anglia4 Posted September 3, 2024 Posted September 3, 2024 man I love the plate on this thing 1 1 Quote
Gobler Posted September 29, 2024 Posted September 29, 2024 On 24/05/2020 at 17:48, siren676 said: Did a little clear out of the garage during lockdown and found my wheel collection so decided to test fit them and see what size flares i need to make. Need at least 60mm for the 6 black wheels and 90mm for the formula mesh. Fitted a Momo Prototipo i forgot i had bought. Picked up a wood lathe and did a couple of near 500kg dump runs. And worked out how to get a stock looking tachometer into it. Discovered on a Japanese forum that the Mitsubishi Townbox dash cluster has identical wiring, just need to run 1 wire from the ecu to the cluster for the tach signal. Works perfect, has a dual trip meter and now know that the limiter is at 7500rpm. Did you do the wire? Asking as I’m about to do the same, if so where does it run too/from? Please and thank you 1 Quote
siren676 Posted September 30, 2024 Author Posted September 30, 2024 1 hour ago, Gobler said: Did you do the wire? Asking as I’m about to do the same, if so where does it run too/from? Please and thank you I used this guide. Goes from one of the coil trigger wires on the ecu to an empty pin on the stock gauge plug http://www.teeart.net/junk/mncb1.html Quote
