About Firebrand
- Birthday 08/31/1982
Contact Methods
Website URL
https://www.instagram.com/tetsuoworkshop/
Gender
Male
Interests
Electronic Music. Maps. Random Exploration.
Local Area
Wellington
Firebrand's Achievements
Advanced Member (3/5)
291
Zac's 1982 Starion, Steering into the OCD Skid.
Firebrand replied to ProZac's topic in Project Discussion
Looking good, the passivated hardware comes up so nice. Maybe it's time I updated my build thread also since there's a bit of a trend going on around here at the moment. -
Firebrand replied to tomble's topic in Project Discussion
Hey, nice purchase, and good luck! I *might* have a spare Starion distributor floating around, I'll have a hunt around for you just in case. I've also got a small pile of grey starion interior bits and a dashboard if you are keen on it, I converted my previous car to black interior so I still have a few leftovers. I was pretty much going to throw them out if I couldn't find anyone who wanted them, as the grey parts aren't that popular. Flick me a message if you are keen. I'm (very slowly) restoring an 87 Starion, in Lower Hutt so not far from you.. As @ajg193 mentioned there's a few guys on here who know a lot about these cars. -
yeah that was my one.
I'm on the second starion, the NZ New one - sold the first one just before lockdown, but haven't been on here much lately. I have a spare cowl/scuttle/whatever, but it's a bit stuffed also - rusty in all the usual places, so you haven't missed out on anything!. I'll see if I can get some photos and do a build update later in the week.
Nice project! The Starion I'm currently doing up is in a similar state, and rusted out in most of the same places (some better than yours, some worse). I'm trying to tackle all the repairs myself so those shots from the panelbeater are very useful haha. I'll get off my arse and update my build thread eventually.
this is for sale now -
Just a quick update on my Mirage, progress has been pretty slow... I've cleaned up the remaining Interior bits, replaced the carpet with some from a Nissan Primera that I ended up wrecking a while ago. After sitting around for ages it didn't really want to start - but I threw in a new battery, replaced the fuel filter and cleaned & re-gapped the spark plugs. Managed to get it to fire up with a bit of engine start, but it wouldn't idle, and was backfiring out of the carb. After a couple of hours of adjusting the carb, and a few bursts of carb cleaner, it seems to be running pretty well now, definitely a bit rough still but at least it starts by itself, idles & runs Ok. Next step is to get underneath as there's a bit of a water leak somewhere, and then start on getting the body a bit tidier. I'm still looking for a rear seat & a windscreen if anyone has them lying around.
Mitsubishi/Todd Motors Heritage Day - April 15th, Porirua
Firebrand replied to xTerraH's topic in Lower North Island Region
I'm not sure they'd let my car in...would be cool to go to though. -
Firebrand's Mitsubishi Starions (Past & Present)
Firebrand replied to Firebrand's topic in Projects and Build Ups
Life got in the way and things took a bit longer than expected, but the new clutch is in, new Main seal is in, new front transmission seal is in. Bellhousing nice and clean. Flywheel machined and new pilot bearing installed, and new thrust bearing. Not many photos - assembly is the reverse of removal etc. I tried my best to torque everything to recommended settings etc. Clutch in place: Everything is back together, and I took her out for a short drive this afternoon. All seems good so far, feels much nicer. Pedal needs a wee bit of adjustment but it's perfectly driveable now. -
I've got this manual which has specs for the 4G32, 4G33 & 4G37: https://1drv.ms/b/s!AjIWJwhrv2O0wkM5Ti17CoD983K_ (link is just to my private onedrive, so totally safe - if it asks you to sign in there should be an option to skip it and go to the doc). Looks like most of the specs are the same across the 4G3x range, but that might be a good starting point if you haven't already got it. No 4G36 in there directly sadly.
Yeah that's a good idea actually, might as well do it all at the same time.
So for the last little while my clutch has been slipping a bit, but it became more of an issue a couple of weekends ago, just revs going up and speed staying the same. So I thought I'd have a go at doing a clutch change for the first time. So i jacked the car up nice and high, removed starter motor, driveshaft, and gearbox. Had a quick check underneath the car and it's looking pretty good, a few spots of surface rust I'll tidy up before I lower it down. old clutch is pretty worn out: so I'll be replacing it with this nice pink one, it's a heavy duty (but still street) one, so should handle a bit more abuse than the old one - kit came with new thrust bearing and the little one that goes in the flywheel also: The inside of the bellhousing is caked with black shit, which I'm guessing is mostly transmission fluid, so I'll clean that up and replace the front gearbox seal also. The flywheel looks OK, but to be on the safe side, and since I don't really want to pull it out for a while I'm going to get it machined before I put it all back together again. -
Otaki Old School meet: completed
Firebrand replied to Hobbs_E21's topic in Lower North Island Region
That was fun, nice hanging out with y'all! -
sounds like a plan! I'll be there -
If it's on 14/15th I should be able to make it
