It sucks and I should have looked closer. But thanks @cletus for making me have another look .
Now I need another block and another gasket set.......better now I suppose
  • Sad 12
Do I need a wastegate actuator? Or weld the bugger up?
And if yes to wastegate control....how much PSI is a good place to start?
The turbo im using is a twin entry TD05HR-16G  From an EVO 4
Max about 22psi and flows about 500cfm..
And also how do you adjust the fuel to compensate for the boost
Cheers
Got a few things done on the old LD28.
*thermostat housing on .. drilled out
And tapped for
*temp gauge and them sensor to turn on and off Fan
Oil gallery T in (small one) so I could get the new oil pressure sensor in and turbo oil feed
git the oil filter and housing on with new water lines and clamps
Starting to come together....
now I took a bunch of photos of things when i.pelled the motor out of the rover and  lost of them..
soooooo.... let play
*WHAT THE FUCK IS THIS
*OR WHERE THE FUCK DOES THIS GO
1.i take it this is the main fuel in
2. Where does this go
3. Where does this go and what is it
4. What is this......and what do I do with it... (pretty sure Harry told me..I forgot though)
5.is this where I adjust the amount of fuel
7. This is oil in right
20241207_191048.jpg.32abc6319d8df84bd6af782cac831647.jpg8. And this is drain back to the block
9.where the fuck does this go and I'm pressuring its water?
10. Does ut go here?.. if not ..where the fuck does this go.⁸
11. Now where does this go
12. now what does this do.
And the motor out of the rover didn't have one
Thanks for any help...
To late to mention i know nothing about these motors.
  • Haha 1
Ok
Whats needed to start the ld28 on the engine stand ..
Just want to see if it runs.
*Flex plate is on
*And can bolt a starter motor to it.and add power to the starter
*can run a hose from a bottle of diesel to pump
What else do I need to do?
Cheers
Sorry been pretty busy doing house stuff so havnt done much with the LD28.
But on Sunday I got it to the point I can try and fire it up....
Annnnnd  it won't....fucking thing!!!
The fuel cut switch that was on the pump that came with the motor that was in the rover .. had no plunger (fuck knows what its actually called ) ..it was just the top part.
So I put one out of another pump I have here in .
I pulled the pipes off the injectors to bleed the diesel through  but I was just getting a dribble at maybe 4 of them.
So I pulled the pipes of at the pump its self and swapped the fuel cut switch to the one that was in the pump (no plunger thing).
And while cranking ( even bought a big heavy duty battery). It just spitting st bedt out of maybe 4 of the 6.
Is it likely to be the pump itself?.
Or a bleeding issue?
https://youtube.com/shorts/dryOLrbjqEg?feature=share
