Flash's 1965 Ford Thames
Flash
  • Replies 715
  • Flash
    716
I'm back on the a/c install.
Today's task was to build a mounting bracket for my receiver/drier bottle, which is all done now, and I'll show you it in all its glory once the paint has dried, but in between coats I thought I'd tackle the a/c compressor inlet and outlet swaps.
So, when I grabbed the compressor from my local wreckers I nabbed the inlet and outlet hoses at the same time.
There are two issues with these hoses.
First up the hard portion of the lines bend towards the side and wont clear the chassis leg on my van. Secondly both lines face forwards which makes sense for a standard a/c install where the condenser sits forward of the engine but in my case where my condenser is mounted underneath and towards the back of the van, I need the appropriate hose to face rearwards.
I was able to solve both issues by sourcing a set of pad to o'ring adapters specifically for the Denso compressor.
After giving the o'rings a bit of lube I was able seat them in their new home:
And that's the compressor all done until I start fabricating my hoses.
I promised to share my receiver/drier mounting bracket efforts with you all, so here goes.
The plan is to locate the drier in the RHS front fender well tucked up above the chassis leg. I decided to make use of the existing bolt holes that mount the coil in the engine bay because if I do go to an electronic distributor sometime in the future the coil will become redundant leaving me with empty holes which will mess with my OCD.
So the first step was to carve a little flat plate out of a steel offcut, and I then poked a few holes in said plate.
Test mounted like so:
The eagle eyed amongst you will likely spot the hydraulic clutch hard line that sits slightly proud of the side even although it has its own factory formed channel to live in, hence the need for the mounting / spacer plate.
Next step was to fizz a bit of square tube to my newly carved mounting plate and after a spritz of satin black I ended up with this puppy:
I've left it to dry overnight, and I'll assemble it all in the morning.
  • Like 9
With the wipers all sorted the next job on the list was to re-instate the glove box.
Chucked it in for a quick test fit to make sure it cleared my new wiper mechanism, and the good news is that it does. The not so good news is that while I was mucking around with it, I noticed that the almost 60 year old cardboard material was crumbling with just a light touch.
Scratched my head for a bit, then decided to chuck on a few thick coats of water based paint as a binder. Left it in the sun till the paint went off and no more flaking so I'll take the win.
To give it a fighting chance I thought I'd line the bottom of the interior with something. Rummaged amongst my stash of junk and found a roll of that PVC based drawer liner stuff left over from our kitchen reno.
Shaped a bit to line the bottom and chucked the box back in.
Looks pretty good and the drawer liner stuff stops things from sliding around, so double bonus.
A bit hard to get a decent photo with my potato camera, but here you go:
  • Like 8
Made a start on my a/c pipework today.
First step was to test fit each of the hose ends on their associated components.
This uncovered two minor challenges. The first being the #10 fitting on the evaporator unit. With the TX valve already fitted to the other outlet there isn't enough clearance between the little protrusion at the top of the TX valve to tighten the nut on the neighbouring #10 fitting.
The photo above was with the TX valve joint backed off.
I was able to rectify this by completely removing the TX valve and then fitting the #10 fitting first before refitting the TX valve.
The next challenge was the #8 fitting on the compressor. The 90 degree bend works okay but the incorporated service port is clashing with the side of the engine box which will result in a less than optimum angle once I've crimped on the hose:
I've bitten the bullet and started trimming back the offending part of the engine box side. To do this I had to remove my clutch reservoir and hardline, ignition coil and newly mounted a/c receiver drier bottle.
I got half of the job done before lunch stopped play, so more butchery planned for tomorrow.
A bit more butchering this morning. The service port on the #8 fitting no longer clashes with the engine box side wall and I reckon there is enough clearance for a/c man to fit his pressure gauges when he gasses up the system.
I then created a reinforcing plate to strengthen the side wall back up. Looks like so:
Gave it a few coats of the usual satin black and it looks almost passable:
I'm letting the paint go off overnight and I'll bolt it in tomorrow.
Thanks for looking.
  • Like 9
