akwlane Posted July 17, 2015 Share Posted July 17, 2015 dont know if this is in the correct place..... I have a mk1 escort 2 door and I need to remove the doors to sand blast and reskin one of them.I have tried a door pin remover thing but that just bent. Any tips? Quote Link to comment Share on other sites More sharing options...
tortron Posted July 17, 2015 Share Posted July 17, 2015 They get pretty stuck in there over time try soaking with some penetrating fluid. Heat may be needed. If its real bad you may have to drill them out. If you are careful you can then punch out the remains, if not you can bore them out a bit and use oversize pins Quote Link to comment Share on other sites More sharing options...
JoKer Posted July 17, 2015 Share Posted July 17, 2015 can you not unbolt/screw the hinges on those? Quote Link to comment Share on other sites More sharing options...
ta63-1uzze Posted July 17, 2015 Share Posted July 17, 2015 I have in the past managed to use a die grinder with a long carbide bit in the chuck, and take the heads off and then smash them through with a long bit of steel from the top . Quote Link to comment Share on other sites More sharing options...
