2 hours ago, 440bbm said:
Didn't notice you mention that you had another 20m of 25mm hose at the end of that 140lm.
The 20m of 25mm hose wasn't installed when I did the visual checks on Tuesday, so you didn't miss a thing. Your advice has been spot on.
I'll have a look into 50mm hose (thank you, I hadn't thought of that), but a 50mm hose would be a heck of a weight to be dragging around a building site, and unfortunately I need it 20m long to get to all four corners so I'll have to make a compromise somewhere. I just need to decide if it's expense/noise/flow/pressure or convenience that I want least. :-)
Edit: I'll do some additional flow checks without the nozzle, then without the hose, hose tail etc.
Both the upper 'tap' and lower tap will be identical setups.  I.e. 40mm LDPE>40mm ball valve>25mm hose tail>20lm 25mm PVC washdown hose>25mm hose tail>Skellerup Master Blaster nozzle
Ah yes gotcha. There will have to be a compromise somewhere. Maybe its best to see about a pump setup on it. then you can keep everything you currently have and don't have to compromise that part, the compromise will be just be on your wallet  haha/
I forget you are over in timbuktu so just not as easy for you to just get some 50mm hose or whatever, so not ever easy fr you.
Thats a good plan.  I used to buy alot of the 2" wb20 pumps and went well. used to be re-fitted and ( slightly modified ) mounted to helicopopters.  Assuming the smaller series is as good as the larger 2" you will be fine.
