New brake lining.  It's a bit too thick but i will make it work.
Edit:  Someone donated me some V12 Lincoln wheel studs to replace those crappy galvanized bolts.
  • 4 months later...
  • Replies 69
  • 1 year later...
Hood tie down strap made from a leather belt.  The belt is so long it forms a loop for someone 3 times my size.  Could wrap that around my waist 3 times before it met the first belt hole, and it has a functional lock in it.  Why would it have a lock?
So i don't know if i should start a technical thread on "How to make trembler coils" as mine are toast and one of the borrowed ones died today. Never successfully made an ignition coil before, i think i'll need help of the electrical gurus on here.
  • 6 months later...
  • 5 months later...
  • 5 months later...
Picture-less update.
While i will still need to dial in the auto-advance curve (the orig' relied on a combination of moving a lever to a basic range, and the magnets on the flywheel ramping up the speed of the points opening) it has a notable improvement in fuel economy, partly due to being able to wind the fuel mixture screw in 1/16th of a turn & have the same performance.
It's like having the magneto set perfectly.  But requires a battery.
  • 5 weeks later...
I can wind the mixture screw in 1/8th and not melt the pistons.
i also made a music player for summer.
The first one, had no support for remembering where it stopped playing when it was turned off & i didn't want to stress the EEPROM by writing to it every time you changed a song.
So i made this hilarious work around.
Ultra capacitors running the player for a few seconds after it is turned off.
 * A basic MP3 player for a car, that was never designed for a radio.
 * connect to an amplifier for enhanced sound.  Anything better than the single MOSFET i used should be fine.
 * in this version i attempted to overcome its habit of not playing the next track, but i don't know how to read the 'Finished playing' from the serial...
 * I derived this code from ...
 DFPlayer - A Mini MP3 Player For Arduino
 <https://www.dfrobot.com/index.php?route=product/product&product_id=1121>
 This example shows the all the function of library for DFPlayer.
 Created 2016-12-07
 By [Angelo qiao](Angelo.qiao@dfrobot.com)
 GNU Lesser General Public License.
 See <http://www.gnu.org/licenses/> for details.
 All above must be included in any redistribution
/***********Notice and Trouble shooting***************
 1.Connection and Diagram can be found here
<https://www.dfrobot.com/wiki/index.php/DFPlayer_Mini_SKU:DFR0299#Connection_Diagram>
 2.This code is tested on Arduino Uno, Leonardo, Mega boards.
#include "Arduino.h"
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
# define ACTIVATED LOW
SoftwareSerial mySoftwareSerial(10, 11); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
int buttonPause = 3;
int buttonVolPlus = 4;
int buttonVolMinus = 2;
int buttonNext = 6;
int buttonPrev = 7;
int buttonFolderNext = 8;
int buttonFolderPrev = 5;
int theReadStatus = 0;
long unsigned theReadStatusTimer = 0;
int currentFileNumber = 1;
int busyReadPin = A1;
int readCurrentFileNumber(uint8_t device);
long unsigned currentMillis = 0;
int thisChar;
boolean isPlaying = true;
int trackCount = 0;
int oldtrackCount = 0;
int folderCount = 0;
int oldfolderCount = 0;
String inputString = "";         // a String to hold incoming data
bool stringComplete = false;  // whether the string is complete
void setup()
# define Start_Byte 0x7E
# define Version_Byte 0xFF
# define Command_Length 0x06
# define End_Byte 0xEF
# define Acknowledge 0x00 //Returns info with command 0x41 [0x01: info, 0x00: no info]
  pinMode(buttonPause, INPUT);
  digitalWrite(buttonPause,HIGH);
  pinMode(buttonVolPlus, INPUT);
   digitalWrite(buttonVolPlus,HIGH);
  pinMode(buttonVolMinus, INPUT);
  digitalWrite(buttonVolMinus,HIGH);
  pinMode(buttonNext, INPUT);
  digitalWrite(buttonNext,HIGH);
  pinMode(buttonPrev, INPUT);
  digitalWrite(buttonPrev,HIGH);
  pinMode(buttonFolderNext, INPUT);
  digitalWrite(buttonFolderNext,HIGH);
  pinMode(buttonFolderPrev, INPUT);
  digitalWrite(buttonFolderPrev,HIGH);
  pinMode(busyReadPin, INPUT);
  digitalWrite(busyReadPin,LOW);
  mySoftwareSerial.begin(9600);
  Serial.begin(9600);
    while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  inputString.reserve(200);   // reserve 200 bytes for the inputString:
  Serial.println();
  Serial.println(F("DFRobot DFPlayer Mini Demo"));
  Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
  if (!myDFPlayer.begin(mySoftwareSerial)) {  //Use softwareSerial to communicate with mp3.
    Serial.println(F("Unable to begin:"));
    Serial.println(F("1.Please recheck the connection!"));
    Serial.println(F("2.Please insert the SD card!"));
    while(true);
  Serial.println(F("DFPlayer Mini online."));
  myDFPlayer.setTimeOut(500); //Set serial communictaion time out 500ms
  //----Set volume----
  myDFPlayer.volume(05);  //Set volume value (0~30).
  myDFPlayer.volumeUp(); //Volume Up
  myDFPlayer.volumeDown(); //Volume Down
  myDFPlayer.play(1);
  //----Set different EQ----
  myDFPlayer.EQ(DFPLAYER_EQ_NORMAL);
//  myDFPlayer.EQ(DFPLAYER_EQ_POP);
//  myDFPlayer.EQ(DFPLAYER_EQ_ROCK);
//  myDFPlayer.EQ(DFPLAYER_EQ_JAZZ);
//  myDFPlayer.EQ(DFPLAYER_EQ_CLASSIC);
//  myDFPlayer.EQ(DFPLAYER_EQ_BASS);
  //----Set device we use SD as default----
//  myDFPlayer.outputDevice(DFPLAYER_DEVICE_U_DISK);
  myDFPlayer.outputDevice(DFPLAYER_DEVICE_SD);
//  myDFPlayer.outputDevice(DFPLAYER_DEVICE_AUX);
//  myDFPlayer.outputDevice(DFPLAYER_DEVICE_SLEEP);
//  myDFPlayer.outputDevice(DFPLAYER_DEVICE_FLASH);
  //----Mp3 control----
//  myDFPlayer.sleep();     //sleep
//  myDFPlayer.reset();     //Reset the module
//  myDFPlayer.enableDAC();  //Enable On-chip DAC
//  myDFPlayer.disableDAC();  //Disable On-chip DAC
//  myDFPlayer.outputSetting(true, 15); //output setting, enable the output and set the gain to 15
  //----Read imformation----
  Serial.println(myDFPlayer.readState()); //read mp3 state
  Serial.println(myDFPlayer.readVolume()); //read current volume
  Serial.println(myDFPlayer.readEQ()); //read EQ setting
  Serial.println(myDFPlayer.readFileCounts()); //read all file counts in SD card
  Serial.println(myDFPlayer.readCurrentFileNumber()); //read current play file number
  Serial.println(myDFPlayer.readFileCountsInFolder(3)); //read fill counts in folder SD:/03
  isPlaying = true;
  myDFPlayer.enableLoopAll();
void loop()
 if (digitalRead(buttonPause) == ACTIVATED)
    if(isPlaying)
      Serial.print( " Paused " );
      delay(20);
      myDFPlayer.pause();
      isPlaying = false;
    else
      Serial.print( " Play " );
      delay(20);
      isPlaying = true;
      myDFPlayer.start();
  delay(20);
 if (digitalRead(buttonVolPlus) == ACTIVATED)
    if(isPlaying)
      Serial.print( " Vol-Up " );
      delay(10);
  if (digitalRead(buttonVolMinus) == ACTIVATED)
      Serial.print( " Vol-Down " );
      delay(10);
 if (digitalRead(buttonNext) == ACTIVATED)
    if(isPlaying)
      Serial.print( " Button Next " );
      trackCount++;
      myDFPlayer.next();
      delay(20);
  if (digitalRead(buttonPrev) == ACTIVATED)
    if(isPlaying)
      Serial.print( " Button Prev' " );
      myDFPlayer.previous();
      trackCount--;
      delay(20);
 if (digitalRead(buttonFolderNext) == ACTIVATED)
    if(isPlaying)
      Serial.print( " Button folder+ " );
      folderCount++;
      Serial.print(folderCount);
      folderChange();
      delay(20);
  if (digitalRead(buttonFolderPrev) == ACTIVATED)
    if(isPlaying)
      Serial.print( " Button folder- " );
      folderCount--;
      folderChange();
      delay(20);
  if (myDFPlayer.available())
    printDetail(myDFPlayer.readType(), myDFPlayer.read()); //Print the detail message from DFPlayer to handle different errors and states.
  while (myDFPlayer.available())
    char inChar = ((char)(myDFPlayer.read()));                    //This method is a work-around for me being too dumb.
    Serial.print(myDFPlayer.readType(), myDFPlayer.read());       //I'm too dumb to figure out ho to read the "play finished" output as a string?
    if (inChar != 0)                                              //So i came up with this, Disgusting! it's just using any data while playing to 'auto-next'.
        if(isPlaying)                                             //Even interference from a spark plug could trigger this.  Shield your wires?
         Serial.print( " Auto-Button Next " );
         trackCount++;
         myDFPlayer.next();
         delay(20);
         inChar = 0;
  delay(120);
void folderChange()
  if (folderCount == 1) {
    myDFPlayer.play((5));
    Serial.print(" 5 ");
  else if (folderCount == 2) {
    myDFPlayer.play((10 + trackCount));
    Serial.print(" 10 + ");
    Serial.print(trackCount);
  else if (folderCount == 3) {
    myDFPlayer.play((15 + trackCount));
    Serial.print(" 15 + ");
  else if (folderCount == 4) {
    myDFPlayer.play((20 + trackCount));
    Serial.print(" 20 + ");
  else if (folderCount == 5) {
    myDFPlayer.play((25 + trackCount));
    Serial.print(" 25 + ");
  else if (folderCount == 6) {
    myDFPlayer.play((30 + trackCount));
    Serial.print(" 30 + ");
  else if (folderCount == 7) {
    myDFPlayer.play((35 + trackCount));
    Serial.print(" 35 + ");
  else if (folderCount == 8) {
    myDFPlayer.play((40 + trackCount));
    Serial.print(" 40 + ");
  else if (folderCount == 9) {
    myDFPlayer.play((45 + trackCount));
    Serial.print(" 45 + ");
  else if (folderCount == 10) {
    myDFPlayer.play((50 + trackCount));
    Serial.print(" 50 + ");
  else if (folderCount == 11) {
    myDFPlayer.play((55 + trackCount));
    Serial.print(" 55 + ");
  else if (folderCount == 12) {
    myDFPlayer.play((60 + trackCount));
    Serial.print(" 60 + ");
  else if (folderCount == 13) {
    myDFPlayer.play((65 + trackCount));
    Serial.print(" 65 + ");
  else if (folderCount == 14) {
    myDFPlayer.play((70 + trackCount));
    Serial.print(" 70 + ");
  else if (folderCount == 15) {
    myDFPlayer.play((75 + trackCount));
    Serial.print(" 75 + ");
  else if (folderCount == 16) {
    myDFPlayer.play((80 + trackCount));
    Serial.print(" 80 + ");
  else if (folderCount == 17) {
    myDFPlayer.play((85 + trackCount));
    Serial.print(" 85 + ");
  else if (folderCount == 18) {
    myDFPlayer.play((90 + trackCount));
    Serial.print(" 90 + ");
  else if (folderCount == 19) {
    myDFPlayer.play((95 + trackCount));
    Serial.print(" 95 + ");
  else if (folderCount == 20) {
    myDFPlayer.play((100 + trackCount));
    Serial.print(" 100 + ");
  else if (folderCount == 21) {
    myDFPlayer.play((105 + trackCount));
    Serial.print(" 105 + ");
  else if (folderCount == 22) {
    myDFPlayer.play((110 + trackCount));
    Serial.print(" 110 + ");
  else if (folderCount == 23) {
    myDFPlayer.play((115 + trackCount));
    Serial.print(" 115 + ");
  else if (folderCount == 24) {
    myDFPlayer.play((120 + trackCount));
    Serial.print(" 120 + ");
  else if (folderCount == 25) {
    myDFPlayer.play((125 + trackCount));
    Serial.print(" 125 + ");
  else if (folderCount == 26) {
    myDFPlayer.play((130 + trackCount));
    Serial.print(" 130 + ");
  else if (folderCount == 27) {
    myDFPlayer.play((135 + trackCount));
    Serial.print(" 135 + ");
  else if (folderCount == 28) {
    myDFPlayer.play((140 + trackCount));
    Serial.print(" 140 + ");
  else if (folderCount == 29) {
    myDFPlayer.play((145 + trackCount));
    Serial.print(" 145 + ");
  else if (folderCount == 30) {
    myDFPlayer.play((150 + trackCount));
    Serial.print(" 150 + ");
  else if (folderCount == 31) {
    myDFPlayer.play((155 + trackCount));
    Serial.print(" 155 + ");
  else if (folderCount == 32) {
    myDFPlayer.play((160 + trackCount));
    Serial.print(" 160 + ");
  else if (folderCount == 33) {
    myDFPlayer.play((165 + trackCount));
    Serial.print(" 165 + ");
  else if (folderCount == 34) {
    myDFPlayer.play((170 + trackCount));
    Serial.print(" 170 + ");
  else if (folderCount == 35) {
    myDFPlayer.play((175 + trackCount));
    Serial.print(" 175 + ");
  else if (folderCount == 36) {
    myDFPlayer.play((180 + trackCount));
    Serial.print(" 180 + ");
  else if (folderCount == 37) {
    myDFPlayer.play((185 + trackCount));
    Serial.print(" 185 + ");
  else if (folderCount == 38) {
    myDFPlayer.play((190 + trackCount));
    Serial.print(" 190 + ");
  else if (folderCount == 39) {
    myDFPlayer.play((195 + trackCount));
    Serial.print(" 195 + ");
  else if (folderCount == 40) {
    myDFPlayer.play((200 + trackCount));
    Serial.print(" 200 + ");
  else if (folderCount == 41) {
    myDFPlayer.play((205 + trackCount));
    Serial.print(" 205 + ");
  else if (folderCount == 42) {
    myDFPlayer.play((210 + trackCount));
    Serial.print(" 210 + ");
  else if (folderCount == 43) {
    myDFPlayer.play((215 + trackCount));
    Serial.print(" 215 + ");
  else if (folderCount == 44) {
    myDFPlayer.play((220 + trackCount));
    Serial.print(" 220 + ");
  else if (folderCount == 45) {
    myDFPlayer.play((225 + trackCount));
    Serial.print(" 225 + ");
  else if (folderCount == 46) {
    myDFPlayer.play((230 + trackCount));
    Serial.print(" 230 + ");
  else if (folderCount == 47) {
    myDFPlayer.play((235 + trackCount));
    Serial.print(" 235 + ");
  else if (folderCount == 48) {
    myDFPlayer.play((240 + trackCount));
    Serial.print(" 240 + ");
  else if (folderCount == 49) {
    myDFPlayer.play((245+ trackCount));
    Serial.print(" 245 + ");
  else if (folderCount == 50) {
    myDFPlayer.play((250 + trackCount));
    Serial.print(" 250 + ");
  else if (folderCount == 51) {
    myDFPlayer.play((255 + trackCount));
    Serial.print(" 255 + ");
  else if (folderCount == 52) {
    myDFPlayer.play((260 + trackCount));
    Serial.print(" 260 + ");
  else if (folderCount == 53) {
    myDFPlayer.play((265 + trackCount));
    Serial.print(" 265 + ");
  else if (folderCount == 54) {
    myDFPlayer.play((270 + trackCount));
    Serial.print(" 270 + ");
  else if (folderCount == 55) {
    myDFPlayer.play((275 + trackCount));
    Serial.print(" 275 + ");
  else if (folderCount == 56) {
    myDFPlayer.play((280 + trackCount));
    Serial.print(" 280 + ");
  else if (folderCount == 57) {
    myDFPlayer.play((285 + trackCount));
    Serial.print(" 285 + ");
  else if (folderCount == 58) {
    myDFPlayer.play((290 + trackCount));
    Serial.print(" 290 + ");
  else if (folderCount == 59) {
    myDFPlayer.play((295 + trackCount));
    Serial.print(" 295 + ");
  else if (folderCount == 60) {
    myDFPlayer.play((300 + trackCount));
    Serial.print(" 300 + ");
  else if (folderCount == 61) {
    myDFPlayer.play((305 + trackCount));
    Serial.print(" 305 + ");
  else if (folderCount == 62) {
    myDFPlayer.play((310 + trackCount));
    Serial.print(" 310 + ");
  else if (folderCount == 63) {
    myDFPlayer.play((315 + trackCount));
    Serial.print(" 315 + ");
  else if (folderCount == 64) {
    myDFPlayer.play((320 + trackCount));
    Serial.print(" 320 + ");
  else if (folderCount == 65) {
    myDFPlayer.play((325 + trackCount));
    Serial.print(" 325 + ");
  else if (folderCount == 66) {
    myDFPlayer.play((330 + trackCount));
    Serial.print(" 330 + ");
  else if (folderCount == 67) {
    myDFPlayer.play((335 + trackCount));
    Serial.print(" 335 + ");
  else if (folderCount == 68) {
    myDFPlayer.play((340 + trackCount));
    Serial.print(" 340 + ");
  else if (folderCount == 69) {
    myDFPlayer.play((345 + trackCount));
    Serial.print(" 345 + ");
  else if (folderCount == 70) {
    myDFPlayer.play((350 + trackCount));
    Serial.print(" 350 + ");
  else if (folderCount == 71) {
    myDFPlayer.play((355 + trackCount));
    Serial.print(" 355 + ");
  else if (folderCount == 72) {
    myDFPlayer.play((360 + trackCount));
    Serial.print(" 360 + ");
  delay(50);
void printDetail(uint8_t type, int value){
  switch (type) {
    case TimeOut:
      Serial.println(F("Time Out!"));
      break;
    case WrongStack:
      Serial.println(F("Stack Wrong!"));
      break;
    case DFPlayerCardInserted:
      Serial.println(F("Card Inserted!"));
      break;
    case DFPlayerCardRemoved:
      Serial.println(F("Card Removed!"));
      break;
    case DFPlayerCardOnline:
      Serial.println(F("Card Online!"));
      break;
    case DFPlayerPlayFinished:
      Serial.print(F("Number:"));
      Serial.print(value);
      Serial.println(F(" Play Finished!"));
      break;
    case DFPlayerError:
      Serial.print(F("DFPlayerError:"));
      switch (value) {
        case Busy:
          Serial.println(F("Card not found"));
          break;
        case Sleeping:
          Serial.println(F("Sleeping"));
          break;
        case SerialWrongStack:
          Serial.println(F("Get Wrong Stack"));
          break;
        case CheckSumNotMatch:
          Serial.println(F("Check Sum Not Match"));
          break;
        case FileIndexOut:
          Serial.println(F("File Index Out of Bound"));
          break;
        case FileMismatch:
          Serial.println(F("Cannot Find File"));
          break;
        case Advertise:
          Serial.println(F("In Advertise"));
          break;
        default:
          break;
      break;
    default:
      break;
void serialEvent() {
  while (Serial.available()) {
    // get the new byte:
    char inChar = (char)Serial.read();
    // add it to the inputString:
    inputString += inChar;
    // if the incoming character is a newline, set a flag so the main loop can
    // do something about it:
    if (inChar == '\n') {
      stringComplete = true;
void execute_CMD(byte CMD, byte Par1, byte Par2)
// Excecute the command and parameters
  // Calculate the checksum (2 bytes)
  word checksum = -(Version_Byte + Command_Length + CMD + Acknowledge + Par1 + Par2);
  // Build the command line
  byte Command_line[10] = { Start_Byte, Version_Byte, Command_Length, CMD, Acknowledge,
                            Par1, Par2, highByte(checksum), lowByte(checksum), End_Byte
  //Send the command line to the module
  for (byte k = 0; k < 10; k++)
    mySoftwareSerial.write( Command_line[k]);
  • Confused 1
