Yo, quick question.
I have a jvc head unit kw-m150bt. It has 4 wires for the steering wheel control stuff. In the manual these are grouped as two programmable signal wires and a ground, then another wire labelled as 'steering remote control wire'
As the volume controls are on the screen and not that easy to use, I want to set up two momentary switches on the dash and program them as up and down volume.
I should be able to get the up and down using the simple circuit on this page;
https://www.hackster.io/SetNFix/diy-car-steering-wheel-controller-with-volume-control-1b201b
So the question is what do I do with that control wire? Is it just connected to the acc circuit or do I just ignore it?
I think you would use the one in the left or the three on the right , but not all. Factory fitted steering wheel controls (in Toyota at least) Have one output. Each button has a different resistor, so the stereo sees a different voltage for each button and knows what to do.
Alright, that make sense now. The group of 3 are customisable in the head unit, so I probably just need one resistance between them....
43 minutes ago, AllTorque said:
They may not even need a resistor.
Yea, turns out if I ground out one or the other I can program volume up and down, I guess I can get technical with play pause later if I get excited.
Cheers for the help....
