Popular Post vk327 Posted September 10, 2019 Popular Post Posted September 10, 2019 Since iv entered this thing in OS drags this year, its about time i chucked up a post about one of my latest money pits.... 1986 VK Royale (vk and a half efi 3.3) After a palmy swap meet road trip a couple of years ago in this VK my mate Chris offered me this... so it came home with me. I drove it for a while as is fixing a few issues and decided to sell off my other VK as a rolling body (kept the 327 for our HQ more in that some other time) also kept all the good bits for this one (suspension seats etc) then came the decision to do something different... and so it all started with a cheap second hand gt35 turbo off facebook (which turned out to be rooted) then came the Garrett turbo and the turbosmart bits and the link G4 and the gearbox, clutch, driveshaft and the full engine build.... and into the pit of $$ this car goes to save me rambling on Ill let the pictures do the talking.... also discuss here: 11 Quote
Popular Post vk327 Posted September 10, 2019 Author Popular Post Posted September 10, 2019 had to move a bunch of wiring so rewired with an under dash fuse box , had the whole setup fitted to the old 270000k engine, made 168rwkw and 598nm of torque, annnd 3 days later blew the rear main seal coming back from kumeu in january. since then its been torn apart new rebuilt engine painted bay and a whole lot of other little things 10 Quote
Popular Post vk327 Posted September 10, 2019 Author Popular Post Posted September 10, 2019 engine cont. 11 Quote
Popular Post vk327 Posted September 10, 2019 Author Popular Post Posted September 10, 2019 finally got a use for my VS HSV seats, painted the bay, and wired up the factory dash to be fully functional 12 Quote
Popular Post vk327 Posted September 10, 2019 Author Popular Post Posted September 10, 2019 got it all pieced back together and running ready for Cert and a tune, also picked up a mint set of 16x8.5 &16x9.5 Vette wheels 17 Quote
Popular Post vk327 Posted September 10, 2019 Author Popular Post Posted September 10, 2019 Passed clean sheet thru cert so stoked with that, brought myself a new toy so wish i had done it sooner. Took it up to Protune to chuck on the hub dyno... and my waste gate is too small, spiking 18psi of angry boost pixies at 3500rpm, aiming to run 7psi base with control up to 12psi to avoid splitting the crank from the block, ah well least the tune is now safe till i can fit up a larger gate. Oh also the camaro t5 gearbox i had fitted was stuffed so in a week had a commodore v6 t5 input shaft modified to fit, fabricated a new mount, bolted that up last wednesday and drove 1200km around northland for gumboot rally over the weekend, which Im super happy with how the car went, super responsive and torquey down low even with a low MAP/RPM limit, plus all the Spooley turbo noises 31 Quote
Popular Post vk327 Posted October 3, 2019 Author Popular Post Posted October 3, 2019 Had a rocker adjuster come loose sounding like an angry dwarf with a pickaxe stuck in the top end, easy enough fix didnt break anything and was just down the road from home. Decided to throw some more $$ in the because turbo bucket, brought a new 50mm wastegate to sort out the angry boost pixies, Booked for back on the dyno the week before drag day.... 17 Quote
vk327 Posted November 25, 2019 Author Posted November 25, 2019 Well back on the dyno at protune yesterday, made some good power (175rwkw 445nm at 11psi) but found an oil leak, seems like this car just dont like dynos haha, at least i was only cleaning up an oil puddle on the dyno and not engine pieces Got home and checked it out, pulled the clutch dust cover...bonus its not the rear main rope seal. Waiting on an engine support bar to arrive and il drop the sump clean it up Gonna weld in a couple of sump breathers and go to town with the rtv Oh and all before drag day... 9 Quote
Popular Post vk327 Posted November 28, 2019 Author Popular Post Posted November 28, 2019 So after a few hours sleep after nightshift, got keen and stuck into pulling the sump since another new tool arrived the engine support beam made this way easier than having to pull the engine. Got the k frame out, sump off, welded in a couple breather fittings and went to town with the rtv and new gaskets. Pics tell the story better, also pic of how iv done the external 5/8" oil pickup in the sump. Fingers crossed this sorts the leaks. Bring on drag day 11 Quote
Popular Post vk327 Posted May 21, 2020 Author Popular Post Posted May 21, 2020 Post drag day have been daily driving to work, broken another 2 t5 gearboxes one blew a 3rd syncro the other sounded like an angry chipmunk so now running on a Frankenstein box made from 3 parts boxes, iv decided to splash out and get a jzx110 r154, waiting for my billet adaptor to gm bellhousing to arrive from the states and will be getting it fitted up and the clutch modified again, bonus is shifter in the right spot and cube speed short shifter off the shelf but need to make a new longer halfshaft, cue the i need a lathe for ....things talk with the Mrs (too late its already ordered) (also the you need another gearbox why?) haha 14 Quote
vk327 Posted May 13, 2023 Author Posted May 13, 2023 Well been a few years, but time for an update on the old vk, been a busy (and expensive) last 6 months with stripping this thing down rust repairs changing up the motor a bit and getting it repainted on the slow task of putting it all back together now Rust repairs around the rear window & boot lip, gave it a nose job with a New old stock radiator support to replace the buckled twisted one 9 Quote
Popular Post vk327 Posted May 13, 2023 Author Popular Post Posted May 13, 2023 Stripped all the old dulux dulon gold off back to bare metal on advise of my painter got it in epoxy primer and enlisted help of a panel beater to make it straight 11 Quote
Popular Post vk327 Posted May 13, 2023 Author Popular Post Posted May 13, 2023 Decided more power was required so new sonic injection intake manifold & new turbo manifold built to fit, also upgraded to a new g4x monsoon ecu so built a concentric twist mil spec style wiring harness and decided to put ac back in so have put alternator back where it was originally it's tight around the wastegate but it just fits 14 Quote
Popular Post vk327 Posted May 13, 2023 Author Popular Post Posted May 13, 2023 Just a couple weeks ago got it back from the painter looking super sharp in BMW pyrite brown, and running the lower trims and bumpers in vl MX grey, onto the fun task of putting a fresh painted car back together https://oldschool.co.nz/index.php?/topic/61662-vk327s-1986-vk-royale-with-boost-discussion/ 38 1 Quote
Popular Post vk327 Posted May 19, 2023 Author Popular Post Posted May 19, 2023 Slowly getting time to work on this between customer jobs and the 2 kids my spare time is pretty stretched, super happy with the 2 tone colours 24 1 Quote
Popular Post vk327 Posted August 23, 2023 Author Popular Post Posted August 23, 2023 More progress happening slowly,engine wiring all finished and engine bay plumbing/assembly coming along, still have to wire up under dash and add the water meth wiring, got the gearbox and drivshaft back in with the new concentric slave setup. Finally had a nice day to get it out in the sun and see how the new paint looks 34 Quote
Popular Post vk327 Posted October 25, 2023 Author Popular Post Posted October 25, 2023 Been chipping away at the massive list of jobs still a heap of little things to finish up but... new headliner in, fitted all the seals and in with the glass, trims and interior back together, just finished off all the plumbing and wiring tonight just the AC lines left to finish once I fit the evap core. Getting close to firing it back up again as soon as I get the rocker cover & taillights back from pinstriping. then I'd better get onto assembling the pile of stainless I have here into a new exhaust. Hopefully have it all sorted an back on the dyno for tune tweaks all before drags 29 1 Quote
Popular Post vk327 Posted October 31, 2023 Author Popular Post Posted October 31, 2023 Been smashing thru the jobs, brakes and clutch all bled up, had the dash out and back in to refit the ac core with new tx valve, finished all the ac lines and pulled vacuum so that's all ready to gas up. Powered up and configured the new ecu, tested everything from the ecu and sensors all working. Flushed and pressure tested the fuel system, dump pipe off the turbo all welded and wrapped. just leaves the rocker cover to fit and exhaust to build Speaking of Rocker cover, I just picked up that and the rest of the bits from pin striping 17 Quote
Popular Post vk327 Posted November 1, 2023 Author Popular Post Posted November 1, 2023 So stoked with how this turned out. Probablly fire it up this weekend just the exhaust to build and be ready for dyno and off for a wof 22 Quote
