ul9601 Posted August 30, 2024 Posted August 30, 2024 If anyone happens to be heading that way, it'd be cool to have RHS monsoon shields front and rear picked if in good shape. cheers Quote
Bluebird_U Posted September 6, 2024 Posted September 6, 2024 Whats the procedure needed to remove them? Might be going past at some point this weekend. 1 Quote
ul9601 Posted September 6, 2024 Author Posted September 6, 2024 1 hour ago, Bluebird_U said: Whats the procedure needed to remove them? Might be going past at some point this weekend. i think it's the typical arrangement with clips on the top window channel and double sided tape. the fiddly part is to get the clips out without cracking the plastic. its got a few clips (3 for front and 2 for rear) and double sided tape on the top edge and also a little pad at the B pillar ends. probably a fishing line or a skinny jnr hacksaw blade to cut thru the double sided tape and hopefully the clips fall out. have a quick practice on the rear left side and see how easy (or not) before spending too much time. tbh im terrible at this myself, destroyed a few of them at PaP practicing lol. here are some photos of them off car. cheers Quote
Bluebird_U Posted September 18, 2024 Posted September 18, 2024 Went down on the weekend but someone had already been at it and had broken the front one in half when removing the window glass. The rear one is still intact (in the boot now). Once the plastic rivets were popped all that was needed was to cut the double sided tape. With the windows up I dont think theres any way to get at the window seals and see how the metal tabs are attached. 1 Quote
ul9601 Posted September 18, 2024 Author Posted September 18, 2024 lol you know the pick a part way - smash everything out of the way and then some just because... will PM. Quote
