doullama Posted August 6, 2017 Share Posted August 6, 2017 Hi all, any k engine guru's know if theres much difference between 3k/4k head gaskets? I've managed to cook my 4k (seized thermostat! ) and pulled it out, its an aftermarket 3k gasket which seems to be missing plenty of the water jacket holes, does this matter? first pic is the one i've just pulled out, second pic is some chinese one which has passages that match that of head/block. 3rd picture is where I assume this one has failed. Chur Quote Link to comment Share on other sites More sharing options...
ajg193 Posted August 6, 2017 Share Posted August 6, 2017 Just get a genuine Toyota 4K gasket. They're less than $30. Also get your cylinder head skimmed to make sure it is still flat. 1 Quote Link to comment Share on other sites More sharing options...
doullama Posted August 6, 2017 Author Share Posted August 6, 2017 Cheers, have emailed the Toyota branch I got the 7k manifold gasket from, for a 4k gasket and head bolts. Will send the head away for recon too Quote Link to comment Share on other sites More sharing options...
