Testament 8,151 Report post Posted August 28, 2018 I've got some spreadsheets that can grind about as much as a 9" if you need man 3 Quote Share this post Link to post Share on other sites
Adoom 1,755 Report post Posted August 28, 2018 19 hours ago, Testament said: I've got some spreadsheets that can grind about as much as a 9" if you need man I supposed if you had 'gridlines' turned on it should work. Quote Share this post Link to post Share on other sites
flyingbrick 7,503 Report post Posted November 9 hey did this work in the end? Quote Share this post Link to post Share on other sites
Adoom 1,755 Report post Posted November 9 1 minute ago, flyingbrick said: hey did this work in the end? It's definitely still sitting in the small thingies drawer. I should probably finish it, over a year is probably long enough. 1 Quote Share this post Link to post Share on other sites
Adoom 1,755 Report post Posted November 9 2 3 Quote Share this post Link to post Share on other sites
Adoom 1,755 Report post Posted November 10 Fiiiiiiiiiiiiine! So I linished the plates on the bench grinder to remove the slag so they would sit flush against each other. Then I lined up the teeth and clamped it together with the bolts. Then turned the tig down to 50 and ran it across the back a few times to glue them together. It bolted up okay. It's kinda works. Like it will stay up if I lift the arm. But it falls down as soon as I turn it on. It would probably help if I sharpen the little plates that engage on the teeth so they fit better. 1 1 Quote Share this post Link to post Share on other sites
