Small update
Put some tyres on my wheels and test fitted for the first time since I brought em. They look good!
Managed to finish mucking around with motor and have put fresh oil in and replaced spark plugs. Dizzy cap and rotor look mint so havent bothered replacing them.
And Painted driveshaft
Will fit this weekend and put some trans fluid in.
Thanks for looking
  • Like 8
  • Replies 71
  • 6 months later...
Holy Shikhimova time flies.
2019 turned out to be a very hectic year. Partner got pregnant, we got engaged, and decided to smash out the rest of our house renovations before our girl was born.
Anyway with riley born and renovations finished it's time to get back into this and boy have I been chomping at the bit to finish it.
Turned out the diff setup was as hori as the front engine mounts and me being a clever cunt I didnt check it before going to chch to strip the parts car so I needed a new one.
So what did I do? I went and brought another diff off harry.. from chch.
received_872403569820797_zpsmer49oc7.jpe
Decided I might aswell upgrade so got the whole disc rear end of an ms112 crown and the GC even threw in a 4.1 ratio diff which is the factory spec ms65 3 speed auto
Needs a complete overhaul and paint.
Got the rest of the panels painted
Now that I've got the rear end I'll swap it over. Hook up the driveshaft and fill trans with fluid and hopefully fire it up in the rear future.
Also brought a square headlight JDM front
Nos Ms90 kioto headlights. Ms90 surrounds and a ms75 pre facelift grill
Exciting times ahead.
  • Like 8
Got stuck into the diff over the weekend. Rotors and calipers sent away for skim/rebuild
Changed the diff head out to the 4.1 which is the factory for a ms65 3 speed auto and gave it a clean up and paint
Cheers
Swapped the diffs over. Old one I'm led to believe is off a 308.. Australian by the look of it.
Old
New ms112 rear
Also got all the skimmed rotors, rebuilt calipers, flexible brake hoses and brake pads. Got some diff oil aswell
Only thing that had to be swapped over was the hand brake cables, everything else bolted up.
I've bled the brakes and adjusted the hand brake and all feels good.
Fitted driveshaft, filled diff and transmission with oil and started trying to tackle the wiring.. doesn't start off key so will need to do some digging and try see.
Getting close now.
Put the rest of the front end on.
Headlights arent working seems no power to the relay from switch side because when I press down on this the lights work. Fuses are all ok. This has been spliced into loom. Going to have to remove cluster ect again to trace behind dash..  So decided to take a break.
Ok so still havent got that relay to work so will make up a new one/buy one.
Took the crown for a hoon down the road. Went ok... ish. The steering isnt quite centered and turning right sucked. Need to re center. And apart from the no exhaust and motor running like pooes it was a success.
Still need an exhaust if anyone knows someone keen I'm in pukekohe. Wanting mild steel. Will use factory 4m cast extractors.
Also cleaned up and painted the grill and surrounds flat black.
Also connected up the throttle linkages so accelerator works off pedal.
Getting close.
  • Like 9
  • 6 months later...
shit time flies.
some people say i need better work life balance but i say life is riding a bike to keep your balance you have to keep moving, anyway shit yarn ive been busy.
not too much has happened with this but it is closer.
took for a hoon down the road which didnt end well because no exhaust = fumes from combustion circling back around into the carb at idle/low speeds.
managed to sus an exhaust of a ms65 crown but had the earlier 4m motor so just had to change flange and im away.
received_658447898351788_zpsrcwfoyik.jpe
received_725047544726091_zpss6bap6sl.jpe
the rest of the exhaust also got painted black but no photo..
all fitted but leaked at manifold i had wrong gasket still will get some rtv tomorrow and try again
also the radiator i had got started to leak once up to temp so i soldered it up and it appears to have fixed the leak.
i also purchased a new wiring harness with relays i just need to wire back to under the dash, brought the washer kit from supercheap auto so shes a squirter boys
plan on giving it another go once home from work today another road test is on the cards.
i need to get this one finished so i can get the corona driveable i havent touched it since i snapped an axle at oldschool drag day 2018 i think
Ill eventually get around to having a play around with this grill and facelift headlights
received_1823180397813115_zpsixjv6ysu.jp
Looking for another pre facelift crown badge and toyota if anyone has them
Had a productive weekend
 Got the headlights working with dip switch got horn up and running and removed the ridiculous speaker boxes on the doors . There was some left over vinyl so i hole sawed and patched over
 Not perfect but 100x better than previously
20200822_180810
20200821_212341
received_1830956683709038
20200823_220457
20200823_211802
Treated myself to some hydraulic wheel dollies so handy for small garages
20200821_205827
Cars running like a bag of dicks not sure why..
  • Like 9
Cars still running like complete shit
Did a compression test came up alright. Plugs 2 and 4 were abit oily but maybe from rocker cover that use to leak I've since replaced gasket and I think when I checked plugs last time might of dripped in..
Anyway I'll start from the top and go over it all including checking the electric side.. 12.9 volts could be the issue..
20200825_19113720200825_19090020200825_19064420200825_19040920200825_19005320200825_185412
Anyway I will persevere..
Cars still running like crap.. ive set the carburetor to factory 4m specs but the carbs for a 5m. Idle and revs allgood but under load it really struggles and smokes like fuck.
Managed to get couple drives up and down the road.. sump appears to still be leaking which is a real pain because the huge fuck off cross members in these crowns give no clearance to access all the bolts... think I'm going to have to pull the motor
. Buggar
Picked up a 6 pin voltage regulator off a mate of mine that came from his old ke35.. I assumed toyota would of used the same.. yep I was right.
Well that sorts out the low 12.8v while car running issue
20200830_150725
20200830_161047
Didnt fix the issue with how the cars running though..
Can anyone recommend a mechanic in Auckland who is good with old cars? This 4m has defeated me I've tried everything and I can't get it running properly. Everything is new on it and I can't figure it out so it's time someone else does.
2020-09-13_05-42-53
Cheers
Sumps all gooed up and torqued back on fuck I hope it doesnt leak.
20200925_210536
Did a bolt check of the motor and decided to paint the front bits of the alternator
20200925_210543
I've marked a reference point in the electric choke housing and rotated it 2 clicks clockwise and see how it goes once I fire it up.
20200925_211541
Before I put the motor back I'm going to check and make sure all the lights/indicators are still working/replace bulbs, general bolt check all round and put motor back in tomorrow/Sunday
Gasket goo says wait 24 hours so I'd better wait that Atleast. I dont want to pull it back out again.
