Ive been following Kpr's hilux build on here after seeing a video on facebook of it shredding mud and decided people might want to see how i guess a similar build is going. (not trying to steal spot light just think people might be intrested)
bare with me i have like 200+photos and alot of info to type so may take awhile
im a drainlayer by trade so deffo not a pro but have had my fair share of building 4x4s and other things. haters shall hate...
ill start from the very begining, so after i finished building 2x nissan patrols i wanted something abit more exciting,
so feburary 2017 i aquired a certified 1991 ln106 hilux with a 350 sbc with a R series toyota box behind it, it ran like shit when i brought it so the mods began and i got it running nice again with new carby, leads, intake etc
Link to post
  • Replies 44
so after making it run well i got used to the power and was super unhappy with the factory leaf set up, twitchy steering, axle tramp, no flex, ride harshness and general truck trying to kill driver.
decided it needs coil overs... then the baja videos came..
i spent about 2 months measuring, drawing, reading and thinking about how i was going to undertake this, alot of info regarding building anything to do with speed and offroad is kept under wraps so it takes alot of time to get through whats on forums etc..
Link to post
so after i decided on what the goal was and how i was roughly going to get there i contacted lvvta and submitted everything for TAC approval, which was a massive waste of time, basically told me its fully up to the cert dude which is what i gathered anyway...
trucking on.
sold the 350 chev, box and hilux diffs, stripped everything back and kept what i needed and sold/ gave away what i didnt.
Link to post
after that i cut all the suspension mounts off with a 18" steel cutting blade on my concrete saw and i had a blank canvas,
following my drawings and roughly guessing where everything is going to fit i narrowed the rear section of the chassis to fit in all the suspension wizardry.
meanwhile all my fishplates and other related steel is being laser cut.
Link to post
after waiting for the steel to be cut on the laser (so much nicer than old mate with a cutting disk on the grinder) they were finally done and i could start forming them and welding them up to the chassis.
now im no fancy engineer but all i am trying to achive is alittle more stiffness and to try keep the chance of cracking to minimum, so at every mounting point or where the rails change direction i fishplated.
im also trying to follow the hobby car manual to keep inline with the lvvta reqs.
Link to post
some where along the way i got some GQ patrol diffs which a far wider than the hilux ones, and much larger and stronger, the certification part of the build comes into play here as i do want this thing on the road if i can, so i cut all the mounts off the patrol diff and jigged them up under the chassis best i could.
using a 300mm digital spirit level and the old stringline i managed to get close as to the same alignment as a factory Patrol (fluked it i think) apart from the toe but thats easy as just adjusting the track bar.
for the front diff i had to cut off rotate the housing and reweld up the radius arm mounts to achive the correct castor for the ride height i want (about the same as a standard hilux)
i threw some trusses on them also for jumps
Link to post
the conversion kit arrived from marks adapters in ozzie (ls1 to hilux R series 4x4 box) and i ordered all the universal link mounts and engine mount kit from usa, cheap as all laser cut slot together parts out of 6mm plate too easy!
Link to post
while i waited for all my univeral link mounts i carried on with power steering box mounts ( gq patrol steering box) and just playing around with numbers in the 4 link calc
and ordered all these FK rod ends heim joints from summitracing, these things are massive, sorta lame they took 3 months to get here though slowed the whole build down
Link to post
my rear lower links ive designed to mount off the existing xmember, but to get the numbers i want in the 4 linl calc i have to drop them abit lower than what the xmember is, was sorta just winging it here with internal gussets i doubt they will break off
Link to post
got some standard patrol front radius arms and put a m24 thread on the ends, and then had a custom threaded sleeve welded onto some 3"currie johnny joints to try get some extra flex and freedom of movement over the pin and bush setup, dont have many pictures of this part but here are the beefy mounts to the chassis i made
Link to post
pretty much finished the triangulated 4 link, not going to massive write ups of how everything is done as theres is enough people who have done it before me and have posted detailed methods on google...
and have started finishing off the front end panhard mounts, steering stuff..
scored a rebuild ls1 off TM for $500
Link to post
