the flat square block of metal in the above photo of the mount - Its kinda T shaped. Once the nut is removed you should be able to push the whole bolt upwards by hand. This is how you slip the insert in. I jacked the transmission up until I had ample space in the mount Thoroughly grease the insert with the supplied grease and then using one hand to hold the T bolt up and out of the gap in the mount, use your other hand to slide the insert into place. Orientation of the mount is a little unclear, if the Whiteline wording should be visible from the front or rear, but as far as I can see it makes no difference, and I've seen others install it both ways. The instructions say to "slide the insert into the rear of the mount". Slip the centre bolt down through the insert, lower the trans down, refit the nut and then torque it to 40NM. To stop the T of the bolt twisting, I jammed a flat blade screwdriver in between the metal and the side of the mount. Job done. Quite easy to do when you don't need to drop the whole crossmember. I'm not sure why they say to. While in the area, the next part to install was the FactionFab rear shift carrier bush. This is another polyurethane replacement. It's a big, solid unit and comes with new bolts The old mount is held in place with two bolts. To gain better access, since it's a bit limited up there, I removed the two bolts off the driveshaft hanger bearing, and let the shaft droop down. This gained me just enough wiggle room to get a spanner up there and undo the bolts Using two hands, one on either side of the mount, wiggle and pull it backwards to remove it. It's a tiny little thing compared to the replacement. The rubber is very soft. Grease the spigot on the end of the carrier, and then wiggle and slide the new mount into place. Refit it with the two new bolts, bolt the driveshaft back in, and you're done. The difference in these two changes was quite noticeable. More direct shifts, less play in the shifter, and much better feel. I think most of it was the mount insert, but the carrier bushing can't hurt to do. Moving to the back of the car, I had high hopes for the rear diff inserts. These, like the gearbox insert, are designed to fill voids in the stock mounts and stiffen them up. The kit includes two inserts for the rear mounts, and two sets of inserts for the two front mounts. These are the front mounts, bolted vertically up to the subframe And the two rear mounts (foreshadowing...) I started with the front mounts. Using a jack I took the weight of the front of the diff and removed the bolt from one side The first part of the insert is a ring that slips over the top of the mount. Remove the metal cap sitting on top of the mount, pop it aside, and then offer up the ring. This needs to be worked slightly so that it hooks under the centre of the mount and wraps over the side. The ring is the shiny black part between the diff and subframe. Don't forget to refit the metal cap on top, this kinda just sits there in place, on top of the ring. Next is to fit the lower insert. This pushes into the centre of the mount and has two notches in it that locate on the protrusions in the bushing. The lower plate will locate in the bumps on the insert. Rinse and repeat for the other side, and that's the two front mount inserts done. Now, the rear. This is where it all turned pear shaped. First, remove the rear swaybar D bush mount brackets so you can move the swaybar to get more room This should give ample space for removing the bolts on the rear mounts. Do one mount at a time. I started with the RH one and soon found an issue. The bolt was really deeply recessed into the mount. I removed it and noted how weird the mount looked. It wasn't what I was expecting. There was zero chance that the insert would fit, the whole design and shape of the mount was wrong. Going by the paint pen X under it, I suspect the car failed compliance on a bad bush when it arrived in NZ, and to get it through the workshop fit whatever bush would fit the hole. It looks a bit like an IS200/300 bush from my googling, but definitely not the right one. It should look something like this, on the right, fitted to the subframe Anyway, the LH bush looked fine, so let's do that one. I removed the two bolts, greased the insert up and slipped it into place The alloy plate goes on and the bolts refitted. After torquing the bolts up, this is where I left it, since I couldn't do the other bush until I sorted a solution. The solution ended up being me ordering a new genuine bush from Japan, knocking the incorrect bush out, and fitting the new one with the insert. Easy, right? The bush arrived quickly, so the BRZ went up on axle stands New genuine bush and correct bolt The mount is vastly different from the currently fitted one I knew I wasn't going to be able to get the new bush in with the muffler fitted, so that had to be removed first. The bolts were a bit crusty, but heating them up nice and hot with a heat gun, soaking them in CRC and then a couple of ugga duggas got them off without issue. Unhooked from the hangers and removed. Tons of space now. I removed the swaybar mount brackets again and removed the centre bolt from the bad bush. Classic Bunnings bolt, a little different from the correct genuine one. I wound the new bolt into the diff, just to check the threads werent damaged. All was good, so it was hammer time. I'll tell you what, spending about 1.5 hours under the car swinging a 1.5KG hammer upside down above your head with limited room, is probably one of the worst jobs I have done in a long time. My arms are killing me now. I was using a combo of 1/2" extension bars (which will never be the same again) and a couple of long bolts, to hammer on the edge of the bush. There isnt a heck of a lot of room around the diff to access the bush. After many whacks, the bush finally started to shift The problem was that because I could only access one half of the bush, it kept trying to come out cocked on an angle and then getting bound up. To address this, I actually removed all but one of the bolts in the rear bush of the diff, which I loosened, and then lowered and shifted the diff across. This gave me more access to the other side of the bush. With the extra access, I managed to get the bush out straight to a point where I couldn't drift it out any further due to the inwards facing flange on the subframe. The trick here was to move to the other side of the subframe and start hammering the bush sideways back and forth. A few good whacks and the bushing just fell out. Comparing the two bushes, well, yeah. No wonder the diff banged around like it wasn't supported... it kinda wasn't; all the force would be acting like a big lever on the bush since it was only supported at the very outside edge of the bush. That bush couldn't have been doing anything once some torque was applied to the diff. The correct bush supports the diff through the whole length of the bush. Refitting, in comparison to removal, was very easy. I lined the bush up in the hole, with the locating arrows facing straight up and down, and then using a mallet knocked the bush home until the centre tube was touching the diff backplate. Using a ruler, I checked the bush was square in the subframe and tweaked as needed. And now, I could finally install the Whiteline insert for that bush. What an ordeal. Everything was torqued as per the Subaru manual As a slight side note regarding the front inserts on the diff, I had heard these can introduce gear whine at certain speeds, and unfortunately I can confirm this was the case. Having them fitted introduced a noticeable gear meshing whine at a couple of different road speeds, mainly around 70KPH and 100KPH, which sucks, since that's where most of my commute usually is. You would get used to it, but I hate noises like that, so opted to remove the two front mount inserts completely and only run the rear bush inserts. The result is no more gear whine, but most of all, the thumping, banging and backlash from the rear diff is gone. Finally, everything seems to be connected together, and it's a lot easier to drive now. I can't be 100% sure what was the inserts and what was just having the correct bush fitted, since I never drove the car without the inserts and the good bush, but either way, I'm happy. If they had just fit the correct bush in the first place, this job would've been done and dusted ages ago, but no, previous owners have been living with it like that and thought nothing of it. As a little bonus, it would be rude to have the rear muffler removed and not start the car, right?
- 94 replies
what sort of merc, is it old enough to do some Pick A Part lego?
Going a full circle into a Marina again. KwS's 1973 Morris Marina Coupe.
kws replied to kws's topic in Projects and Build Ups
Well, that's it, it's been six months, which means the WOF on the Marina has run out. So what did we get up to in that time? Not much. I covered around 150km total in that time, but other than some mishaps, the smiles per mile were high. One thing I had been looking forward to, after British Car Day, was a grass Motorkhana run by the local MG Classic Car club. It's close to where I live, and fairly low stress since it's on nice smooth grass. It'd be a treat for the Marina for being so good. Before then I had a couple of small things to sort. The main one was the valve cover gasket which had been leaking down the side of the head, onto the exhaust manifold. Not ideal. Quite easy to do. Whip off the six bolts on top From there, the cover just lifts off, revealing the pinnacle in 70s OHC technology After a good clean, a new gasket was fitted and the cover went back on I also replaced the fuel filter as I'm still running into issues where its filling with old fuel sludge from the tank. This was from just a couple of times driving it. Not as bad as the last filter, its not blocked, but still a lot of sludge. Before replacing the filter I wanted to try something; draining the tank through a filter and seeing what comes out. I fitted a new filter, rerouted the outlet of the pump into a fuel can, via a funnel and grips... And powered the pump directly from my jump pack I drained about 15L out of the tank, until the pump started to suck air, before hooking it all back up to the carb, refilling the tank with the fuel I just removed, and changing the fuel filter again. This was a new filter. It's not as bad as I thought, but still quite a bit of sludge. With another new filter fitted, a fresh 20L of fuel in the tank, we were ready to go A couple of weeks ago the Motorkhana rolled around, so I got up nice and early, bundled the tools into the support car and head off. Lots of awesome cars in attendance, and a bunch of great people too. Before long, we were queuing up ready for the first course. This was one of three courses set up for the day. Here I am, ready to tear it up Being one of the first cars through, the grass being very wet, and my first time ever doing something like this (let alone in a Marina), my times were... slow. Even with my complete lack of power, traction was non-existent. I got a pretty darn slow time, but who cares, I was having fun! I lined back up for another try This time the ground was a lot more torn up, less grass, more mud. Traction didn't improve... I went into it with a bit more vigour this time Still slow as heck, but went for maximum flair. The world's slowest steering ratio doesn't help when things get a bit crossed up, it feels like it's a million turns end to end That run looked like this from outside the car Leaning with intent Definitely slightly sideways I was having a darn good time, sliding the car around in the mud, even if I was way off pace. Having done that course twice now, I wanted to move onto the next one and see what that was like. I was inching forward in the queue of cars, waiting my turn. All was going well. Too well. The car was running great, the temps were good, everything was working. Until it wasn't. I pressed on the clutch pedal to move the car forward and bam, suddenly my foot was on the floor. Dammit. The clutch slave cylinder again. You can see me gently tapping the pedal to see what the state of it was. Last time this happened I stomped the pedal to see if it was jammed, this resulted in all the guts of the cylinder being ejected when the force of my foot pushed the piston out through the circlip. I didn't want to do that again, So I was careful not to press too hard. Thankfully my battery was fully charged, my starter a trooper, and I was on grass, so I could turn the engine over in gear and get it started, which allowed me to move the car off the line and back to the parking area. After popping the bonnet I could see what had happened, the large main circlip that retains the slave cylinder and stops it sliding backwards away from the clutch lever had decided to yeet itself and was no where to be found. Thankfully, the rest of the slave was still intact. Myself, my wife and a couple of other competitors had a good look around for the circlip, but it never turned up. As far as I know, it's still there, sitting in the grass. Broken or not, It's still a cool car After scrambling around for a bit, we eventually jumped in the support vehicle and shot home to see if I had a spare circlip. I did not, and could not get one on a weekend either. Damn. So, what does one do then? Zipties. All I needed was enough clutch to do a couple of starts at intersections on the way home, I could start it in gear to leave, and rev match the shifts without the clutch on the drive back. I secured the slave in place with 6 large zip ties, pulled as taught as I could given the space. We knew when the entry gates were being opened, so we left a little early. Starting in gear, and leaving it in first until I got to the gate, as its all low speed shared public access At the gate, waiting to be let out The drive home was fairly uneventful. The clutch worked, with a couple of pumps, for the once or twice I needed it, otherwise I kept it in second for maximum low speed grunt and with some creative route-taking, managed to get home without having to stop for traffic and avoided too many intersections. To my amazement, despite the heat down in that area, the zipties were all still present when I got home, albeit they were softening up as the clutch was barely working by the time I pulled into the garage. I'm not disappointed the car let me down, not at all, you have to expect things like this when pushing a 50+ year old car that until recently had been off the road half its life. I'm disappointed I didn't get more time out on the grass, doing sweet skids. I'm more impressed though that even though it broke, it still got me home under its it power, with nothing but zipties to fix it. Through the day the Marina attracted a lot of attention, particularly when the bonnet went up, but everyone was very positive and loved seeing it out there. There were offers of help, tools and one guy even offered to shoot home and get a metal detector to find the clip; none of which were needed, but very much appreciated. The whole community around entry level events like this is awesome. Once I got it home, I looked at my options. I could convert it to the UK style cylinder, which is a different shape and doesn't rely on a circlip to retain it, it uses the body of the cylinder, so it physically can't fail in the same manner. These are available ex UK, but are a pain to fit and I have already rebuilt my current Aus cylinder, so that'd be money down the drain. I decided to give the Aus cylinder one more chance. This time I grabbed some callipers and got measuring. It turns out when buying external circlips, you measure the body of the shaft its going to go on, not the groove it sits in I ordered some 35mm stainless external circlips online And after struggling with circlip pliers to fit it, the slave was once again back where it should be, less the zipties I did wonder if the fact the cylinder had been painted when it was rebuilt had anything to do with it. The circlip groove had paint in it, so before fitting the new clip I used a wire brush to thoroughly clear all the paint out of the groove. I'm not sure if the old circlip was wrong or just old and tired, but it was a very loose fit compared to the new one. You could almost fit the old one by hand, the new one takes a bit of force and work with circlip pliers to get in place. The clutch pedal feels a little firmer now, but that could be a placebo. I took the Marina for a really good, hard, run over some twisty back roads near home and the clutch seems to be operating 100% fine now, with no signs the circlip wants to jump off again. I will call it a success for now, but keep an eye on it (and a spare clip and tool in the boot). That brings me to today, where the Marina now has no WOF and cannot be driven on the road until it is renewed. I have chosen not to renew the WOF for now and will instead take the car off the road over winter. During the last check, I had an advisory for the bushes on the rear diff reaction rod being perished, so that will be high on the list of things I need to do, but there is also a reasonably big list of work I would like to complete before its back on the road, one of which is upgrading the suspension, and I plan to get the twin carbs on too. Heck, If I get around to it, the door cards need trimming too. So, here we are again, the Marina is off the road, but with a clear plan in mind. We will be back, better than ever, ready to do more KM than the last WOF period, and next years Motorkhana.- 80 replies
- 22
The final lot of work in the week since I bought the car, was to sort out some shifting issues Since I got the car, I had some drivability issues. I've previously mentioned the throttle and clutch response being an issue, but the gearbox also shifted pretty badly. There is history of the gearbox having been rebuilt not long after the car was imported a few years ago, under warranty, due to a "whine in 3rd gear". I confirmed with the workshop that did it that yes, it's been rebuilt, but no they didn't retain any info on exactly what was done. It's fine when driving, no whine now, but the shifting is pretty crap for a box that people rate quite highly. When cold it's very hard to shift, and when warm pretty much every gear is notchy to shift into, and often crunches. There is also a fair bit of play in the shifter when in gear. After extensive reading, I concluded that the gearbox fluid needed to be changed, and I wanted to try the uprated shifter springs to see if they made an improvement. Other than money, I had nothing to lose trying this. I ordered some uprated shifter springs and three bottles of the recommended Motul Gear 300 75W90 gearbox oil The car went up on the Quickjacks, for my first look under it. Over all, it's very clean under there with minimal concerns. All the suspension bushes appear to be in serviceable condition. I started with the shifter springs. To access the gearbox I removed the rear under tray (the black tray, not the silver one), which is secured with a whole lot of 10mm bolts There are two springs, one either side of the gearbox This one uses a 10mm hex. There is VERY little room to get this one out, so you will have to use a hex key, not a socket. I had to dig deep through my roll cab to find this as I normally use sockets or my big hex keys which had no chance of fitting. The other is easier to access Both were very tight. I guess when they were refitted after the rebuild, on the bench, they were done to FT (F'n Tight) instead of NM. They had also been refitted with good old grey RTV, which was a pain to clean off. That second one uses a 27mm socket, and is a lot easier to access if you have a flex head ratchet. I had to use a cheater pipe to crack this one Yay, sealant Remove the springs (the one behind the 10mm plug may need a pick or magnet to slide it out) and replace them. Refit the plugs. There is a lot of talk online about cross threading the big one in the photo above, but just take your time to refit it by hand. Put some pressure on it, rotate it backwards a couple of times, and then it should wind right on in by hand with minimal effort. I couldn't get the torque wrench onto the 10mm one, so did that up gutentight by hand, and used the torque wrench on the 27mm one. With the springs replaced, I located the drain and fill plugs on the side of the gearbox Which are both 10mm hex. I cracked the upper one and then removed the lower drain plug to release a torrent of thick and quite dark fluid. The level was right, and no chunks came out, but the fluid wasn't pretty. I cleaned the small amount of sludge off the drain plug magnet, replaced the crush washers on the plugs (18x24mm alu) and refit the drain plug. I started to refill by using the nozzle on the bottle, but ended up sticking a pump in the bottle and pumping it in to the gearbox as it was quicker. After about 2.2L went into the box, and it started to trickle out again, I refit the fill plug. A quick clean with brake clean, and we were done. I refit the under tray, and lowered the car down. Up top, I replaced the battery. The sticker indicated that it had been replaced at 56,000km in 2017 (Heisei 29) The cranking was quite slow, and I really didn't want to get stuck somewhere. I whipped the old one out And stuck a nice new one in. Shame to lose the cool blue Subaru battery though Cranking is much faster and more powerful now. While under the bonnet, I also enlisted the help of my wife to bleed the clutch. It's a weird system on this, where I couldn't one-man bleed it. If you push the pedal down with the bleeder open, it didn't push fluid out, you have to pump the pedal and hold it down with the bleeder closed and then open it to release the fluid. The pedal also gets stuck to the floor due to the helper spring. I definitely got some air through the hose, and the clutch does feel a bit less vague now. So what's the verdict? Well, It's like a new, better, car. The throttle body clean I mentioned in my last post made a massive, completely unintentional, improvement. I can only presume the throttle plate was getting stuck closed and opened once a sufficient amount of angle/motor torque was dialled in by the pedal (usually around 15-20%), snapping it open. Now it opens straight off the pedal being pressed, and the response is significantly better. I no longer use the throttle controller to dull the pedal response, I may even start using sport mode. Secondly, the gearbox fluid completely changed the feel of the box. No longer is it stiff and hard to get into gears, it's a lot smoother, but all the notchy and crunchy shifts have completely gone. It went from a gearbox I legit thought was on its last legs, to one that's pretty good to use. Not MX5 (or Alto) levels of accurate and smooth, but much better. The shifter springs have also taken out a lot of the in-gear play in the shifter, which makes the selection of gears more accurate and it no longer sort of wobbles into gear, occasionally being blocked by the gate. There is still some play, but it's no longer an issue. The combination of these fixes means I no longer bunny hop and jerk away from a stop, and it's made the whole driving experience much more enjoyable. And finally, the last improvement until the next lot of parts arrive, new tires and an alignment. I knew the rear tires were bad; the previous owner warned me one would need replacing for a WOF, and the other was new, but mismatched, from having a puncture. The fronts, appeared fine. Knowing I was going to want to drive this car spiritedly, I ordered some Bridgestone RE003s, in the stock 215/45R17 size. I can now confirm you can fit a full set of four in the car. Today, I dropped the car in for the tires to be swapped over and an alignment. I'll tell you what, I'm glad I did. First, the front tires were also trashed. They're cheap ditch finders, but it turns out the inside edge of both were chewed down to the secondary rubber, so they're no good. One rear was also worn down on the inside edge. The fronts One surprise to me with the old tires was how soft they are. After handling the RE003s which are quite a firm carcass, the cheapies have no structural integrity at all. The sidewalls squish under the weight of its own mass, and the belts in the tread just sink down if you apply any pressure. The alignment explained it all though; the excessive wear, the weird tracking, and the shaking when driving. That's a heck of a lot of front toe. The RH front was 4mm toe out, and the LH front was 2.2mm toe in, basically driving like this / / but with one side pointing right almost twice as much as the other. I could do with some front camber though... Driving down the road now, I could immediately feel the car was smoother. I didn't realise it must have been shaking or something at lower speeds too, as it feels different even around 50kph. The steering is more responsive and no longer wanders down the road. Of course, I had to break in the new tires, so a quick drive over a local hilly road was in order. Suddenly, after all this work, the car finally felt cohesive and like it was all working together, not trying to fight itself. It feels very good to drive now, and I'm finally bonding with it, instead of just liking it, seeing the potential in it, but being annoyed by how it feels. I still need to clean it, but here are a couple of quick photos with the new rubber
- 94 replies
- 18
Yes, you can check on the Subaru Japan website, and this one has had both recalls carried out.
Next on the list of things to quickly knock off, I wanted to install a proper gauge to measure oil pressure and temp. I had planned to install a temp gauge in the Alto but never got around to it, so knowing that the BRZ would be seeing track time and I wanted to monitor it, I looked into my options. I wanted something clean, simple and easy. The solution came in the form of an Saas Dual gauge It's really designed for oil pressure and coolant temp, which is a weird combo, but there is no reason it should have issues reading oil temp. I ordered a gauge and a couple of adaptors to mount the sensors on the FA20. The next question was how to mount it. I wanted it subtle, and not sticking up in a pillar mount or something. Searching around, I came across vent pods, which allow you to mount a gauge in the right-hand dash vent, which seemed like a nice tidy way to do it. I found one on Thingiverse and tried to print it on my ancient old printer, which didn't go well. Thankfully, a friend has a much better printer and kindly ran one off his machine for me I quite like this design as it still allows for airflow through the vent instead of completely blocking it. To install it, the dash vent just pulls out. Stick your fingers in the vent and grabbing the outside edge, give it a sharp pull As a small note, it fits back in with the large bit of the surround facing the cluster. I marked the top of mine to make it easier to refit without guessing which way it goes Once removed and on the bench, the front ring just unclips As does the retaining ring behind it Now the vent flaps can be removed The vent pod insert was a smidge too small on the outer diameter, so I wrapped some tape around it to make it a snug fit I used some foam tape to pad the back of it out too After a quick scuff with some scotchbrite to dull the gloss, I reassembled it all Now for the less fun part, the wiring. I knew the under dash wiring would be easy, the option connector has everything I need, but getting the two sensor wires from the engine bay through the firewall was going to be a pain. To power both the throttle controller and gauge from the option harness I needed to make a Y splitter, so I whipped one up For the sensor wiring I chose to go through the main grommet, using the add-in tube thing I snipped the plugged end off the tube above the main wiring harness And using an old coat hanger, I fed the bundle of wires through You'll want to use a zip tie to seal the tube around the wires once you're happy with their length. I ran the wires to their relevant locations on the engine. I haven't received the adaptor for the temp sensor yet, so I have just bundled the wires up where they need to go, but I could fit the pressure sensor. That big round plug is where the temp sensor will go once the adaptor arrives. I'm going to tee into the factory pressure sensor here, on the front of the engine To access this, I removed the intake pipe and air filter housing A ton of room with that removed I fit the adaptor and the two sensors This location gives heaps of room to clear the air filter box. The wiring for the stock sensor sits well below it. Before refitting the intake piping, I removed the four 10mm bolts from the throttle body, removed it and cleaned it. It was caked in black sludge. I wedged the throttle pedal down and used brake clean and a rag to thoroughly clean inside it. With the intake reassembled, I moved to installing the gauge into the dash. I ran the wiring through the vent, plugged the gauge in and pushed it into place. There is a bump on the LH side of the ducting behind the vent, this gave me room to feed the wires out without cutting into the ducting. I pressed the ignition button and it all lit up A quick first start to make sure it all worked and check there were no leaks. Pretty good pressure when cold. Without the temp sensor, the digital readout just sits at zero. Good oil pressure when warm too. This is at 89c oil temp Once the temp sensor is fitted, I will rely more on the actual gauge rather than Torque, but it'll be interesting to compare the difference between the two. Hopefully this will let me catch any potential oiling issues before they become a problem.
Having arrived home with the new car the day before, I took no time at all to start ripping the car to bits. The first thing to fix was going to be the head unit. I had previously purchased another of the cheap Android units from AliExpress, the same I had used in the Alto, in preparation to fit it in my next car, so once I bought the relevant wiring and fascia adaptors, I was ready to get stuck in. I started by removing the surrounding trim, which came free by hand Where I immediately came across my first problem. Being the stock head unit, it still had the stupid security screws fitted. As if anyone wants to steal a stock head unit that badly. Nothing a garage full of tools can't fix though. A small bolt extractor was the perfect solution Upon removing the unit, I was greeted by the obligatory JDM nest of wiring behind the head unit It took a lot of work to unpick all the wiring and dump what wasn't needed All the black wires with the square plugs are for various antennas around the car, which would require a lot more disassembly than I can be bothered with, so they were bundled up, taped up and zip tied out of the way. This left with me with the two main connectors, the FM antenna harness (with adaptor) and a 5 pin connector which has the reverse camera trigger on it. As a side note, the wiring adaptor required is for a Toyota, showing the car's shared roots. In NZ it's an Aerpro APP0141 I also needed some little filler plates for either side, since the standard head unit is wider than a normal Din unit. These were Aerpro ATB2 Along with all the wiring for the head unit, there was also wiring for the ETC unit in the glove box, which all had to come out. This turned out to run all along the dash, to under the steering wheel Where I also found this weird bundle of wires with heaps of unused bullet terminals As it turns out, this is actually a genuine accessory. Part number H0077AL000 - Option Harness, which ties into the car harness and gives a bunch of "outs" to use for various things It appears the DRLs tie into it, as does the ETC unit and reversing camera trigger. Very handy! Anyway, back to the head unit. This is where it all started to turn a bit pear shaped. The Android unit is very shallow, so the brackets need mounting holes quite far forward (an issue I had in the Alto), but putting the two side by side looked like I should be good The filler plates needed some modifying to clear the mounting brackets. I had to cut a lot more out of these later on A quick test fit in the surround. It's VERY tight, I suspect the Android unit might be a fraction taller than the Din standard. I cut the ISO plugs off the adaptor harness, and wired it to the head unit wiring, ready for a test boot Excellent, everything seemed to be working. So now it should just be as easy and screwing it in and pushing the surround on over it, right? No. This part of the job took the longest. In the end I had to file the mounting holes on each bracket into slots, so I could lower the head unit down as it mounted too high and clashed with the dash, and finally it took me a while to realise the filler pieces needed to be moved backwards a hole, and can't mount flush with the unit otherwise they actually try to share space with the surround, which is no good. This took a horrible amount of test fitting, back and forth, to get it to fit right. In the end though, it finally did And the two reasons I wanted this unit, worked The audio quality, like in the Alto, isn't great, but the original head unit didn't sound amazing either (clear, but lacking bass), so I'm not sure if that's just normal for these. At the end of the day, I just want background music for commuting. Most of the time when driving this, I'll want to be enjoying myself and concentrating. The main function is Waze and being able to use Torque Pro. Speaking of Torque, one function that was missing from the Alto is present on the BRZ; engine oil temp. This isn't the final layout, but good for testing. This has to be added with a custom PID in Torque, based on instructions in this thread here and using these settings OBD2 Mode and PID: 2101 Minimum Value: -40 Maximum Value: 215 (this is just the maximum that this location can support, which does not mean the sensor can read that high) Scale factor: x1 Unit type: C Equation: AC-40 (no space between A and C; "AC" is the location within the response) OBD Header: 7E0 (Auto also works, but seems to take longer) Seems to work well and responds as expected. I still really rate these little cheap head units. They're far from perfect, and if you're into good audio I wouldn't bother, but for the functions they offer, it's hard to beat. One last little bit of work, while I was under the dash, was to fit my Pivot throttle controller. By some miracle, this car uses the Toyota harness, which I happened to have already since I last used this on the Yaris. I disconnected the throttle pedal harness and added the Pivot harness in line I tapped into the option harness for switched power, connected the ground to a bolt, and job done. The main reason to add this wasn't to improve throttle response, but to actually dull it down. This one does both Sport and Eco modes, and as I found out, turning it to Eco2 was enough to dull the pedal response and make the car more drivable. This was just masking an issue I would find the solution to later on.
Thankfully yes, this has a digital speedo. I can't imagine having to live with just the analogue one, the scale is so cooked that it goes to 260kph and 50kph is a twitch of the needle from zero. Apparently these have a 180kph speed limiter anyway, so what sick joke is the speedo going that high?
It'd been an interesting month or so since I sold the Alto, trying to work out what on earth my next project would be. Finally, It fell into my lap. I knew the criteria. There were a few reasons to sell the Alto, and one of them was to experience a new platform on the track. I felt I had reached the limits of what that car could do without dumping a bunch of money into it for bigger turbos, new wheels and tires etc. This meant I was looking to move away from FWD and get a RWD or AWD car. Being manual was non-negotiable. The other goal was to try and reduce the amount of money I had tied up in the Alto. That last one was actually much harder than I expected as all the "fun" cars had "fun" tax on them. My options were really limited; An MX5, an Altezza or some sort of Subaru. Nothing else really fit the price range. So that's where I started. In terms of Subarus, I tried to avoid pre-Y2K as older than that involves 6 monthly WOFs, and I can't be bothered with that, so that left with me Legacys or bug-eye onwards Impreza. Anything STI was out of the question, I couldn't afford that performance, but it still had to be a turbo. The options for WRXs were limited. There were a few bug and blob WRXs floating around for a good price, but they all carried huge Ks (usually around 300,000km) with questionable histories and modifications. I didn't want to buy a time bomb. The uncertainty around these led me to look at the newer hatchback style Impreza, as they still came in turbo options, manual, AWD, and usually with lower Ks as they were newer. My wife and I did a couple hour round trip to look at the first one. A black 2007 Impreza S-GT, the JDM narrow-body WRX. It'd been for sale for a while, and the seller did advise that the last WOF had a note for underbody rust on the rear subframe, but otherwise the car was "all good". The rust wasn't too much of a worry as long as the rest of the body was solid, as I could wire brush and treat the subframe. This car looked good from a distance, but as I walked toward it (from the rear), I immediately noticed really bad "orange peel" in the rear quarter panel. Being in the industry and having seen it all, this put me on alert straight away. The more I looked, the worse it was. Rust bubbling in the roof gutter at the rear, bad paintwork, rust starting on the boot floor where the rear panel had been cut off and replaced (along with a tell tail paint pen "cut" line). The seller told us "oh yeah it had a small nudge in traffic a couple of years ago". Yeah, his definition of "small nudge" might differ from mine, when it appears the whole rear end had been cut off and rebuilt. It probably wouldn't be an issue for most people, but it would always bother me. I took it for a quick drive anyway to see if it was worth the effort to fix it up, but although the 260hp and AWD felt nice, it just didnt really inspire me. The price was also too high considering the issues. I walked away. Next was a New Zealand new version of the same car, a 2009 WRX, also in black. Long story short, this too had been in a rear shunt, with a misaligned tailgate, both rear quarters had been repainted, and there was a lovely patch of cracking bog above the rear wheel, with rust bleeding stains under it. I didn't even drive this one, I just thanked her for her time and left. As a change of scenery, I had been watch a listing for a 1993 WRX "Version 1" but hadn't been able to get in touch with the seller before someone else bought it. This was an exception to the rule, I love these old GC8s but the prices are getting insane, so when it was relisted a little further up the coast for a similar price, I jumped to contact the seller. Already alarm bells are ringing, why is he selling it so soon? He spun a story about needing the funds, but in truth I think he bought it without inspecting it and got stung and needed to offload it quickly. One day after work I drove up the coast and went to view the car. I knew from the previous seller that there was some rust, and he had provided a couple of photos showing it was in the top of the front guard and in the rear door, both replacable panels, but he hadnt supplied photos of the rust in the boot he mentioned. Viewing the car, the rust was far more extensive. In a quick look, I found a rust bubble in the front chassis rail, rust bubbling along the top edge of the rear guard, and worst of all, the seller pointed out the rust in the boot; basically the whole rain channel under the rear glass, on both sides where the hinges are, was made of bog. Cracking, badly painted and rusty bog. When I mentioned "heck, I didn't think it'd be that bad", the seller replied "neither did I". Ouch. I walked at that point, you'd need to either reshell that car, or gut it and spend months cutting all the rust out and rebuilding it. The final Subaru I looked at was another NZDM WRX hatch, this time in silver. Much to my surprise, this one had also been crashed. I knew it was rough, and had a couple of dings, but it was priced well, so I could've overlooked those, but this one had a new curveball, rust. It wasnt huge, but there were definitely rust bubbles down the LH A-Pillar by the glass, and at the top of the hatch opening where the hinges are that someone had tried to paint over. When asking about things like cambelt and service history I got a lot of blank looks, so that didn't bode well. I took it for a quick drive to see how it went and it was fairly disappointing. The clutch feel was horrible, and the brakes had a massive shudder, so work was obviously needed in those places too. I'm quickly finding out that these WRXs were often bought by families and are just "a car", with little care given to what they are or how to properly look after them. It's a shame. So, whats next? The old Toyota Altezza was in the price range, and with 200hp on tap with a 6 speed manual and torsen LSD, they should be fairly fun. I've owned one before, and although it was a nice car to drive, it always felt a bit underpowered for the body, and wasnt that exciting. This lead me to consider a couple, but not bother looking at any. Finally, it was MX5s. I looked at three. I'll start with the one I walked away from as soon as I started it up; an ND1. It's a gorgeous car, and even the massive stupid wing didn't look too bad in photos (although in person it looked 100x bigger). This had some seriously questionable mods though, one of which was a painted on Union Jack on the soft top (why). The worst though was the exhaust, which I don't think had anything resembling a muffler. I got in, pressed the start button and was immediately greeted by the loudest car I have ever been in. My wife was standing just outside the open door, and I couldn't hear her talking to me over the exhaust. That exhaust, and the fact that the car was so small and cramped for my rather generous frame, meant that I had to walk away. That left me with a pair of NCs. I've also previously owned an NC, and really enjoyed it, so knew one would go well as a track car. Turners Damaged Auctions was the location of the first one, an early NC1 RS soft top. It had high Ks, appeared to have been sitting outside for ages, had some cosmetic issues, but otherwise if it went cheap enough I was prepared to fix it up and thrash the pants off it. Even if the engine was bad, I had planned to 2.5 swap it. I went and viewed the car, since by some miracle it was at the local yard Externally, it didn't look too bad. The brown soft top needed some love, there was a ding in the RH rear arch, and the front bumper was... trash. The inside was pretty good too. Some wear, but with over 200,000km on it, it's to be expected. It also had a broken front quarter window. The underside is where it got a bit iffy. It all appeared to be surface rust, but there would be a few hours worth of work under there scrubbing it with a wire wheel and then treating and painting it. The auction rolled around, and with a fixed price limit in my mind, I was ready to hit the bid button. The bidding started and ended about a grand higher than my limit, so it wasn't to be. Interestingly about a week later it popped up on Facebook with a new reg and wof, a repainted front bumper, replaced window and dyed soft top for significantly more than he paid. Can't argue with the hustle, at least he did some work to fix it, but I can't help but wonder how much work he put into the underside, or if he just blasted paint right on over the rust. Finally, the last NC I looked at was a PRHT NC1 at the infamous "shite car dumping ground" dealer Everything about it was right. The colour, the spec, the power hard top, manual, LSD, cloth interior, and something like 130,000km. I jumped at the chance to view it bright and early the next morning. They had it parked out front and center, where it was catching some attention, paint shining in the sun. After a good look around, issues were coming to light. The term "polished turd" was coming to mind. The tires, although good Michelins, were about 10 years old and hard as plastic. The engine was weeping oil in a couple of places under all the dealer spec shiny slime, and there was an excessive amount of wear in the interior for the Ks; it was ageing worse than both my old one and the Turners one above, which both had over 200,000km on them. I jumped in and took it for a drive anyway, as I can fix all of that, for a price. The drive showed me three things; I like NCs a lot. The thermostat was stuck open so it never came to temp, and the rear shocks were poked. The slightest bump would have the rear of the car slamming violently down onto its bump stops. Horrible. I had the same issue with my old NC, and spent a not-insignificant amount to fit a pair of new shocks to fix it. Pulling back in, the salesman comes up, beeming, practically rubbing his hands together after running them through his slicked back hair. His face dropped when I said its got a couple of serious issues, the thermostat is stuck open, the rear shocks are stuffed and the tires are borderline dangerous, would he work with me on a better price? "The boss drills into us every Monday not to drop prices" is what I got told. They "might" take it to a workshop and have them "look" at the thermostat and shocks, but I wouldnt count on either of them being fixed properly, if they even acknowdleged there was an issue. It's no wonder they're (proudly) sitting on a massive inventory of cars that never seem to sell. I decided to leave it at that point. The price was too high, they were asking a premium price for a car that needed some significant work. If they would've worked with me to drop the price a grand or two, it would probably be in my driveway. After viewing the other hunks of junk in the mean time, I actually went back to the dealer the other weekend, a couple of weeks after first seeing the car, with the full intention of dropping the asking price on it and driving away as it is. This time it was in their shed, under the artificial lighting. The more I looked at it, the worse it looked. The paint was fading and peeling in places, and it just didnt have that shine from last time. With a heavy heart, I walked away again. Now, there is one other car that fits the criteria almost to a T. The Toybaru twins; the Toyota GT86 and Subaru BRZ. I had been writing these off as the prices were just too high. I couldn't justify dropping $16-17K on a high KM one. The autos were cheaper, but stuff that. These guys have the concept right. Modern, light weight (just over 1200kg), RWD, Manual, and a responsive 2L flat four "Boxer" engine. They were a collaboration between Toyota and Subaru. Both cars share the same basic shell, driveline and interior, but the differnet brands gave them different faces and trim levels. The BRZ is generally considered a bit more upmarket than the 86. So, the other day whilst flicking through Marketplace, wading through all the trash, I spot a new listing for a 2012 BRZ. Oh, it's manual. Price is pretty decent too; a bit lower than usual. Within a couple of hours of it being listed, I had interrogated the seller, got sent a bunch more photos, and made a slightly silly offer, which had been accepted. The seller was really upfront. It has 190,000km on the clock, so its lived a life and has some marks to tell it, but he sent me photos of every little mark inside and out. Anything I asked, he tried his best to answer. A couple of days later, where I lived in a constant state of "he's going to sell it out from under me", he met me in the agreed town, about half way between where he and I lived. I look over it, take it for a quick drive, and deals done. We wait about... 2 hours for the bank to transfer the cash, and then we're off home. Sitting waiting for funds to clear... The two hour drive home was interesting. I quickly learnt the car had some flaws. The most obvious one was that the JDM stereo was still installed and I had no idea how to connect my phone to it. Que two hours of jamming to the Japanese pop music that I found stored on the headunit internal hard drive. I got a couple of interesting looks gound through the small towns, cranking that, arm out the open window... The other big issue was the throttle response and clutch control was terrible. Taking off from intersections resulted in either bunnyhopping away, or nearly stalling it as the throttle did nothing. I got a bit more used to driving around it, but it wasnt that much fun. I'm also forgetting that the car came fitted with a lovely sickly sweet air freshener in the cup holder, which got so strong and unpleasant I considered throwing it from the moving car to get rid of it, but in the end I handed it to someone to throw in the bin at the next stop. Oh, and the last surprise was that the car has a pretty bad shake when travelling over 100kph. I'm hoping this is the mismatched cheap ditchfinders that are currently fitted. Anyway, I made it safely home and although I was off to a bit of a rocky start to the relationship, I still enjoyed the drive back. It was a very pleasant car to drive. If I were a Youtuber, I'd say something like - I BOUGHT THE CHEAPEST MANUAL BRZ IN THE COUNTRY. But I'm not, so... yeah, I did though. It was fithly, but I couldnt help myself from stopping and grabbing some photos. Being an S trim level, the highest in this model, I also ended up with some goodies like dual zone climate and heated half leather seats Along with red stitched leather padding around the place. A previous owner had ticked a couple of boxes too, which left me with an STI skirt kit (except the front lip which has been replaced with a knockoff due to an incident with a possum), LED "dayliner" DRLs, the red STI start button and the previous owner added the rear spoiler with STI gurney flap. Over all, its a stunningly good looking car. The World Rally Blue paint and STI skirts are what really tipped me over to buying this one. All the others that were on the market tend to be black, white or the odd red one. I'm also a fan of it being the Subaru variant as I feel its the most true to its heart; the boxer engine. So yes, thats the new toy. I have a big list of things that need doing, and before doing any actual "upgrades" I really want to get on the track and get a baseline first, so I know what to improve on.
- 94 replies
- 18
Update - After a quick test with my GPS, I can confirm I made the speedo no more, and no less accurate than it was. It still reads exactly 10KPH under, but the response of the needle to speed changes is significantly better than it was. I would suggest using the calibration dot mentioned above, but in my case I guess my "by feel" calibration was good enough.- 80 replies
My book covers the six, I just haven't been bothered to go upstairs and look 😅 That would make sense about the diff ratio, It's why I presumed it was from a six
Selling the Alto had an interesting unintended benefit; it has allowed me to get the Marina out and use it more since it's not blocked in anymore. Using the car more has shown up a couple of small issues here and there. Nothing too major, except the speedo, which decided it didn't feel like reading correctly anymore. A couple of years ago I replaced the speedo cable with a nice new one as the old one came out in multiple pieces The speedo was working fine, albeit reading low, until a couple of weeks ago where I noticed the speedo was starting to play up. Starting from a stop, the speedo was unresponsive until I got a few KPH under the wheels, and then it jumped up to the correct speed and worked OK from there. The issue got worse the other day, where not only would it take time to jump up to speed from a stop, but it then started to stick at speeds too. I would be cruising along at 50KPH, and if I sped up or slowed down within about 10KPH, the speedo would still be stuck at 50KPH. As soon as the difference was more significant, the needle would jump to the next speed and stick there. This was no good, it's bad enough working with an old inaccurate speedo, but one that sticks is just not gonna fly. I did notice that the odometer was still ticking along correctly and didn't appear to be sticking, and having replaced the cable, I suspected it was binding inside the speedo mech. Googling Smiths speedometers (the most common design around this age), I learned that the needle has no physical connection to the cable and instead uses a spinning magnet bar inside a metal cup. The magnet creates a magnetic field in the cup, which causes drag on the cup, which turns it and with it, the needle. A hair spring on the needle shaft creates the opposite force needed to drop the needle to zero again. I read that there are a few points where this mechanism can bind up and cause the needle to stick, so the plan was to strip down a spare speedo and see what's what, before servicing my actual one. The spare one gave me an idea of what I was working with, so I proceeded to remove the cluster from the car As a side note, the Aus speedos use a threaded fitting for the cable, whilst UK ones use some sort of clip. UK Spec Speedo Aus Spec Speedo Before removing the rear screws, you need to remove the glass and bezel first, which is held with three metal clips The glass and bezel can be removed The actual speedo is held in place with two screws in the back Compared to the spare speedo I have, which I suspect was for a 6 cylinder, the graduations are different and the REVS/KM also differs 4 cylinder speedo is in both KPH and MPH 4 Cylinder 1750cc 160KPH (Possible) 6 cylinder 200KPH The 4 cylinder speedo is 680REVS/KM whilst the (possibly) 6 cylinder one is 840REVS/KM as shown on the bottom of the face, and on a sticker attached to the rear Having the two side by side showed the issue when I drove both of them with a drill inserted into the cable hole. The "good" spare responded quickly and to small changes in speed, whilst my original one seemed almost dampened in comparison, slow to react and only moving for bigger changes. At least that confirms it's not the cable or gearbox drive. Anyway, moving on from nerding out, let's strip the speedo and see if we can fix it. First, remove the needle. Much like the tacho, I used some cardboard to protect the face and then a pair of small screwdrivers to pop it off. Make sure to lever the needle on top of the two little screws on the face, as this is the strongest area, otherwise you risk bending the face With the needle removed, I then removed the pair of small screws on the face and removed the face The odometer mechanism is quite cool. Externally very simple, although I'll admit I don't know what's going on inside the number wheels to make them turn, but on the outside it has a little arm that is driven by a worm gear, which other than the magnet bar, is the only part actually directly driven by the cable. The other end of that gear is a little offset cam, which is what moves the arm. The offset causes the arm to move back and forth, and also up and down. As the arm moves down and reaches the bottom of its stroke, it moves towards the toothed wheel, engaging with it and turning it as the arm moves upwards again, which advances the odometer, before again moving away and down. The spring keeps tension on the arm, making it pivot on the body of the speedo instead of just flopping about. Start by removing the small spring on the odometer mechanism Followed by the little clip holding the arm on. This is removed by lifting the end of it up, so the hook clears the arm (orange arrow), rotating it slightly so that the hook doesn't pop back in (green arrow) and then sliding the clip so that the pin moves to the bigger hole (red arrow) and then the clip can be removed The arm can be removed next. This allows us to remove the four screws on the top plate, which will separate the two halves of the speedo mech Be careful here, since we aren't unhooking the spring, you need to lift the metal cup off with the top plate. It's only retained by the spring, so don't let it hang, or it can damage it. This is the magnet bar, which creates the magnetic field to drive the cup. The needle shaft locates in the hole in the center, but this creates no physical drive of the shaft. This recess needs to be cleaned out thoroughly. I used brake clean and a very fine small paint brush. The other area I found to be in need of a good clean was the drive gear for the odometer, it was caked in dirty, crusty and sticky old grease. You can also see the offset cam that drives the arm, here. I removed the drive gear (slides out of the body of the housing) and thoroughly cleaned it before refitting with some silicone grease. Interestingly, I found the actual magnet bar to be quite stiff, sticky and did not spin freely by hand. I suspect this could've been the cause for the old speedo cable failing. I hosed this in brake cleaner, particularly around where the cable enters, whist spinning and rotating it. This eventually freed it up so it spun with minimal resistance. Lots of dirty black muck came out with the brake cleaner. I carefully used some very light oil to lubricate the mechanism. One or two drops under the big worm drive gear, and one at the edge of where the cable enters. I also used a small amount in the recess where the needle shaft sits. Once I had cleaned up any extra oil and made sure when spun by a drill there was no excess oil being flung about, I carefully reassembled the speedo and refitted it into its housing. I've since been told, regarding the below, that the correct baseline calibration point is to align the needle with the small dot just below the stop (by moving or removing the pointer) so please keep that in mind. I will have to test and calibrate mine accordingly. One thing to note when reassembling is the tension on the needle. With no tension, the needle is free to just float around and doesn't care about returning to zero To add tension, lightly press the needle on the shaft (barely pressed on) and hold the needle down against the stop. Whilst the needle is on the stop, gently rotate the metal cup a small amount in the clockwise direction (orange arrow). This will add tension to the needle. Add just enough that it drops smoothly down to the stop and stays there. If you add too much it'll actually create excessive resistance on the needle and the needle will stop increasing with speed as the magnet cannot overcome it. Apparently too little tension can cause some needle bounce at low speeds. Once happy with the tension, press the needle in place. Initial testing with the drill shows a good improvement, with the needle responding much faster and to smaller changes, much like the spare speedo does. I have only had the chance to take the car for a quick run around the block, but during that drive the speedo responded perfectly, so hopefully it remains working. It'll also be interesting to see if the accuracy has improved any.- 80 replies
- 17
Wait, so every replacement shock that isn't OE requires a cert, adjustable or not?
