Everything posted by SOHC
What NGK plug would cross reference with a Champion D16? I lost my sparkplug book
SOHC replied to h4nd's topic in Other Projects
- 1292 replies
Took the gearbox apart and as allways 2nd gear has gone through the cace hardening, on the lookout for a clutch, I need the clutch for when I make the engine plates
It must have a little regulator for the direct AC lighting? Or is it like a BSA Bantam and you miss a gear and burn out the headlight. Outer calliper piston seals can fuck off especially on a dirt bike
Got this motor today, it’s an industrial motor but has the mag out the back witch makes things way more easy, it was from a rotory hoe that had a stuffed gearbox and other problems so I didn’t feel so bad.
I ordered another ignition, this one is a little big bigger and has a some charging coils. I really hope I can fit it between the frame and the engine, failing that I can cut the whole thing off the engine and extend it and the cover and weld it back on so the mag is in front of the frame.
T/S main bearing has a bit of play, it may be why the thing was parked up, I have to strip the whole thing anyway
- 89 replies
Cut the starter snout off and melted it down into blobs then I have welded up the hole and the script with it using the oxyacetylene, you can use all the crap to your advantage, it works like a flux.
- 1292 replies
- 24
- 1292 replies
- 22
I hate this flux it balls up and rolls away, I use to like that pink shit made by CIG
Well I think I got scammed on a cylinder head, payed a guy for a motorcycle head but no head yet. the one on this engine has the Finns going in the wrong direction for a motorcycle, but apart from that the JAP engine is an ok fit, I have over 50mm to make a new ignition system. A shit load of work is needed now
Don’t run it with the battery disconnected bad things happen
The mag and it’s spacer is a good 150mm long, if I made something that supported the drive sprocket and I could mount this to might be a go. Then I it would fit well.
This engine is also a contender for this project, it seems to be in very good condition and has never been apart. Problem is the mag is in the way of the frame, I am thinking of making up a plate with a trigger coil and running a CDI ignition or something
Made this flathead holder for when I pick up my new motor, supports the engine by the exhaust flanges, as it will be put into the back of my Volvo with a fork lift and dragged across my driveway and into the shed.- 1292 replies
You dissing me and I didn’t see it? -
Rear wheel bolts in witch saves a huge amount of work, those plungers are stuck, been soaking them in oil
It fits well, I would have to make some kind of ignition system as the mag won’t fit with the gearbox
