The first task was to replace the factory carb. I pulled the plugs and it was obviously running super lean and on top of this i am sure that the vacuum secondaries weren't working. I couldn't find a rebuild kit for it so replacement seemed like the best option. I went for a 32/36 Weber because I have had good results with Weber's in the past and I find they are easy to configure and tune for different applications.
I managed to rework the throttle cable hardware from the original carb so it would work with the Weber.
It was a little fiddly but ended up working very well.
  • 6 months later...
If anybody knows where I might find an inlet manifold for a RWD SOHC Mitsubishi 4G63 engine please let me know.
I will need one to hack about (modify) in order to make this work.
Amazingly a few parts have shown up during lockdown so on with the show!
The fuel pick up strainer arrived so I got the fuel pick up reinstalled and also mounted the electric fuel pump.
I started installing the fuel lines however I ran out of 5/16 fuel hose so the last little bit will need to wait.
I got the position of the fuel delivery device sorted so I trimmed the manifold flange, I am happy that everything fits right where I planned so that's a win.
Old bogans will recognise the unmistakable shape of a Holley 2300 flange.
  • Like 9
