footey Posted January 24, 2018 Author Share Posted January 24, 2018 Quote Link to comment Share on other sites More sharing options...
footey Posted January 24, 2018 Author Share Posted January 24, 2018 decided to replace all the wheel cylinders the shoes where allgoods for the time being also have found that my radiator is buggerd so a new one will be on its way shortly. after the brake are a go i will start working on the electrics and the custom dash. Quote Link to comment Share on other sites More sharing options...
footey Posted January 24, 2018 Author Share Posted January 24, 2018 1 Quote Link to comment Share on other sites More sharing options...
footey Posted January 24, 2018 Author Share Posted January 24, 2018 my face after i found one wheel cylinder was different gahhh put the drum back together missing half the bits now waiting on one cylinder to finish the job 1 Quote Link to comment Share on other sites More sharing options...
footey Posted March 22, 2018 Author Share Posted March 22, 2018 Quote Link to comment Share on other sites More sharing options...
footey Posted March 22, 2018 Author Share Posted March 22, 2018 Got this in the post new 2 core alloy vk commodore rad, hopefully fingers crossed this will do the trick Quote Link to comment Share on other sites More sharing options...
footey Posted March 22, 2018 Author Share Posted March 22, 2018 Fits so good had to bodge up some spacer to lift the whole rad, something about this one having square end tanks and hitting the chassis rails its now in there like a beast and not coming out, now time will tell if she will hold a steady temp slaving up some hills in sweltering summer heat while towing a jeep out because there shit i mean lesser quality 3 Quote Link to comment Share on other sites More sharing options...
footey Posted March 29, 2018 Author Share Posted March 29, 2018 Quote Link to comment Share on other sites More sharing options...
footey Posted March 29, 2018 Author Share Posted March 29, 2018 1 Quote Link to comment Share on other sites More sharing options...
footey Posted March 29, 2018 Author Share Posted March 29, 2018 Have decided for now to use to original cluster, have added a new ignition switch that has a diesel glow before start, also enlarged the hole from the original two pin power supply on the dash to fit a twin USB charger and volt meter, now just to wire this all up Quote Link to comment Share on other sites More sharing options...
footey Posted March 31, 2018 Author Share Posted March 31, 2018 1 Quote Link to comment Share on other sites More sharing options...
footey Posted March 31, 2018 Author Share Posted March 31, 2018 Quote Link to comment Share on other sites More sharing options...
footey Posted March 31, 2018 Author Share Posted March 31, 2018 Chopped off the old lights, bolts where seized in place, Have a set of leds to install and a set of led inserts for the headlights. Also installed all the new loom, everything loops through the drivers side so i can make a junction for trailer lights, Quote Link to comment Share on other sites More sharing options...
footey Posted March 31, 2018 Author Share Posted March 31, 2018 Also have pressure bled the brakes as i was having an issue getting a hard pedal now there like a geriatric that took some viagara. pressure bleeding also meat brake fluid went everywhere so washed the old girl down. Slowly getting there Quote Link to comment Share on other sites More sharing options...
footey Posted April 2, 2018 Author Share Posted April 2, 2018 Quote Link to comment Share on other sites More sharing options...
footey Posted April 2, 2018 Author Share Posted April 2, 2018 spent the last few days finalizing the wiring, working on how to wire an auto trans with od is a nightmare anyone with experience wiring a 4n71b would be nice to cross reference, everything now is quick disconnect and an 12 way fuse board behind the panel rather then the old two fuses. Also have rewired a new ignition switch however think i need to add a diode to stop back flow while in accessory, so the fuel pump etc stops working. just to add a few relays wait for the led indicator relay and she will be good to go Quote Link to comment Share on other sites More sharing options...
footey Posted April 9, 2018 Author Share Posted April 9, 2018 Quote Link to comment Share on other sites More sharing options...
