  • Replies 116
  • rivalrx
    117
Car was running rough and I noticed milky radiator water….no overheating though and water level was good.
decided to comp test and replace head gasket to be safe.
comp 140-160psi across all 6 cylinders which is good.
there was definitely a compromised head gasket on the firewall end of the block which is pretty common.
I forgot to mention the WOF guy mentioned. that the lower linkage to the trans (base of the box) needs a new bush. That should really tighten the shift action.
schloppy
  • Haha 1
Got a shipment of new rear amber tail light lenses. In they go!
Guess I need to get the red lenses now…
I also got super low front springs and some chrome door lock knobs too. Those don’t screw in so I may need to drill the centres out a touch to make them work.
So I cracked into slamming the car - first stage is the front.
Dobi sports appear to be LOW and the shocks were the original Ford ones 50psi S years old. Absolutely shagged too.
New super low kings and short konis in - one side down and one to go later today.
having trouble loading photos here as per usual….
  • Like 8
Once both sides are in, I can let the car settle and then see where I net out. The super low kings are for 6cyl and the old Dobi sports are the same height but substantially thicker. Potentially worth me hanging onto them as they could sit the car spot on when a v8 is added.
or I just just the correct v8 springs when I need to.
auto is slipping in reverse and I need to see where I can adjust the bands on an old Borg Warner auto - if anyone knows holla
