Popular Post Flash Posted May 16, 2021 Author Popular Post Share Posted May 16, 2021 Looks like I've finally nailed the accelerator movement with version 3.5 of my cable bracket Spent a bit of time yesterday cutting, grinding and welding. Fitted it all up this morning and still wasn't happy as the pedal movement still felt short. Crawled under the van for a think and a bit of mucking about and I've learnt another valuable lesson. Contrary to what the actress said to the bishop it's not so much the length of the long arm, but the angle at which it is applied that hits the sweet spot. So I ended up making another version of the pivot plate with the longer arm at less of an angle to the shorter arm. I also cut and shut the length of the Thames accelerator rod and lengthened my little intermediate rod and the Thames accelerator pedal now travels a total of 100 mm from rest to full throttle. Next step is to shorten the HiAce cable as its currently got a lot of excess looped around the engine bay and then I'll chuck a bit of paint on the new bits. I'll also pick up a nice bit of stainless steel threaded rod on my next visit to town for that added bit of bling. Thanks for reading. 11 Quote Link to comment Share on other sites More sharing options...
Flash Posted May 17, 2021 Author Share Posted May 17, 2021 Today I thought I'd have a go at shortening the HiAce accelerator cable that I am using as it's currently way to long and is making the engine box look untidy. The light coloured tape wrapped around the outer sheath shows just how much it needs to be shortened by. Quote Link to comment Share on other sites More sharing options...
Flash Posted May 17, 2021 Author Share Posted May 17, 2021 So first thing was to strip out the inner and take to the outer with a cut off wheel. Gave the cuts on the outer a bit of a file and a de-bur to alleviate any snagging. The end has been crimped on, but I managed to drill out the outer sheath giving me a nice clean end fitting. 1 Quote Link to comment Share on other sites More sharing options...
Flash Posted May 17, 2021 Author Share Posted May 17, 2021 With the outer sheath now at the correct length I attempted to re-crimp the end using my vice, but only being able to tackle a set of opposite faces at a time it was starting to go pear shaped (literally) , so I decided on a Plan B which entailed smearing a bit of epoxy on the end of the outer sheath and then pushing it into the fitting. I was super careful and managed to do this without getting any epoxy in the inner opening, so that was good. I'll let it go off overnight and will assemble it all tomorrow. The inner cable will be straight forward to shorten as I'm currently using one of those universal ends that sandwiches the inner cable. Pic below shows just how much I had to cut out. Thanks for looking. 4 Quote Link to comment Share on other sites More sharing options...
Flash Posted May 17, 2021 Author Share Posted May 17, 2021 In other news a parcel arrived from the UK today. These shabby looking bits are like hen's teeth, so I was super chuffed when Sandy from the Owner's Club was able to track down a set for me. A mate of his has just stripped a rusty old wreck and luckily salvaged these. So why am I so chuffed I hear you ask ..... Well whilst all 400Es came out with the demister slots stamped into the all metal dash, only those vans fitted with the factory option cabin heater actually had the demister nozzles and associated pipework fitted. Asking around amongst the handful of Australian 400E owners that I know, it seems like none of the locally assembled vans came out with the heater / demister fitted. A few fully imported Dormobile campers that arrived here from the UK do have them. Anyway, I suppose I could have fabricated something, but I'm pleased to have the original units. Doubly chuffed as for cert here I have to have a windscreen demister fitted, so this will make the job a lot easier. I'll give them a tickle with a flapper disk and a lick of paint and they should be good to go. 5 Quote Link to comment Share on other sites More sharing options...
Flash Posted May 17, 2021 Author Share Posted May 17, 2021 And for those who might be interested here is a pic of a UK van that has the factory option heater fitted. As you can see it was a pretty agricultural setup. 6 Quote Link to comment Share on other sites More sharing options...
Popular Post Flash Posted May 18, 2021 Author Popular Post Share Posted May 18, 2021 I guess by now everyone is tired of reading about my accelerator setup, so I'll close the subject off by sharing a photo of the new components with a quick splash of paint. I'm looking forward to working on something else tomorrow. 12 Quote Link to comment Share on other sites More sharing options...
Flash Posted May 28, 2021 Author Share Posted May 28, 2021 Well, it’s been over a week since my last update so that kinda bears witness to the time consuming nature of the issue that I am currently trying to resolve. Let me explain …. So spurred on by my recent success with the revised accelerator setup I decided to revisit my gear linkage setup. When I last touched on this subject I was leaning towards replacing the original Thames column shifter with the floor shifter harvested from my Mitsi Express donor. The main reason being that I just wasn’t able to get enough force applied to the gearbox gate selector to get a consistent result. I’ve got to admit that at the time this decision didn’t sit well with me at all. The column shift adds to the van’s general quirkiness and it feels like a compromise going with the floor shifter. So, with that in mind I decided to have one more go at sorting out the column shifter. To my way of thinking the issue stems from the fact that I am "losing energy" through the long push pull cable compared to the solid shift rods that the HiAce was equipped with, so my first thought was to see if I could retro fit the HiAce rods to the Thames. Started off by cleaning them up a bit as there is nothing nicer than fiddling about with clean parts. Then marked up the components so I knew which parts made up the gate selector versus those belonging to the gear selector. Ended up with this: 1 Quote Link to comment Share on other sites More sharing options...
Flash Posted May 28, 2021 Author Share Posted May 28, 2021 I spent a considerable amount of time under the Thames trying to find a clear route for the HiAce gate selector rods, but eventually had to concede defeat. The major stumbling block is the fact that the HiAce is a monocoque construction so there are no beefy chassis rails to contend with. In the case of the Thames there is a ruddy great chassis leg that needs to be trans versed to get from the gearbox arm to the column shift arm. I looked at modifying the intermediate pivot point on the linkage by extending the connecting rod over the top of the chassis rail thus leaving me with the shorter gearbox rod on the inside of the chassis leg and the longer column rod on the outside of the chassis leg. This could have worked if I didn't have the steering column in the way of the final connection to the column shifter. I could attempt to fabricate some kind of dog leg setup with another pivot point to get around the steering column, but I'd end up with a reverse pattern gate shift. I could incorporate another pivot point to retain the correct movement direction for the gate lever but I'm worried about over complicating the solution. So with my first attempt banished to the naughty corner I decided to investigate the possibility of using the shorter gearbox rod and pivot point from the HiAce mated to the a shorter push pull cable. The HiAce gate rod and pivot are the ones labelled A in this photo : 1 Quote Link to comment Share on other sites More sharing options...
Flash Posted May 28, 2021 Author Share Posted May 28, 2021 Since this is just a proof of concept I didn't want to drill any additional holes in the Thames chassis or floor, so ended up fabricating a few new brackets so that I could mount the pivot and the outer sheath support bracket for the cable. So with everything temporarily mounted in position I gave it a whirl. Instant fail ....... Still not enough torque to get the gate lever to move smoothly. I was surprised by this outcome as I figured that the unequal length arms on the intermediate pivot point would have given me extra torque, but not so. In desperation I even tried reversing the pivot arms so that the longer arm would be on the cable side. This reversal meant fine tuning the temporary support brackets, so yet more time was spent cutting, grinding, drilling and welding. Still no luck. Sharing my frustration with Mrs Flash over a cuppa, she reminded me that success is the result of moving from one failure to the next with no discernible loss of enthusiasm, so spurred on by these words of wisdom it was back out to the shed to puzzle out another approach. Lying in relative luxury on my manky old piece of house carpet under the Thames is where I do some of my best plotting and scheming. Whilst lying there and fiddling about with the gearbox gate lever it suddenly came to me that maybe the solution lies in something other than a cable or rod based mechanism. What about some other way of moving that bloody lever.... it only needs to travel a maximum of 15 mm in either direction ... how hard can it be FFS ..... Alternatives you say ... well what about hydraulics I thought. Needing both a push and a pull movement I'd need two separate circuits. Thinking this through my head started to hurt. I'm not saying it's impossible, more like it's way beyond my skills base. My next thought was electronics. What about setting up a pair of solenoids that could be activated by micro switches located at the bottom of the shift column. Now I don't know much about solenoids so last night I spent a bit of time asking the google and it turns out that a pair of linear solenoids might be the go, only thing is they would need to have a "push and hold" function. Turns out there are such beasties available, but I wasn't convinced that they would provide enough torque to be up to the task. Puzzling more on this topic last night whilst sitting in front of the idiot's lantern, I suddenly remembered that I had seen one of those central locking solenoids fitted to the tailgate on the Starwagon donor van. What have I got to lose I thought. So first thing this morning I harvested it and was able to temporarily mount it using a few bits and bobs. I've only tested it in one direction thus far, but this little video clip shows the result of the experiment. 7 Quote Link to comment Share on other sites More sharing options...
Flash Posted May 28, 2021 Author Share Posted May 28, 2021 And here is a link to a longer version of my test. https://youtu.be/5FQ_NSinxRI The eagle eyed amongst you may spot the second gear lever that is positioned above the gate on the gearbox lifting correctly as the gate lever is activated. I've also included a still shot of the setup below. It's temporarily mounted using one of my gearbox mount holes and isn't the prettiest looking setup at the moment. But its fine for a proof of concept. I still need to test the opposite movement before I give it the final tick and I'm also thinking that the door activating solenoid may not be the correct unit for the job as I don't think it is equipped with a "hold" circuit so would probably burn out under sustained use. I'd be grateful for any input and advice from those who know a bit about solenoids. Thanks in advance. 3 Quote Link to comment Share on other sites More sharing options...
Flash Posted June 25, 2021 Author Share Posted June 25, 2021 Long time no update, but that doesn't mean that nothing has been happening. I've spent hours and hours trying various things to get my gear shift to the point where I am 100% happy. I've shelved the option of using electronic solenoids for now as it would just add an additional layer of complexity. I'm seriously contemplating changing over to a 4 speed auto if I can track one down. Just so that I can keep the interior looking stock with the column shifter. The same model HiAces that I got my engine from were equipped with a A44DL auto, but they are pretty thin on the ground over here in Straya. I go all excited the other day as our local wrecker got in an auto Townace, so I raced around for a look see. Unfortunately it is the newer generation A46DE which would again just complicate things. In other news, late last week I decided to take a break from the Thames, so cracked into stripping down my second donor HiAce. I've harvested just about everything of value. The back axle still needs to come off, but I'll do that once its on the rollback when the scrappy comes to fetch it next week. 8 Quote Link to comment Share on other sites More sharing options...
Flash Posted June 30, 2021 Author Share Posted June 30, 2021 So two things happened today. My mate Trevor dropped by to pickup the remains of donor HiAce 2. I pulled the HiAce back axle out and slung and old Thames unit under there just so we could load it up. Goodbye old friend. 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Flash Posted June 30, 2021 Author Popular Post Share Posted June 30, 2021 And then in other news a fellow Thames enthusiast who is visiting the area dropped by for a yarn. This sweet little truck is fitted with a V8 and associated running gear out of a Leyland P76. The cab has been converted to tilt for full engine access. 17 Quote Link to comment Share on other sites More sharing options...
Flash Posted August 6, 2021 Author Share Posted August 6, 2021 Yikes, you know that things have slowed down when you have to scroll to page 3 to find your build thread. Having said this I've got a pretty good excuse. So, the day after my last update I got a call from someone who was interested in the gearbox out of my Express donor van. He was in a hurry for it so I quickly dropped the engine and gearbox and was busy separating the two when the engine toppled over and crushed the small finger on my right hand. It's my own bloody stupidity as I was in a rush and had taken a short cut. Needless to say it has been a tough month and a bit. At one point the finger looked to be in jeopardy, but thankfully things improved. The splint came off last week and although I still have no feeling in the lower part of the finger I have regained some movement in the middle joint, so hopefully I'm over the worst. In case you are busy eating breakfast, lunch or dinner whilst reading this I won't post any pictures of the finger, but here is a pic of the offending engine which I haven't even had the stomach to look at since the dastardly deed took place. Anyway, onward and upward as they say. 5 3 Quote Link to comment Share on other sites More sharing options...
Flash Posted August 6, 2021 Author Share Posted August 6, 2021 This morning I thought I'd try to get back on the tools. I managed to ease a work glove onto my damaged hand to offer it some protection and then made a start on pulling my donor Starwagon apart. The hand held up surprisingly well so with a bit of luck I should get the engine and gearbox out tomorrow. 6 Quote Link to comment Share on other sites More sharing options...
Flash Posted August 7, 2021 Author Share Posted August 7, 2021 More progress today. Managed to remove the engine and gearbox from the donor Starwagon. I decided to lift the van rather than drop the engine and box as I had visions of another crushed hand, but all went well this time. Pic or it didn't happen. 6 Quote Link to comment Share on other sites More sharing options...
Flash Posted August 16, 2021 Author Share Posted August 16, 2021 And another one heads off to be reincarnated as a toaster. 6 Quote Link to comment Share on other sites More sharing options...
Popular Post Flash Posted October 8, 2021 Author Popular Post Share Posted October 8, 2021 You know that things have slowed down a bit when it is almost two months since my last update. To be fair most of my free time has been taken up sorting out other members of our vehicle fleet. Needless to say I've missed working on the Thames and I really need to get back on it. So my last Thames related update was all about the challenges I was facing trying to get the Thames column shift to work properly with the 5 speed Toyota gearbox. In one of my updates I was even considering fitting an automatic gearbox if I could find one. At the time I asked for some advice on the Tech Forum page and the general recommendation was that I should be hunting for a A44DL auto box out of the mid 80's HiAces as this would be equipped with a Y bell housing to match the Toyota 3Y engine that I am running. At the same time it was pointed out that these boxes are getting pretty thin on the ground. Anyway I have been keeping an eye out for an auto and about a month back I was swapping a few yarns with a fellow Queenslander on the Book of Faces and he happened to mention that he had a few spare auto gearboxes lying around for his Y powered HiAce camper. After a few messages back and forth a deal was struck. I would swap him a 4 speed manual complete with flywheel, pedal assembly and clutch hydraulic pipework for two A44DL auto boxes. On Tuesday morning Mrs Flash, the hound and I loaded all of the manual stuff into our modern daily van and headed off into inland Queensland to visit my new FB mate. After a round trip of 878 km, I now have two auto boxes languishing in my shed. Both are 0372L models but one has the Y bell housing and the other the newer RZ bell housing. Apart from the bell housing difference the only other difference between the two boxes is the position of the dip stick outlet on the oil pans. The RZ has the dipstick on the opposite side for some reason. First prize is still to get the 5 speed manual to work, but at least if it all turns to custard I now have a fall back position. Photos of my two new boat anchors : Thanks for reading. 12 Quote Link to comment Share on other sites More sharing options...
Flash Posted October 16, 2021 Author Share Posted October 16, 2021 A good few years ago a mate of mine had a lawn mower that broke down. After heading into town and buying a new one, he came home and proceeded to fix his old one. Well now that I have my two auto gearboxes safely tucked away in the corner of my shed, I'm now feeling a bit like my lawnmower mate as I'm moving forward with renewed vigor to get the manual gearbox working correctly. Sad, I know, but at least I've secured a fall back position should everything turn to custard with the manual and all it cost me was a tank of fuel and some other junk manual parts that I had lying around. So back to the manual gearbox. By now you are all sick and tired of hearing me rabbit on about my battle to get the original Thames column shifter to work with the Toyota 5 speed. I can get it to work, but it's just not smooth or consistent enough for my liking. All it's going to take is one miss shift at revs or speed and it will all end in tears. Mrs Flash has given it a few test goes and has declared that she is reluctant to drive the Thames as is for fear of scrambling the box. So that leaves me with either doing the conversion to auto or doing a floor shift conversion on the manual. A while back I tried the floor shifter out of my Mitsi Express donor van. Because of the way the shift mechanism worked I had to use long Morse cables that I looped around to get the shift pattern correct. While this worked okay the "latency" in the long cables meant that the "gate wouldn't automatically return to centre when in neutral. I was able to remove this latency using shorter Morse cables, but this resulted in a reversed shift pattern. Not ideal at all. So earlier in the week I decided to try modifying the Express shifter to provide a normal shift pattern. My cunning plan was to mount the mechanism upside down and then rotate the gear stick by 180 degrees. So got out my grinder and welder and I'll let the pictures tell the story 3 Quote Link to comment Share on other sites More sharing options...
