  • Replies 184
  • shizzl
    185
Assembled the doors today.
new rubbers for the glass slider thing bits (makes it tight and quite stiff to operate now) hopefully it’ll loosen over time.
fitted the new door locks and weather strips.
glass got cleaned and 1/4 windows refitted. But if a shame the rubbers for these are a little nasty.
fitted the new inner door rubbers, but Jesus the doors have to be slammed to get it to latch. Please tell me they will flatten quickly.
also started connecting wires. Got the headlight/park light circuit finished.
piss easy seeing as I landed everything.
boy thing I need to figure out now is how to set it up to run a solenoid to turn on the fuse box on acc.
the constant 12v (key, hazard circuit, park lights) will be fused between the circuit breaker and fuse box.
hope that’s right.
would love a hand with this wiring stuff to make sure it is right.
Not looking likely that I will make this deadline.
off camping with the tribe of ungratefuls.
will only have 8 evenings to get this finished.
all brake lines/hoses
engine/box
deck panels and windscreen/rear glass install.
and sort the speed sensor, fuel tank and lines and decking.
dammit
  • Sad 1
I finished the brake lines!!!!!
only have the brake hose mounts to weld into the diff to complete this, then bleed it up.
clutch needs to be an AN line with a 90 degree fitting off the master.
I used BG familia rear hoses on the back.
then the Mrs gave me a hand to drop the motor in.
i also found a pin hole in the factory fuel tank just as I went to install it, that got yeeted the fuck out into the yard.
so then I spent too long trying to get the fuel cell fitted up.
finished the fuel lines, pump and just need to finish the tank mounts.
didnt want a tank visible inside the deck, dammit.
  • Like 9
Oops forgot the pic of the tank.
not going for a big tank. The hunter ends up having stale arse fuel in it as it is. Don’t want stale premix in this.
better to fill more often
