Flash's 1965 Ford Thames
Flash
It's almost two weeks since my last Thames update and I'm embarrassed to say that I am still mucking about with wiring.
Whilst grovelling around under the dash wiring up my power steering pump it dawned on me that now that I have changed direction in terms of the style of the internal aircon unit that I am planning to fit, I'm no longer going to be able to access the new fuse blocks that I mounted earlier in the piece.
So with no choice but to re-do the job, I disconnected the wiring and removed the fuse panel. Luckily, I hadn't yet re-wrapped the harness.
Looked around for an alternative location for the fuse panel that will be well out of the way and decided to tuck it up under the dashboard on the passenger side.
Found two existing mounting holes in the dash lip and figured I might be able to attach the opposite side of the panel to one of the metal cable holder tabs that is welded in place.
After some fiddling about with a cardboard template, I bent up some metal plate, poked a few holes in it and gave it a spritz of the usual satin black.
Let things dry off overnight, then transferred the fuse blocks and relays across from the old panel.
I had to replace the wires for the main fuse as the originals were too short, but with that done I was able to mount the panel in his new home. A bit tricky wedging myself under the dashboard to take a photo for you, so apologies for the quality, but you get the idea.
 And now I'm so looking forward to extending the rest of the wires to the new panel location.
Not.
  • Like 8
  • Replies 715
  • Flash
    716
It's Thames day 601 according to the Captain's Log and I thought I'd spend it by building another iteration of the gauge panel.
As mentioned yesterday, the current angle of the gauges makes them very difficult to read from the driving position, so I figured that a little angle was called for.
First step was to banish the aluminium filler panel to the naughty corner and figure a way to angle the gauges.
Started by blowing the dust off the cheapie individual gauge pods that I bought a while back:
Stripped the mounting feet off the buggers and attached them together with a bit of threaded rod, some nuts and washers like so:
Whipped up some dodgy looking templates for a set of mounting brackets that will attach the threaded rod to the bolts that I glued to the back of the dash to hold my original gauge panel.
Carved some replicas out of some angled aluminium off-cuts, poked a few holes and bolted things into position.
Doesn't look so great in the above photo, but the gauge visibilty is perfect from the driving position.
The next photo shows a side view and clearly shows the angle of the new setup.
As you can see in the above photo, I'm still using the slip collars to give the gauges that countersunk look.
I want to drop the pods slightly to get things more centralised in the opening, so I'll fine tune the mounting brackets tomorrow.
Then all I need to do is figure out how I'm going to build a backing plate to neaten things up.
Thanks for looking.
  • Like 8
Yesterday I took the Thames through to my mate Grant's place. I've been having a problem selecting 5th gear and figuring out what is wrong is a two person job, so Grant being the GC that he is stuck his hand up to help. We chucked the thing on his 4 poster and I worked the gear shift while he checked out what was going on. Turns out that the angle on one of my morse cable holding brackets was slightly off thus causing the inner cable to snag up when trying to select 5th. I elongated one of the mounting holes on the bracket to change the angle whilst Grant painted the fender on a customer's Holden and we then headed out for a test run.
Learnt a few things during that drive. Firstly, my new Speco temp gauge is reading high by about 7 degrees C according to Grant's laser temp gun. Secondly my fuel gauge is pretty accurate in that when the needle is on empty the tank is actually empty. Oops. Luckily another mate of ours saved us from a long walk home by riding to the rescue with a can of fuel. I certainly won't be making that mistake again.
Anyway, today I thought I'd turn my attention to my much-neglected fresh air flap. Originally this was going to be replaced with my home-made a/c evaporator unit, but since that plan has been shelved, I thought I'd give the flap a birthday.
The flap mechanism is made up of two components. The underside is a meshed insect / stone guard that was looking pretty second hand. The top is covered in overspray and the bottom is sporting a mixture of surface rust and freshish chassis black from when I did the underside.
Started off by dropping it into a vinegar bath where it will languish for a day or two.
The actual flap door looks really good on the cabin side, but not so good underneath.
The cork seal was far gone so I scraped that out and then sanded down the surface rust.
A bit of primer and a few coats of satin black and it's looking a bit better.
More tomorrow.
  • Like 9
The mesh covered bit of my fresh air flap has been in the vinegar bath for a few days, but is still looking a bit grotty. The mesh looks a bit delicate so I'm loath to hit the thing with a flapper disk, but I did give it a light sand and then chucked some rust converter on the parts that look a bit dodgy.
While I wait for that to dry, I thought I'd move on to the next item on my snag list.
So, from day dot I've had issues with my left-hand headlight. At first I attributed the issue to a blown sealed beam - the one on the right in this photo.
A while back I fitted a new set of H4 units with LED globes, but was still having issues with both lights staying on high beam no matter what position the dip switch was in.
So, first thing this morning I dusted off my copy of the factory wiring diagram and cracked straight into tracing the issue.
Thought I'd start off by looking at the dip switch. This is a new unit that I fitted a while back.
Popped both headlights out and did a continuity test on the wires running from the dip switch to each headlight. Quickly found an issue with the low beam wire on the left-hand headlight. No power getting through.
Grovelled under the dash and discovered that someone had swapped the earth and low beam wires around on the little inline connector. I suspect this happened when the painters re-installed the headlights after the bare metal restoration. Easy enough to do especially with all the overspray that the mucky buggers had got on the main wiring loom.
Anyway, with that sorted I've ticked another item off the "to do" list.
Thanks for looking.
  • Like 8
Jeez, the mesh in my little fresh air flap was a real bugger to paint. Even although I was applying really thin coats, I still managed to clog up a few of the gaps in the mesh. Was able to clear the holes with my thinnest bradawl, but it kept chipping the paint, so it took a few iterations of poking and painting before I was happy.
Doesn't look too shabby.
Popped it back in with some fresh stainless fixings and it should be good for another few years.
Oh, almost forgot to say that I found a perfect looking rubber seal in my stash to replace the sad looking cork original.
Unfortunately, I don't have enough to complete the job, so I'll grab some more from my local rubber place when I'm next in town.
  • Like 9
And I've now got the next batch of a/c related bits.
Receiver drier with mounting bracket, pressure switch and a pair of adapter pads for my Denso compressor.
And then my 23-inch condenser and a pair of 10-inch Spal pusher fans.
I can't wait to start putting this lot together.
  • Like 8
