Ghostchips
Ghostchips 1920-26 ford T bucket (of rust)
Don't mind this, it's just a basic, primitive tune i spent the afternoon adjusting
// constants won't change. Used here to set a pin number:
const int coil1 = 3;
const int coil2 = 5;
const int coil3 = 7;
const int coil4 = 9;
const int sensorPin1 = A4;
const int sensorPin2 = A1;
const int sensorPin3 = A2;
const int sensorPin4 = A3;
int sensorValue = 0;
int sensorThreshold = 200;
int sensorMax = 0;
// Variables will change:
volatile int coilState = LOW;
volatile int coilPin = LOW;
volatile int sparkTriggerDelayActive = false;     //added this to try & see if i can delay spark at low RPM.
volatile int sparkTriggerDelay = 0;
volatile unsigned long rpmCurrMicros= 0;
volatile unsigned long rpmOldMicros = 0;
volatile int sensor1TriggerCounter = 0;           // counter for the number of button presses
volatile int sensorTriggerState = false;         // current state of the button
volatile int lastsensorTriggerState = true;     // previous state  of the button/sensor in this case.
// constants won't change:
// Generally, you should use "unsigned long" for variables that hold time
// The value will quickly become too large for an int to store
const long dwell = 10;        // but this is how long the "points" are open, open longer reduces duty cycle of coils.
const long coilCharge = 2;           // interval at which to charge coil (milliseconds)
void setup() {
  // put your setup code here, to run once:
  Serial.begin(9600);
  pinMode(coil1, OUTPUT);
  pinMode(coil2, OUTPUT);
  pinMode(coil3, OUTPUT);
  pinMode(coil4, OUTPUT);
  pinMode(A4, INPUT_PULLUP);
  pinMode(A1, INPUT_PULLUP);
  pinMode(A2, INPUT_PULLUP);
  pinMode(A3, INPUT_PULLUP);
void activateCoilsIfLow(uint8_t inPin, uint8_t outPin)
 volatile unsigned long timestamp = 0;
   if (analogRead(inPin) <= sensorThreshold)
    if (lastsensorTriggerState = (false))
      delay(sparkTriggerDelay);
    else
      coilState = HIGH;
      coilPin = HIGH;
      digitalWrite(outPin, HIGH);
      timestamp = millis();
      while (coilState == HIGH && coilPin == HIGH && (timestamp + coilCharge) > millis());  //Busy wait
     digitalWrite(outPin, LOW);
      coilPin = LOW;
      while (coilState == HIGH && coilPin == LOW && (timestamp + dwell) > millis());
      coilState = LOW;
      coilPin = LOW;
  else if (analogRead(inPin) >= sensorThreshold)
    if (sensorTriggerState != lastsensorTriggerState)
      rpmOldMicros = rpmCurrMicros;
      rpmCurrMicros = micros();
      lastsensorTriggerState = false;
      rpmConsultRatioTable();
void loop() {
  activateCoilsIfLow(sensorPin1, coil1);
  activateCoilsIfLow(sensorPin3, coil3);
  activateCoilsIfLow(sensorPin2, coil4);
  activateCoilsIfLow(sensorPin4, coil2);
void rpmConsultRatioTable()
  if (rpmCurrMicros - rpmOldMicros >= 497512) //sub250rpm
      sparkTriggerDelay =0;
  else if (rpmCurrMicros - rpmOldMicros <= 255024) //125rpm
      sparkTriggerDelay =57;                   //prev'55
  else if (rpmCurrMicros - rpmOldMicros <= 169491) //177rpm
      sparkTriggerDelay =39;                   //prev' 37
  else if (rpmCurrMicros - rpmOldMicros <= 127512) //250rpm
      sparkTriggerDelay =27;                      //at 250 RPM and 45 degree sensor advance, this would be 30ms to TDC, subtract 2ms for coil charging and subtract more m.s. for advance
  else if (rpmCurrMicros - rpmOldMicros <= 85008) //375rpm
      sparkTriggerDelay =16;
  else if (rpmCurrMicros - rpmOldMicros <= 61000) //500rpm
      sparkTriggerDelay =11;
  else if (rpmCurrMicros - rpmOldMicros <= 48000)  //625rpm
      sparkTriggerDelay =7;
  else if (rpmCurrMicros - rpmOldMicros <= 41000) //750rpm
      sparkTriggerDelay =2;
  else if (rpmCurrMicros - rpmOldMicros <= 31500) //just under 1000rpm
Posting this here so i can find it later if i'm not home.
Side note: i am probably the only person using milliseconds to determine when to fire the plug compared to using actual degrees.
Share this post
Link to post
Forget that one, the new tune is better.  That one sounded like a series of tiny gearshifts, kind of like an early fast&furious movie.
Eww why is there a digital thing on my dash?  Oh, if i look closer it's an exhaust temp' sensor.  But the gauge seems to have suffered damage from a 25 volt alternating current charging system.  But it worked for a month so i guess i got enough data...
Share this post
Link to post
/* i have no idea how this works
 *  I gave up in frustration & just starting putting code anywhere, it works?  Umm ok.
 *  There should be a second scale to test out for diagnostics, it's hidden
 *  by the star slash symbos just like this text is, appers 'greyed out' in my uploader software
 *  (arduino IDE i think it's called?)
 *  Should be the same for you?
int starterDelay = 10000;
int sensorMax = 0;
volatile unsigned long startingDelayTimer = 0;
volatile int startingDelay = false;
volatile int sparkTriggerDelay = 0;               //added this to try & see if i can delay spark at low RPM.
volatile unsigned long rpmCurrMicros= 170000;
void setup() {
  Serial.begin(115200);
    if (lastsensorTriggerState = false)
    else if (lastsensorTriggerState = sensorTriggerState)   //this isn't working with one equal sign.  I'm so lost.
      delayMicroseconds(sparkTriggerDelay);
      coilState = HIGH;
      coilPin = HIGH;
      coilPin = LOW;
      coilState = LOW;
      coilPin = LOW;
      if (millis() >= (startingDelayTimer + 10000))
        if ((rpmCurrMicros - rpmOldMicros <=  169491))         //over approx' 177RPM
           startingDelay = true;                               //no longer hold timing advance-retard at full advance, hope you moved the timing lever by now.
        if ((rpmCurrMicros - rpmOldMicros >= 497512))
          startingDelay = false;                               //chances are you have to re-start the engine now. it'll take 10 seconds or more at over 200RPM to act normal again.
          startingDelayTimer = millis();
      if (startingDelay == true)
      else
       Serial.print ( " Starter delay period not ended " );
  lastsensorTriggerState = false;           //Why do i need to make that 'false' so many times to avoid it doing weird things?
void loop() {
  else if ((rpmCurrMicros - rpmOldMicros <= 255024) && (rpmCurrMicros - rpmOldMicros >= 169491)) //125rpm
      sparkTriggerDelay =81000;                     //was 57, then 59 and i don't know what overflow is but i get an error for it here.
      Serial.print ( " RPM 125" );
  else if ((rpmCurrMicros - rpmOldMicros <= 169491) && (rpmCurrMicros - rpmOldMicros >= 127512)) //177rpm
      sparkTriggerDelay =61000;
      Serial.print ( " RPM 177" );
  else if ((rpmCurrMicros - rpmOldMicros <= 127512) && (rpmCurrMicros - rpmOldMicros >= 85008)) //250rpm
      sparkTriggerDelay =41000;                    //was 27  //at 250 RPM and 45 degree sensor advance, this would be 30ms to TDC, subtract 2ms for coil charging and subtract more m.s. for advance
      Serial.print ( " RPM 250" );
  else if ((rpmCurrMicros - rpmOldMicros <= 85008) && (rpmCurrMicros - rpmOldMicros >= 61000)) //375rpm
      sparkTriggerDelay =31000;                 //was 16
      Serial.print ( " RPM 375 " );
  else if ((rpmCurrMicros - rpmOldMicros <= 61000) && (rpmCurrMicros - rpmOldMicros >= 48000)) //500rpm
      sparkTriggerDelay =23000;                 //was 11
      Serial.print ( " RPM 500 " );
  else if ((rpmCurrMicros - rpmOldMicros <= 48000) && (rpmCurrMicros - rpmOldMicros >= 41000))  //625rpm
      sparkTriggerDelay =7000;
      Serial.print ( " RPM 625 " );
  else if ((rpmCurrMicros - rpmOldMicros <= 41000) && (rpmCurrMicros - rpmOldMicros >= 30000)) //750rpm
      sparkTriggerDelay =1670;
      Serial.print ( " RPM 750" );
  else if ((rpmCurrMicros - rpmOldMicros <= 30000) && (rpmCurrMicros - rpmOldMicros >= 25000)) //1000rpm
      Serial.print ( " RPM 1000 " );
  else if ((rpmCurrMicros - rpmOldMicros <= 25000) && (rpmCurrMicros - rpmOldMicros >= 23076)) //1200rpm
      sparkTriggerDelay =125;
      Serial.print ( "RPM 1200 " );
  else if ((rpmCurrMicros - rpmOldMicros <= 23076) && (rpmCurrMicros - rpmOldMicros >= 22222)) //just under 1300rpm
      sparkTriggerDelay =20;
      Serial.print ( " RPM 1300 " );
  else if (rpmCurrMicros - rpmOldMicros <= 22222)//just over 1300rpm
      Serial.print ( "RPM over 1300" );
void rpmConsultRatioTable()  //Very Retarded, for diagnostic purposes
      Serial.print ( "RPM Zero" );
      sparkTriggerDelay =162000;                     //was 57, then 59
      Serial.print ( "RPM 125" );
      sparkTriggerDelay =78000;
      Serial.print ( "RPM 177" );
      sparkTriggerDelay =64000;                    //was 27  //at 250 RPM and 45 degree sensor advance, this would be 30ms to TDC, subtract 2ms for coil charging and subtract more m.s. for advance
      Serial.print ( "RPM 250" );
      sparkTriggerDelay =32000;                 //was 16
      Serial.print ( "RPM 375" );
      sparkTriggerDelay =26000;                 //was 11
      Serial.print ( "RPM 500" );
      sparkTriggerDelay =14000;
      Serial.print ( "RPM 652" );
  else if ((rpmCurrMicros - rpmOldMicros <= 41000) && (rpmCurrMicros - rpmOldMicros >= 31500)) //750rpm
      sparkTriggerDelay =2670;
      Serial.print ( "RPM 750" );
      Serial.print ( "RPM 1000" );
  • Haha 1
  • Confused 2
Share this post
Link to post
On 28/11/2019 at 20:57, SOHC said:
I gave you like 7 carburetors and you lost them all, did you find the brass ones?
Yes i found enough pieces of bronze ones to make about 80% of one, then faked the rest with bits from the rustiest one i could find.
Not sure why i spent about...50 hours on it?  It's a ...questionable? design, like, Victorian era "I just designed an engine that runs on gas & want to run it on liquid fuel & this is the best I have" design.  Not horrible, just weird.  They have a 'toilet lid' looking flapper in them and a bowl of gas, and tubes, and the flapper not only regulates how much air (yes air) gets sucked into the main jet but opens at speed as a kind of mixing valve?  And doubles as a backfire arrestor.
Weird, logical enough, but horridly old fashioned.
Share this post
Link to post
