ul9601 Posted July 4, 2022 Share Posted July 4, 2022 Can anyone pick a part for me at Pick-a-Part in Tauranga? (There is another one in PaP Wellington, so I posted a separate post earlier on Lower North Island thread too. Nominal said he might be going there some time, but keen to get hold of one wherever, if someone near Tauranga is going there, that's cool too.) Should be a real simple 5 minute job - A reverse light off a facelift Y11 Nissan AD van (car number 329) Open the tailgate, rip out the tailgate trim panel, undo 10mm nut then free the U shaped retaining channel (spread apart the open end then it can be pulled from inside), the lens assembly can be pulled from outside. Will need the lens assy, retaining clip, the retaining nut and the bulb holder to go with it. It should be free of defects like cracks or chips but I can live with small scratches. Cheers. Quote Link to comment Share on other sites More sharing options...
Bluebird_U Posted August 24, 2022 Share Posted August 24, 2022 Did you have any luck with this? Wont be around till next weekend if you still need it. Quote Link to comment Share on other sites More sharing options...
