kpr
KPR's 84 Hilux
77 posts in this topic
Discussion Thread
Yeah I brought another rusty Toyota. Farmer spec.
Actually is surprising how solid it is, panel work is super rough. but have had a good dig around and its the least rusty toyota yet. only surface rust in a few places, no holes!
321046369.jpg?
dsc02755s.jpg?w=900
Plan was to take it out in the mud then make a few changes. But found a few things needing some attention first.
Wheel spacers
dsc02739s.jpg?w=900
Something not right here. hub gears don't exist inside. guessing they removed the guts after breaking it, then kept driving.
dsc02752s.jpg?w=900
DICK's
dsc02741s.jpg?w=900
7 people like this
Share this post
Link to post
Budget officially blown.
Was not planing on doing this until something broke and if i actually like the truck.  Money was meant to go towards some sweet wheels and tyres,  but since the driver side hub was non existent and i hate fixing stuff. I'm throwing all the good stuff at the front axle while its apart.  hopefully never have to fix it again
Big brown box
dsc02761s.jpg?w=900
Original 30 spline longfeild axles/cv's
Chromoly hub gears
Auto locker etc..
dsc02762s.jpg?w=900
dsc02764s.jpg?w=900
Been fixing the guards.  still look bit shit, but better than the rest of the truck.
dsc02757s.jpg?w=900
3 people like this
Share this post
Link to post
I feel like this whole topic should be moved to fabrication cock-ups thread
turns out the crown wheel is stuffed too
dsc02786s.jpg?w=900
sussed a hi pinion  front diff today.  in the correct ratio  ( 4.8 )
dsc02787s.jpg?w=900
Just because you wanted to see it again,  some more chrome diff case
dsc02784s.jpg?w=900
The ends of the case were pretty carved out. So have attempted to repair
dsc02771s.jpg?w=900
Tried not to put too much heat into them
dsc02773s.jpg?w=900
Have lost a little bit of diameter, but seals should hopefully still be tight enough.  At least they wont get carved out first turn of the wheel.
dsc02779s.jpg?w=900
Tomorrow's  job. Make these bits go into above bits
dsc02790s.jpg?w=900
2 people like this
Share this post
Link to post
Auto locker installed
dsc02792s.jpg?w=900
These bearing shells came out of the swivel hubs,  pretty tired!
dsc02801s.jpg?w=900
Got a high steer kit to replace the horrible factory setup. Stock stuff was pretty worn out,  so its getting ditched while i'm under there.
Arms are huge compared to factory
dsc02805s.jpg?w=900
Front axle back in, everything has been replaced. just need to rebuild brake calipers and its good to go.
High steer kit doesn't agree with factory suspension and sump. the black arm is just sitting there. will be hard up against sump when bolted on.
dsc02822s.jpg?w=900
Picked up some parts off a mate,   ifs steering setup for the high steer, and turbo stuff off a surf, just for lol's
dsc02802s.jpg?w=900
Moved diff forward 30mm for more clearance.
dsc02819s.jpg?w=900
Mockery  thread seems to be here :
http://oldschool.co.nz/2011/forum/index.php?/topic/44791-kprs-84-chromelux-discussion/
2 people like this
Share this post
Link to post
So after buying the hi steer steering kit.  I did some research, seems its made to work with a 4" lift..   Not keen.
Cut the shit out of the sump, which gave just enough clearance, at full suspension compression.
dsc02829s.jpg?w=900
Then tried to fit the ifs steering box, hmm thats not gonna work.
dsc02854s.jpg?w=900
Best way around it was to drop the front spring mounts. seems to be a very common mod, for various reasons.
dsc02879s.jpg?w=900
Goes here.  Mounts are dropped about 40mm.  will lift the truck around 1inch i'm guessing. is a bit of a dick to get fitting nicely, as the cross member is a bit bent up
dsc02884s.jpg?w=900
4 people like this
Share this post
Link to post
Steering box fits!
The mounting kit didn't locate the steering box in the correct place for my setup.  Angle grinder fixed the problem.  Tig'd the plates to the chassis.
dsc02889s.jpg?w=900
Got it back on the ground, on the new wheels. starting to look a little less farmer spec
dsc02900s.jpg?w=900\
Had to remove the wheel spacers on the rear!  They went all out and used spring washers.   These are all off one side
dsc02898s.jpg?w=900
Need to remove the radiator, to finish some welding and make a bracket for the ps pump. then should be able to take it for a test run
5 people like this
Share this post
Link to post
Rear sump, extra deep. It's 2 16v sumps cut up to make one.
dsc03069s.jpg?w=900
dsc03070s.jpg?w=900
5 people like this
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
