Popular Post Stu Posted July 4, 2021 Author Popular Post Share Posted July 4, 2021 Oh yeah, I also added this turd to the fleet. I have no idea why, seemed like a good idea at the time. Will likely move it on if anyone is interested. Its a 1985 EP70, that someone has spent alot of time/effort/money into squeezing a silvertop 4age into. Its quite hilarious to drive and unlike my blue car it doesn't try to kill you. Comes with a Link g4+, coil overs, si interior, rear disc brakes, etc. If I keep it I'll turn it into a track hack. It needs some new panels and a few bits so if anyone knows of a reasonably tidy EP70 going or not then let me know - just needs to be tidy. 15 Quote Link to comment Share on other sites More sharing options...
Popular Post Stu Posted August 9, 2021 Author Popular Post Share Posted August 9, 2021 So i made a thing from ali this time Will likely bomb it black at some point, its a bit too shiny for me. Thanks to Richie i now have some cam covers that have the lower bolt provisions for the COP plate so im working on getting those tidied up, modified for breathers and painted. I've also been making a few brake hard lines and about to start buying the ecu and sensors etc. 19 Quote Link to comment Share on other sites More sharing options...
Popular Post Stu Posted October 4, 2021 Author Popular Post Share Posted October 4, 2021 Lockdown didn't quite provide all the spare time I was anticipating due to picking up a heap of essential work, but I have been ticking away at this thing. I've been wanting to get into the wiring so have been putting in a few hours here and there. Wiring is something Ive done alot of over the years so while I don't enjoy body wiring that much, I am looking forward to getting into the ecu side of things. The whole idea with the wiring is that the engine/ecu wiring is plug and play so if I ever wanted to go back to a stock engine/ecu (I wont) then it wouldn't be a total nightmare to do. I hope it means the car will retain its value better this way. Way back when I stripped the car for painting the front end wiring loom ended up stashed in a box which gathered dust, but I hauled that out and started pondering things. I wanted to make a few small changes to the factory front wiring like shifting the washer pump wiring from the factory location behind the passenger strut tower where it will melt due to the heat from the headers, over to the factory 85 location on the drivers side. I also wanted to take out the air con wiring, re-route where the loom runs and tidy up a few other things. So the loom got stripped back, I traced all the plugs so I've got notes on what goes where with wire colours, then got to work. I removed all the aircon wiring but kept the circuits intact with notes on what connects where so if I want to later down the track I can overlay that loom and plug it all back in. I laid in the new washer wiring but de-pinned, insulated and hid the original wiring so it can be uncovered and repinned later on if the washer ever goes back there. The drivers side wiring route usually runs through firewall into the wheel well then in through the inner guard, down across the inner fender to the head lights and along the front under the top radiator support, but I've changed this so its all hidden under the guard, runs under the headlight and along the lower radiator support so none of it is seen. The alternator wiring is now re-routed to enter the engine bay below the head light so its a short straight run along the chassis rail and is far less noticeable - its actually shorter wiring along with being neater. Wrapped it all in conduit and then taped up and clipped back in using as many factory fixing points as possible. A large number of hours later shortening and lengthening etc it looked like this. I quite like the fact that I know what all the plugs do, where the wires all run and that there isn't any un-used plug or circuits. Lots of time spent doing things that no one will ever see or care about And other than the short section of alternator wiring this is all you can obviously see - its not finished yet but you get the idea. While I was at it I took the dash out and hauled the dash wiring loom out for a once over too. There was only a few minor changes I wanted to make like reconfigure the wiper wiring so instead of running through the engine loom like factory its part of the dash loom instead - Its spliced in so a factory engine loom would still work if needed. Fixed a few broken speaker wires and sorted the stereo wiring too. After that it all got a once over with new wrapping and replaced the odd plastic clip and it went back in. Quite satisfying that everything is in the right place, clipped back into factory points and theres no random wires. While I was at it I ran another separate loom next to it from the ecu area over to the dash for the Link inputs/outputs I want to run including a canbus circuit for future proofing incase I run a dash in this thing. Dash all went back in and at least for now its all buttoned back up properly. Then with the looms all plugged back in and the battery temporarily connected I powered the car up and after replacing a few bulbs everything seems to work and the smoke didn't escape so that's a bonus! I'll give the interior a good clean once the ecu wiring is done as its dusty as shit but it looks like a car again. I'll update on the ecu side of things soon but stuff as been arriving so im hoping to get onto that sometime soon. Other than wiring I also got the EGT setup pretty well sorted - have welded the compression fittings onto the exhaust so that can go on for good soon too. Thats all till next time 26 Quote Link to comment Share on other sites More sharing options...
Popular Post Stu Posted October 10, 2021 Author Popular Post Share Posted October 10, 2021 #ingredients #broke So yeah, short of the injectors turning up I should have everything for the engine wire up now. Huge thanks to DaveScienceTM @Roman who 3D printed me a super sweet mounting plate for the CAN-PWM fan speed control module. Just gotta find some time to wire it - there might be a few "sick" days off work coming up... 15 Quote Link to comment Share on other sites More sharing options...
Stu Posted October 31, 2021 Author Share Posted October 31, 2021 Small update time. With the 86 I wanted to try and use CAN wherever possible as I haven't used it before and if it goes wrong its only my car compared to someone else's. So in the above pictured pile of junk is a Spartan3 CAN wideband with the ADV sensor, an ECUMaster CAN-EGT amplifier, and a Maxxecu CAN-PWM module. Eventually I'll get a CAN-GPS module and a possibly a dash but that will be a loooooong way off. I've started with the PWM fan speed control and as mentioned above, with the help of DaveScienceTM @Roman and his fancy 3d printer I now have a mounting block that fits to the underside of the battery tray. This will do for now but I have in mind a two piece mount so it has a cover. Anyway, wired up the module, relay, output and can circuit including terminal resistor which is inside the sealed off deutsch plug at the bottom. Mounted up under the battery, 60amp fuse is on the side, can bus runs through the front then parallels with the chassis wiring under the guard and into the cabin. And sorted out the fans themselves: And then, with the help of Dave we got the data streams roughed together and the fans running with varying speed: There is still some sorting out to be done on the data streams as the PWM module transmits an internal temperature, amperage load, and an error state, which are showing but not in the correct scale yet. Still learning so it might take me some time to sort out but its a promising start. The whole reason for the variable speed is that the battery is quite small (will eventually be a lithium one) and want to limit the load where possible, plus ramping fan speed is kinda rad... Till next time. 7 1 Quote Link to comment Share on other sites More sharing options...
Roman Posted November 1, 2021 Share Posted November 1, 2021 Another cool thing about rampable fans. Instead of instantly on/off and shock loading your closed loop idle. You can gently ramp in the extra alternator load using a timer or whatever and it will help keep engine speed steady without a jolt. 2 Quote Link to comment Share on other sites More sharing options...
Popular Post Stu Posted May 29, 2022 Author Popular Post Share Posted May 29, 2022 Update time: Blue EP71 I've been thinking about what to do with this car and have finally come to a bit of a plan. Currently its under cover in dry storage and gets largely forgotten about for months at a time. Every now and then I take the cover off, stand around pondering things while it gets a heat cycle or a short drive, then put it all away again. Its reasonably functional in its current form, is a total animal to drive (read FUN), and works well enough. I'm sure I could jump in it and rattle off more high 11sec quarter mile runs (possibly quicker) or go hit a track without too much effort. But there are a few small things that past Stu did that current Stu isn't so happy with. I'd like to swap back to the taller ratio gearbox with the new Cusco LSD I've got sitting on the shelf to see if one less gear change on the quarter mile would make a difference. I've also got the new S2 GTX2867 to go on, all the stainless bends/pipe for the upgrade to a 3 inch exhaust. I'd pour some new engine mounts at the same time, change the hot side intercooler pipe, finally fit the front lip properly, rewire the main power feeds, put some high impedance big injectors in it and do away with the ballast resistors, maybe upgrade the ecu to an extreme, wire up the speed sensor and clutch position sensor so I can setup proper launch control etc. I'm motivated, but the reality is that I don't have time for this with house renovations, a growing business, caravan build and the AE86 being priorities. So, for now this thing will continue to stay parked up for the most part and the aim is to refresh it over winter 2023 and get it ready for OS drags 23. So for now all Ive done is have the alternator upgraded/rebuilt, bought a new battery, pulled the spare gearbox out of storage to fit the new diff, and ordered a few vband clamps. #boring I'm hoping that in the next month or so I can find a weekend to give it a good clean as it got put away filthy so at least I feel its not being neglected. And here's one of my favourite pics to keep the motivation going: Other EP71 The beater has had significant rust and panel work done to it since I bought it and its "nearly" ready for paint. A really good mate of mine is tackling most of the work and has done an amazing job - I'm very thankful as I just don't have the time to do it myself. I actually bought a donor shell to take doors/hatch/guards and a few cuts from as there was a fair bit of rot. It will never be a show car but its looking miles better than it was and Im looking forward to getting it back on the road for general hooning. Will take it up and dyno it with KPR at some point and finally use the ramps that allow the dyno to take FWD cars that I built aaaages back. This is an old photo and its much further on now but you get the idea. Ive picked up a full Si body kit for it (side skirts, front lip, boot spoiler) which I'll paint up when the rest of the car is ready. I'm on the hunt for some different wheels for it but unsure what I really want - should really stick with 15's for cert but tempted to find some 14's. The 86 I haven't really touched this much until lately while Ive been waiting for Caravan parts to arrive. Changed out the front strut brace for a Cusco one. Fitted a kill switch in the engine bay and tidied up the main powers - will likely move the earth point to further forward on the chassis leg so its not seen. I want to eventually run a big fuel pump and big coils etc so rather than relying on old relays etc I setup a new relay/fuse box up under the dash on the passenger side. Have run the feeds through to the battery and will hook them into the factory main fuses as there is a slot free. Just trying to track down a fuse to suit then thats done. You can see the link bracket mounted onto the underside of the heater box - there's not alot of real estate to hide stuff. Ive also drawn up a mount for the Spartan3 and the EGT amplifier that DaveScience aka @Roman is going to 3d print for me - thanks bro! This will mount to the side of the blower casing behind the glove box so will be nicely hidden. Ive drawn up all the wiring diagrams now so any spare time will be on wiring the engine from now on. Thats it for now 14 2 Quote Link to comment Share on other sites More sharing options...
Popular Post Stu Posted June 7, 2022 Author Popular Post Share Posted June 7, 2022 Holy hell, two updates within 6 months?! I think I've mentioned before that there isn't a lot of real estate for the ecu and wideband etc to be mounted so I've been taking advantage of every piece of space available to mount things. Ecu's laying on the floor or stuffed loose in a glove box is a pet hate of mine. I needed to find a space to mount the CAN-EGT amplifier and the Spartan3 wideband and worked out there is some clear space between the back of the glovebox and the blower box which might do the trick. I drew up a mount and once again the GC @Roman 3D printed it and it came out great - admittedly it took two goes because my tape measure was faulty... Anyway, got there in the end. The two little caps are to capture the cables so they don't move and put stress on the plugs. Everything fits well and the CAN-EGT clips into place solidly, glad that worked out. This is where its going to live. So everything is starting to take shape now, and ive buttoned up the drivers side. I need to find some new clutch and brake pedal rubbers, a fog light switch, replace the few bulbs in the cluster/console as there are a couple not working, find a black bonnet release lever, and give everything a clean. I'm still hunting for the head light and wiper switch bezels that have the dimmer and intermittent text on them as the switches are the adjustable ones but mine don't have the text on them. Also managed to get the factory radio running again and have been listening to a few classics. I like the factory dash insets for storing tapes. Last year I got in on a group buy for some carbon weather shields so fitted those too. And here's the alternator all rebuilt/upgraded. Have fitted that now, waiting on a belt to show up then the charge circuit stuff is all done. I'm working on the engine loom at the moment - plan is to have the injection circuit and the coils circuit to have plugs to the main harness so if I ever decide to change them its only the sub harness that needs changing rather than the whole loom. Anyway, more on that once its done. 13 1 Quote Link to comment Share on other sites More sharing options...
Stu Posted June 7, 2022 Author Share Posted June 7, 2022 Oh yeah, also found another hole in the NA 4age EP71. Fuck I hate bodywork. Everything else is looking good though so hopefully in the next month or so it will be close to ready to paint. 6 2 Quote Link to comment Share on other sites More sharing options...
Popular Post Stu Posted September 20, 2022 Author Popular Post Share Posted September 20, 2022 AE86 updates? I've been ticking away at this but only sporadically as the caravan and the orange EP71 have been eating all my time. Ive been sorting small annoying things like blown dash bulbs, working out why the hand brake/fluid level light didnt work on the dash (wire break), why the dash lights dimmer wasn't working (switch garked up with crud), why the rear brake light warning light was on (incorrect bulb wattage), and sorting small clips and bits of trim that were missing or broken etc. #boring #nomajorprogress But things have been progressing on the other orange EP71: Actually, it might be time to start a seperate thread on this turd... 10 Quote Link to comment Share on other sites More sharing options...
Popular Post Stu Posted October 10, 2022 Author Popular Post Share Posted October 10, 2022 Quick update on the 86: A mate of mine has had a set of factory plastic side skirts gathering dust in his extensive hoard of AE86 parts and I have been pestering him for at least 2 years to sell them to me. I was visiting him to pickup some other parts and finally got him at a moment of weakness and managed to load them into my car. Very very happy! It was going to be factory skirts or nothing as I'm not a huge fan of the big fiberglass ones. Have temporarily fitted them poser spec but will be taking them off to clean them up properly sometime soon. Yes panel gaps are all over the show and the ride height is stupid high, and its grubby, but its coming together now.... finally. I have been pining over @Roman's ethrottle setup on his Echo for quite a while now and I wasn't 100% happy with the original blacktop quad setup on the engine. I managed to pick up a set of BMW throttles with the intention to slowly figure out if they would work on a 4age and maybe swap them in later on down the track. They are pretty compact and the quad alignment is actually not too far off the 4age. The initial idea was to just slowly tinker away with it as a low priority but as usual with me, shit snowballed. It wasn't long until I had cut a flange, squashed some pipe and tacked up a manifold... They worked out really well and there is oodles of space for trumpets. @Roman (aka DaveScienceTM) has kindly offered to print a few to trial and I'm pretty excited to keep the momentum going. I'm working on the pedal arrangement at the moment and have a few options that may work fairly easily. I will mount up a vac manifold underneath the quads and hook that into the brake booster. Being e-throttle I wont need any idle up solenoids which I'm stoked about. I also have started on the cam covers. Couple of spots the cutter went a bit deep as I was running it with the jog wheel so will weld those up at the same time I setup the breathers - will update more on those next time. 21 Quote Link to comment Share on other sites More sharing options...
Popular Post Stu Posted September 13, 2023 Author Popular Post Share Posted September 13, 2023 Holy thread dredge batman - where has the time gone? I haven't done anything on the 86 in a very long time - mainly due to getting distracted with the white 4age EP71.. But in life update news we have bought a larger house so I dug the 4agte out of deep storage and now have it at home where I can get back to tinkering on it in any spare time (yeah right). I can confirm it still drives good, scarily good, I had forgotten how angry this car really is, Being in storage hasn't caused any major issues other than the pressure gauge on the fuel pressure regulator leaking and dowsing the engine bay in fuel. I have a new Turbosmart gauge on the way but in the mean time blanked it up with a bung. There are alot of sins to remedy but for now its nice to have it home. First task is to lower it back to street height as its still jacked from racing. 20 1 Quote Link to comment Share on other sites More sharing options...
